Cutkosky Cutting Rules: Understanding Rules & Where To Add i
  • Context: Graduate
  • Thread starter Thread starter thoughtgaze
    Cutting Rules
The discussion revolves around the application of Cutkosky's cutting rules in quantum field theory, specifically addressing the treatment of propagators and the introduction of delta functions when evaluating Feynman diagrams. Participants explore the implications of including or excluding factors of i in the replacement of propagator terms and the conventions used in labeling vertices in diagrams.
  • One participant questions the standard replacement of propagators in the context of Cutkosky's rules, noting a discrepancy in signs when applying the rules to a loop amplitude in ##\phi^3## theory.
  • Another participant suggests that the issue may stem from the evaluation of Feynman diagrams, implying a potential misunderstanding of the cutting rules.
  • A third participant shares their experience using Cutkosky's rules, explaining that the replacement of off-shell propagator terms with delta functions is typically given by ##(k^2-m^2+i\epsilon)^{-1} \rightarrow 2 \pi \delta(k^2-m^2)##, and discusses the role of factors of i depending on the version of the Feynman rules used.
  • One participant expresses interest in the convention of treating vertices differently based on complex conjugation and requests references for this notion.
  • Another participant provides a reference to a paper that discusses the treatment of vertices in the context of complex conjugation, indicating that this approach may not be widely recognized.
Participants exhibit disagreement regarding the correct application of Cutkosky's rules and the treatment of factors of i in propagator replacements. There is no consensus on the conventions used for labeling vertices or the validity of the proposed replacements.
Participants express uncertainty about the conventions used in their calculations and the implications of different approaches to Feynman diagrams. The discussion highlights the potential for varying interpretations of the cutting rules and the need for clarity in definitions and assumptions.
thoughtgaze
OKay, so whenever I run into explanations on the cutting rules, most of the time I see the statement to replace##\frac{1}{p^2 - m^2 + i\epsilon} \rightarrow -2i\pi \delta(p^2 - m^2)## for each propagator that has been cut
taking note that there is no factor of i in the numerator for ##\frac{1}{p^2 - m^2 + i\epsilon}##
so for example, for ##\phi^3## theory we can have a loop amplitude given by
##iM(p^2) = \frac{(i\lambda)^2}{2} \int \frac{d^4k}{(2\pi)^4}\frac{i}{(k-p)^2 - m^2 + i\epsilon}\frac{i}{k^2 - m^2 + i\epsilon}##
or
##iM(p^2) = -\frac{(i\lambda)^2}{2} \int \frac{d^4k}{(2\pi)^4}\frac{1}{(k-p)^2 - m^2 + i\epsilon}\frac{1}{k^2 - m^2 + i\epsilon}##Making the cut through the diagram, and making the above defined replacement gives
##-\frac{(i\lambda)^2}{2} \int \frac{d^4k}{(2\pi)^4}[-2i\pi \delta((k-p)^2 - m^2)][-2i\pi \delta(k^2 - m^2)]##
upon simplifying we should have...
##-\frac{(\lambda)^2}{2} \int \frac{d^4k}{(2\pi)^2}[\delta((k-p)^2 - m^2)][\delta(k^2 - m^2)]##
which is off, by a minus sign, from the right answer...
I would get the right answer if I made the replacement
##\frac{i}{p^2 - m^2 + i\epsilon} \rightarrow -2i\pi \delta(p^2 - m^2)##
WITH the factor of i in the numerator
instead of ##\frac{1}{p^2 - m^2 + i\epsilon} \rightarrow -2i\pi \delta(p^2 - m^2)##
WITHOUT the factor of i in the numerator
What am I doing wrong?
The main thing I see you're doing wrong is evaluating Feynman diagrams.
Oh? Well how so?
@thoughtgaze
I have been using Cutkosky's cutting rules extensively in my summer project but I still regard myself as an amateur in QFT so please take everything I am saying with a pinch of salt as they say :) The replacement of the off shell propagator terms with delta functions when we take a 'cut' is given by, as far as I am aware, ##(k^2-m^2+i\epsilon)^{-1} \rightarrow 2 \pi \delta(k^2-m^2)##.
The factors of ##i## come into play depending on whether we are using the normal or complex conjugated version of the Feynman rules. Given a cut diagram, there is a convention that we label the vertices of the diagram black or white, black vertices follow standard Feynman rules and are accompanied by a factor of ##i## and white ones the complex conjugated version so come with a ##-i##. In this set up, there is usually a corresponding theta function in the replacement above of the propagator terms so that energy flow from black to white vertices is counted positively but I am not sure if you are perhaps using another convention.
Interesting, I have not heard of this convention to treat the vertices differently by complex conjugation. Do you have any references for this particular notion?
Also, I have not seen ##(k^2-m^2+i\epsilon)^{-1} \rightarrow 2 \pi \delta(k^2-m^2)## in any reference I have, for example, peskin&schroeder eq. 7.56
Apologies for delay in replying,
See for example pages 9-10 of this paper http://arxiv.org/pdf/1401.3546v2.pdf.
