Curve Sketching: How to Identify Multiple Global Minimums in a Quartic Function?
  • Thread starter Thread starter Hollysmoke
    Curve Stupid
9 replies · 3K views
Hollysmoke
Is it possible to have 2 global minimums? I'm just having trouble determining whether this quartic has minimums or not =/
No. There is only one global minimum, however, a function can be minimal in more than one place.
For example, the function:
f(x)=0
is minimal everywhere.
For the function y=x^4-2x^2-2, does this look right, then? I know the IPs are right but I'm not sure about the minimums.
http://img174.imageshack.us/img174/3466/graphpickup5mj.png
Right! (I wasn't sure if you were marking it as a minimum or not, but I wanted to be sure you noticed)
That was a typo on my part (thank you for noticing it!)
So there are no minimums in this case?
Becaue when I try to calculate it, the 3 critical numbers I get are 2,-2, and 0. But if I sub in 2 or -2, I get 6, which doesn't seem right...
No, there are minimums, just no absolute minimums. There are actually 2 local minimums, and one local maximum between them.
f(x)=0
But isn't the definition of the minimum (not at a domain endpoint) that:
[tex]f(x \pm \epsilon) > f(x)[/tex] for sufficiently small [tex]\epsilon[/tex]
But [tex]f(x \pm \epsilon) = f(x)[/tex] if [tex]f(x)=0[/tex] for all x and so would not have any minimum.
Your plot should make it obvious that there is in fact a global (absolute) minimum so you should either distrust your plot or your work.
Check your critical points again! (in the plot we trust)
Beam me down said:
But isn't the definition of the minimum (not at a domain endpoint) that:...
Nope, it's a less than or equal to, [tex]\leq[/tex], for a minimum. Or [tex]\geq[/tex] if you're looking in a mirror.
