Calculating Velocity at a Specific Point on a Curved Slit
The problem involves calculating the velocity at a specific point on a curved slit defined by a sine function. The original poster states that the velocity is constant in the x-direction and seeks to determine the vertical component of velocity at a given x-coordinate.
  • Participants discuss the calculation of vertical velocity using derivatives and the application of the chain rule. There is confusion regarding the interpretation of the problem, particularly whether it asks for velocity or acceleration.
Some participants have offered guidance on the correct application of derivatives and the chain rule. There is ongoing exploration of the implications of the cosine function's range and its argument in the context of the calculations being performed.
Participants note discrepancies in the problem statement and express uncertainty about the requirements, particularly regarding the distinction between velocity and acceleration.
Melawrghk
The shape of the arch is defined by a sine function with a = 0.2 and the width of the arch is 1m. The velocity v is constant at 2m/s. What is the velocity at point P when x=0.25m?
So since v is just in the x-direction, I figured that's the vx speed.
Then I came to having to find an equation to vy and this is where I get stuck. I remember from high school physics that equation of velocity can be essentially found by taking a derivative of the position equation.
In this case I get:
vy=y'=0.2*pi*cos(pi*x)
From which I can find that at x=0.25m, vy = 0.444288 m/s
But that combined with the horizontal speed of 2m/s gives me a resultant velocity of 2.05ish, instead of 2.19 that I'm supposed to get. Help please?
It is asking for acceleration, not velocity. You are adding apples to oranges.
BTW, is that the exact wording of the problem? - it is appauling.
Yeah, that's the exact wording.
Sorry, the question is a two parter. I'll fix that. I just decided to not even tackle acceleration if I can't figure out velocity.
Where did I see acceleration?! I must be going mad. I am so sorry. Anyway, your velocity calculation is almost correct. Your problem is that vy is the derivative of y wrt t, not x. Think chain rule.
Oh thank you, thank you! :) That allows me to get acceleration as well. Yay!
Except... Now I'm doing a question that's basically the same, except
y=0.23sin(pi*x) and Vx=2.4m/s and we have to find velocity at x=0.32
I did the same thing as before and got:
Vy = 0.552*pi*cos(2.4*pi*t)
But the thing in the brackets ends up being >1 and that can't be. What did I do? :S
What thing in brackets? Do you mean 2.4πt? What's wrong with that being >1?
Yes that, but cos can't be >1...
The cosine is not >1; its argument is >1. The domain of cos(x) is x any real number, (and actually this can be generalized even further). I think you're worried about the range. Don't worry about that; your calculator will take care of it.
  • · Replies 29 ·
10K
