Cycle decompositions of the rigid motions of the cube
  • Thread starter Thread starter gotmilk04
    Cube Cycle
The discussion focuses on the cycle decompositions of the 24 rigid motions of a cube, represented as permutations of its 6 faces, forming a subgroup known as S_{CUBE} within S_{6}. Participants explore how to represent these permutations and their cyclic decompositions, using examples such as rotating a cube and analyzing the resulting face positions. The conversation also touches on the relationship between S_{CUBE} and A_{6}, prompting further investigation into whether S_{CUBE} qualifies as a subgroup of A_{6} based on its properties.
  • Understanding of group theory, specifically permutation groups.
  • Familiarity with cyclic permutations and their decompositions.
  • Basic knowledge of rigid motions and symmetries in three-dimensional geometry.
  • Experience with mathematical notation and concepts related to S_{n} and A_{n} groups.
  • Study the properties of permutation groups, focusing on S_{6} and A_{6}.
  • Learn about cyclic decompositions and their applications in group theory.
  • Explore the geometric interpretations of rigid motions in three-dimensional space.
  • Investigate the relationship between symmetry groups and their corresponding algebraic structures.
Mathematicians, students of abstract algebra, and anyone interested in the geometric properties of cubes and their symmetries will benefit from this discussion.
gotmilk04
Write down cycle decompositions of all 24 of the rigid motions of the cube by regarding each rigid motion as a permutation of the 6 faces.
Then, this is a subgroup of S_{6}, called S_{CUBE}.
Prove or disprove that S_{CUBE} is a subgroup of A_{6}
I'm not sure how the permutations are represented in regards to the 6 faces of the cube, so I can't do much else until I know that.
Would it help to look at some dice?
Place one on a desk in front of you with
6 on top
5 on front
4 on left
3 on right
2 on back
1 on bottom.
Now keep the 6 on top and 1 on bottom, but rotate so that
5 is on left
4 on back
3 on front
2 on right.
You could represent that as (5 4 2 3) meaning that the 5 got sent to where the 4 was, the 4 got sent to where the 2 was, etc.
A cyclic decomposition of a permutation is a way of isolating the things which go to each under repeated application of the Permutation. f Associate to each face of the Cube, and a number {1,...,6}, and then consider an element of the permutation Group on 6 letters. Can you find a symmetry of the cube, which is capable of reproducing this permutation? That is, rotation about some axis (Say, rotation by Pi or Pi/2 about the axis going through the center of the faces (Perhaps you can't; think about this. Why is this impossible?) Now think about the the Group of permutations on 4 letters. Can you identify some part of the cubes geometry which is permuted in a way such that every element of S_4 corresponds to a permutation of these parts of the cube under permutations?
Also try going the other way around. For instance, if your cube is situated at the origin in R^3, what kinds of rotation options do you have? If you start with the top face 1, bottom 2, left 3, right 4, one facing you 5, and one away from you 6, assuming that x runs horizontally, z towards you, and y vertically. Say you rotate the cube by pi/2 about x. What is the image under this permutation of each face? Well, 3 and 4 aren't going to change/ they map to themselves. 1 is going to go to 5, 5 is going to go to 2, 2 is going to go to 6, and 6 is going to go to 1.
This gives you the cyclic decomposition of the permutation
(1526)(3)(4). So this rotation fixes three and four, and repeated applications of it "permutes" the other faces cyclically. Is it obvious to you that this is equally well thought of as the image of the faces under an element of S_6?
Where does that take the faces of your cube? Now think about the cyclic structure of the permutation p associated to this rotation about x (apply the permutation again, see where things go). Think about all the "rotations" and "flips" you can perform on this cube. What cyclic decomposition is associated to each kind (for instance, flips about the diagonals, or flips about the lines dividing the edges)
  • · Replies 20 ·
  • · Replies 18 ·
17K
