- 50,510
- 26,559
kurros said:I goes up as the masses separate, and L is conserved
Also, if you are extracting the energy and doing something else with it, is L still conserved? (Hint: electromagnetic fields, for example, can carry angular momentum.)
PeterDonis said:So what happens when all of that rotational energy is extracted?
PeterDonis said:Also, if you are extracting the energy and doing something else with it, is L still conserved? (Hint: electromagnetic fields, for example, can carry angular momentum.)
kurros said:Then you're done and no more can be extracted.
kurros said:It's conserved so long as nothing leaves the system
PeterDonis said:Not in the Earth case, which is the case in which I agree work will be done. In the Earth case, what does the free body diagram of the cable's suspension point look like?
Or put it this way: suppose that both ends of the cable were free falling towards the Earth (instead of the cable being suspended by a structure), with a mass at each end. Could you extract work by paying out the cable?
Take a step back to the Earth case, and modify it as I said above, to remove the obvious difference (as compared to the two galaxy case) of there being an extra force on the suspension point due to the Earth (i.e., not due to the tension in the cable). What happens?
PeterDonis said:Ok, good, so you agree that there is only a finite amount of rotational energy to be extracted. What state will the system be in when all of that energy is extracted?
If nothing leaves the system, where does the energy you extracted from the rotational kinetic energy go?
kurros said:now it isn't analogous anymore because both ends of the cable are just freely falling
kurros said:It doesn't have to go anywhere. We could just turn on a lamp inside an insulated box or something, in which case the interior of the box just heats up.
PeterDonis said:It's certainly not analogous to the original Earth case, no. But at least you agree that, if both ends of the cable are freely falling, no work can be extracted. Ok.
Now, suppose we start out with two masses and a cable connected to each one, but the cable is slack, and the two masses are being subjected to some tidal gravity. The masses will start to separate, and the cable will gradually get less slack until it reaches its natural unstressed length. Up to that point, will any work be extracted by this process?
kurros said:Though you will get less and less energy per unit change in separation since the tension in the cable gradually decreases.
kurros said:It is interesting though that the acceleration actually *increases* with separation in the dark energy case. I don't know what's up with that or where the energy comes from in that case.
PeterDonis said:Ok, so from the standpoint of the center of mass inertial frame, you're transferring rotational kinetic energy to heat energy. Ok so far.
When you pay out a little bit of the cable and increase the separation of the masses, again from the standpoint of the center of mass inertial frame, does the angular velocity increase, decrease, or stay the same?
kurros said:It goes down because L=I w, and L is fixed while I increases, so w decreases.
kurros said:No, because the masses are just moving on geodesics up to that point.
PeterDonis said:Agreed.
Bingo! You just stated a crucial difference. The reason you are confused is that you are not seeing that this difference means that, while work is being extracted in the rotating case, work has to be input in the dark energy case--in order to increase the tension in the cable. (And similarly, if you have two masses connected by a cable inside a spaceship that is in a free-fall orbit in the Earth's tidal gravity, you would have to input energy to the two mass-cable system to extend the cable, because its tension will have to increase.)
Also, this illustrates the key difference between the dark energy case and the mass suspended on Earth case. In the mass suspended on Earth case, as the mass is lowered, the potential energy of the system decreases. But as the two galaxies separate in an expanding universe, the potential energy between them increases. (This is actually not a rigorous argument, because there isn't really a well-defined potential energy in a non-stationary spacetime like an expanding universe--whether dark energy is present or not. But as a heuristic it should serve.)
PeterDonis said:Ok, good. Now, once the cable starts to go under tension, the system will reach an equilibrium in which the cable tension is just sufficient to hold the masses at constant separation. Compared to the point at which the cable was at its natural unstressed length, has energy been added to this system, or removed?
kurros said:You certainly do not *need* energy for the masses to separate, since this is what they will do just by following their freely falling paths if you cut the rope.
kurros said:I think their potential energy effectively decreases as they separate, since we are in a regime where dark energy is dominating over "ordinary" attractive gravity.
kurros said:Energy has been added.
kurros said:until the tidal forces goes to zero because the separation is too large
kurros said:If you have a solid objection to any of this then I'd really like to hear it.
PeterDonis said:Let me take a step back and try to make explicit the intuitions that lie behind what I've been saying.
PeterDonis said:I'll defer that until I've had a chance to look at the potential energy math.
Yes, I understand that the discovery of an accelerating expansion has prompted Adam Reiss to revive interest in the cosmological constant and point to "dark energy" as the source of the accelerated expansion, but by tailoring the cosmological constant to fit the observations however accurately, is still just a mathematical description of our observations, and doesn't address what is the underlying physical mechanism that causes the expansion, even if it had turned out to be decelerating instead.kimbyd said:To expand a little on Orodruin's response, dark energy doesn't cause the expansion at all. It modifies the rate of expansion, making it higher in the late universe than would otherwise be the case.
How is this different from the rest of GR (or other parts of physics)? Maybe I'm misinterpreting here, but it seems like, if I wrote the Maxwell equations, they would be subject to the same objection: that the equations are just math descriptions without an underlying physical mechanism. Or likewise the Einstein equations for the case that Λ = 0: The equations are just descriptive of reality -- and that's no mean feat.alantheastronomer said:...tailoring the cosmological constant to fit the observations however accurately, is still just a mathematical description of our observations, and doesn't address what is the underlying physical mechanism that causes the expansion, even if it had turned out to be decelerating instead.
Wait, what? Not sure I get this part of your argument. Tension is a scalar (or rank 2 rensor if you prefer). It does not point.PeterDonis said:(1) Tension in the rope.
A: The tension is constant, and points upward (i.e., it pulls the mass upward, and the suspension point pulls the rope upwards).
You are here looking at different objects. At both the ends, it pulls what is attached to that end towards the other end.PeterDonis said:(i.e., it pulls the mass upward, and the suspension point pulls the rope upwards).
But now you moved the goal post. In A the ripe pulls the mass towards the branch and the branch towards the mass. In B it also pulls each galaxy towards the other. I also do not see why the tension would be zero in the middle.PeterDonis said:B: The tension changes sign: it points inward at both ends (i.e., it pulls each mass inward), and decreases from each end towards the center of the rope, where it is zero.
PeterDonis said:They will not separate immediately; if they are at rest when you cut the rope, they don't instantaneously acquire a nonzero velocity.
But cutting the rope is not what you were proposing; you were proposing paying out the rope. So what happens if you do that when the masses are at rest relative to each other and the system is in equilibrium?
Hm. I'll have to look at how this works in de Sitter spacetime, which has zero stress-energy except for the "dark energy" of the cosmological constant, unlike the FRW spacetime in our current best-fit model, which has both ordinary matter and dark energy. The lack of the latter in de Sitter means it has a timelike Killing vector field, which means that a potential energy can be rigorously defined, unlike the hand-waving I was doing.
Are you sure? Consider: at the point where the cable was at its natural unstressed length, the masses were moving outward relative to each other. At the point where the cable is under tension and we are in equilibrium, the masses are at rest relative to each other. So where did their kinetic energy go?
Huh? Tidal acceleration increases with separation for ordinary tidal gravity like the Earth's. Tidal acceleration between two masses separated by a distance ##L## and in a circular orbit of radius ##R## around the Earth goes like ##a \approx GM L / R^3##.
Consider two test masses that are both moving on geodesics, which are diverging because of tidal gravity. Can those masses do work? It seems obvious to me that, if they are moving on geodesics, they can't do any work, because to do work, they would have to exert a force on something, which means they would have to transfer momentum, and by conservation of momentum, that would have to change their own momentum, which means they would have nonzero proper acceleration and could not be moving on geodesics.
Now, in the scenario under discussion (the original one, with two galaxies connected by a rope, but I'd rather view the "galaxies" as two test masses to avoid any complications from their own gravity), the masses were not claimed to be moving on geodesics; they are connected by a rope, and the rope has some tension, and that tension is restraining the motion of the masses. But we also said that the tension in the rope increases as the masses get farther apart. As you pointed out, that creates the question of where the energy is coming from. But even more basic than that: if the tension in the rope is increasing, then how can work be extracted from the system? It seems like work would have to be input into the system to increase the energy.
It is possible that your suggestion about potential energy could resolve at least some of this; as I said, I need to look at how the math actually would work in de Sitter spacetime, where the presence of a timelike KVF makes it possible to just turn the crank and derive a potential energy formula.
It's also worth noting that there is a key difference between "ordinary" tidal gravity, like that in the vacuum region around the Earth, and the "tidal gravity" produced by dark energy. The former is Weyl curvature; the latter is Ricci curvature. You can make them look similar by restricting attention in the Earth case to radial separations, where the tidal gravity causes geodesics to diverge (and I have implicitly been doing that in this discussion). But the difference is there.
PeterDonis said:Following on from my previous post, here is a comparison of the "mass suspended from a rope on Earth" scenario (which I'll call A) and the "masses connected by a rope in free fall under tidal gravity" scenario (which I'll call B).
(2) Work extracted.
A: Work can be extracted at the suspension point because the constant tension in the rope transmits the "force" of the mass descending.
B: Work cannot be extracted at one end based on the relative motion of the mass at the other end, because the tension in the rope is zero at the center, so the rope cannot transmit force from one end to the other. This is also evident from the fact that the tension at the two ends of the rope points in opposite directions.
This does raise the question: could work be extracted at the center of the rope, by paying out rope at equal rates in both directions? (It would have to be equal in both directions in order for the center of the rope to move on a geodesic, since the net force there must be zero.) I'll defer that until I've had a chance to look at the potential energy math.
JMz said:The underlying question for me about all the issues with the rope: In the presence of non-zero Λ, is there a theorem that states that something is conserved that we agree should be called "energy"?
Yes, Noether's is obviously relevant. But the problem this thread seems to be focusing on is the question of whether there is something that would be conserved if Λ=0, that is (somehow) energy-like, but that isn't when Λ≠0.Orodruin said:The theorem related to conserved quantities is Noether’s theorem. What we typically call ”energy” is the Noether charge related to time translation invariance. Since an expanding universe is not time-translation invariant, energy is generally not globally conserved. Of course, this does not violate local conservation of the stress-energy tensor.
Orodruin said:Tension is a scalar (or rank 2 rensor if you prefer). It does not point.
kurros said:I think the existence of tension in the tether makes it crystal clear that energy is indeed able to come from somewhere.
