Dark energy = cosmological constant, any problems with that?
153 replies · 15K views
kurros said:
You could absolutely put your generator in the center.
If this turns out to be correct (which it might--as I said, I have not looked at the details of the math for this yet), it does not imply that you could also extract energy at either end. The center has a property that no other point has--the energy extraction machine can stay static there without having to have any proper acceleration. And by hypothesis, there is no source of proper acceleration other than the tension in the rope, which can't both hold anything static and allow any extraction of work.
Astronomy news on Phys.org
kurros said:
You could absolutely put your generator in the center. Just attach the spool correctly so that the cable going up and the cable going down are turning it in the same direction. Should be no problem at all. In fact I have some headphones that work like this, they attach to a spool with a spring in the center which automatically winds up the cable from the middle. You pull on both ends to unwind it, which stores energy in the spool spring. Could generate electricity just as well.
Edit: like these: https://www.amazon.com/dp/B000W8GMNY/?tag=pfamazon01-20
On a slightly related topic, I made a post a while back to do with recession velocity >c I asked if I tied an arbitrarily long rope to a distance galaxy that was receding, as at some point that galaxy would be receding away from me > c, would the rope be moving locally at a velocity > c?
It was shown that this wasn’t possible because the rope would break due to ‘tension’ caused from expansion.
So even if it were possible to have a rope that long (which it’s been proven it’s not) and use a generator to harness the effects of expansion you’d still have to deal with a local velocity of the rope >c.
Does "local velocity" mean relative to comoving objects? As the rope can't be thought spacelike (I think not even in a thought experiment) one end has to be transported along a timelike path. Doesn't this make difference?
What do you mean by "local velocity"? Even in the case of two comoving observers who, relative to each other, are separating "faster than c" (which is itself a somewhat misleading description), neither of them are moving faster than c relative to objects in their local areas, nor are either of them moving faster than light beams in their local areas.
The issue with trying to connect two such comoving observers by a rope is that the tension in the rope would have to be "greater than infinity", heuristically speaking (the tension increases without bound as the separation between the observers approaches the cosmological horizon, which is the point at which they are moving "at c" relative to each other, in the somewhat misleading language that is often used to describe this scenario--so if each observer is beyond the other's cosmological horizon, the tension in a hypothetical rope between them would have to be "greater than infinity"). It has nothing to do with any "local velocity > c".
As I understood the thought experiment mentioned there is a generator made up of a spool of two cables, each attached to distant galaxies. As the galaxies move apart it pulls the cables out of the spool which turn the spool to create electricity in some way.
Ignoring the fact that this scenario isn’t possible (as mentioned in my pervious post) if we imagine the cables are of arbitrary length, at some point the galaxies would be receding away from the spool at a velocity greater then c. Therefore if I was stood next to the spool I would see the cables moving relative to me at a velocity greater than c.
So the issue of harnessing any potential energy from expansion seems academic as the laws of physics would seem to prohibit it?
I don't see how your previous post is saying that the scenario is impossible in general. (Nor did the previous thread you refer to.) The scenario is only impossible if the galaxies are so far apart that each one is beyond the other's cosmological horizon (i.e., each one's recession velocity relative to the other is "faster than c", in the misleading language that is often used). But the scenario under discussion in this thread in no way requires that.
No, they wouldn't, because the cable would break before that point was reached, since the tension in the table would increase without bound as the separation between the galaxies approached the cosmological horizon distance.
Even leaving aside the comment I just made, your implicit assumption here, that the speed of the cable at one galaxy must be the same as the "recession velocity" of the other galaxy, is not correct. If it were, no work could be extracted, because the cable would have to be in free fall.
The post I was referring to was actually a very old thread from years ago and to be honest I can't remember at what point the rope would break. Also the rope was only tethered at one end. I'll have a look through my content and post the link.
But I would also imagine in the scenario mentioned it could be possible for there to be a point where they separation between the galaxies was still within the cosmological horizon distance but the spool could be rotating at a rate greater than c. So there must be something that stops this?
And this is the problem when you only quote part of a post, you can take things out of context. As I don't disagree with your statement at all and have already stated that. So not sure what you are getting at?
Even leaving aside your comment that isn't what I was implying. If we imagine it were possible to have some infinity long meter stick that is attached to a single galaxy that is receding away from me and I can watch the meter stick go by, if I time how fast the meters pass me, at some point they would be passing me at a rate greater than c. But as you said this isn't possible anyway.
No, there isn't. Once again, you are implicitly assuming that the rope has to move at the same velocity, relative to the spool, as a free-falling, comoving observer at the rope's other end. That's not the case. The rate at which the rope pays out can be as slow as you like.
You appeared to be describing something that's impossible, and then making a claim about what it would be like if that something happened. That doesn't make sense.
This has nothing to do with the scenario being discussed in this thread. The rope is not a meter stick; its unstressed length is not constant.
I don't think that is correct. The tension in the rope should be constant along the entire length, so you can attach the spool wherever you like. And it doesn't matter if the spool is static, the *rope* is not static, it is unwinding due to being "pulled" by the masses on both ends. Like if you grabbed both masses with your hands and pulled them apart. Attach the spool in the middle, the end, one third along, anywhere, it doesn't matter. Although you would have to have a bit of a weird spool setup to get it to sit one-third along, it would have to unwind rope twice as fast in one direction compared to the other or something. The forces balance more easily in the middle, or with the spool attached to one of the masses.
That's true. But we can just use really heavy masses rather than a long rope. The power generated should be proportional to the "anchor" masses, times their separation (since their relative acceleration should be proportional to their separation). So we could make a rope that is only a few hundred light years long (far enough that the acceleration due to dark energy is larger than their mutual gravitational attraction; they'll also have to sit in intergalactic space I guess, so that they aren't in some orbit in a galaxy which would have its own associated tidal forces) and attach them to big masses like the Earth, and the power generated should be measureable. Of course it is a ridiculous experiment, but the point is that we can do it on a scale small enough to avoid any part of the "apparatus" moving anywhere near c relative to any other part. And also small enough and moving slowly enough that a Newtonian analysis should be perfectly valid, once we compute the accelerations induced in the masses due to dark energy.
The proper acceleration of the rope has to vary along its length, since the center of the rope is in free fall and the masses at each end are not; and, as I said before, the proper accelerations of the masses at each end point in opposite directions.
(Anyway, I thought we agreed earlier that the tension in the rope had to increase as the masses got further apart. Is there now a reason why you think that is not the case?)
If nothing is holding the spool static, why won't it just fly away along with the rope? The point is that something has to be preventing the spool from doing that. In the case of the mass suspended from a rope on Earth, it's the structure supporting the spool, which is in turn supported by the Earth, that's doing that--the structure is pushing the spool upward so it doesn't fall along with the rope.
In the case of the two galaxies, if you put the spool at the center of the rope, and if you ensure that the rope is let out at equal rates in both directions, then the spool will stay in one place (because it can do so there with zero proper acceleration and all forces on it in balance), and in that case, I think that you can extract work, yes--because I think (but I haven't verified the math) that the potential energy released as the masses "fall" away from the spool in both directions is more than what is required for the increased tension in the rope as the masses get further apart.
If you put the spool at either end, then unless something holds it back and prevents it, it will just fall along with the mass at that end. It can't be the rope that's holding the spool; that's holding the mass, and the two can't just move together. And there's nothing else in the scenario.
Hmm, I guess that is technically true, but I think it is a miniscule component of the tension. We might as well approximate the rope as massless, and then it takes no force to move any segment of it off its geodesic, so there is essentially no tension due to this. Almost all the tension comes from moving the enormous masses attached to the ends of the rope off *their* geodesics, since F=ma :).
No we agree on that*, but really it is just the positions of the masses that are important, by the above argument, the mass of the rope itself doesn't really matter. Or at least, let us suppose that we have lightweight rope, such that it doesn't matter :).
*or at least, we agree the acceleration increases; the tension actually depends on how much friction or resistance is in your generator or spool; if there is no resistance then the spool just freely unwinds and you won't generate any power. You can crank up the resistance until you reach the breaking point of your rope, or create enough force to keep the heavy masses from moving anywhere, whichever comes first.
Bolt the spool onto one of the masses, and then wind the rope onto that spool. Then anchor the other end of the rope directly to the other mass. Or you could add another spool there if you wish to generate power on both ends, though you'll have to share the available energy :).
Shouldn't it be "let the rope wind off of the spool"? The rope's length is increasing, correct?
Sure, sure, whichever way you want to look at it :). Or picture a big pile of rope next to one of the heavy masses, which feeds through some mechanism (attached to that mass) which spins as the rope is pulled through by the other mass.
We can't do that, because a rope with zero rest energy density and nonzero tension violates energy conditions; it would have to be made of exotic matter, which is not believed to exist.
However, it might be that the energy stored in the rope is small compared to the potential energy change in the mass. That's one of the things I want to check in the math.
No; if the rope is being wound onto the spool, the spool has to be doing work on the rope, not the other way around.
Sorry this was just ambiguous grammar on my part. I meant wind the rope onto the spool to set up the experiment, then it can unwind as it is drawn off by the other mass.
Ok, that clarifies what you were saying.
Oh sure, let us use an extremely lightweight but rigid rope, so that it basically doesn't stretch at all and stores basically none of the energy we are talking about in its internal elastic potential energy. Like a chain made out of carbon nanotubes or something :). We just want it to transfer energy from place to place.
I think Peter is right, but I haven't done the math either. Here is another way of looking at it. Let your nanotube chain be much longer than the distance between the two comoving masses (in a LCDM universe), so that both masses slide past it. Now extract some small amount of local energy from this relative motion by whatever means. The two masses will start to recede slower and the relative motion will eventually stop - that is unless the accelerated expansion can counter it. I think this is more or less what needs to be put into math form.
Well we are both going around in circles here as we both agree the scenario is impossible so let's leave it there. I will say however although I'm happy to take it on face value I've never seen any math or what physics prohibits the length of a rope from spanning further than our cosmological horizon. But that's not important right now anyway.
I am? Ok, so just to check my understanding...
Ignoring cosmological distances for the moment, I have a spool with 2 cables attached, set up in similar way as described by kurros:
kurros said:
Each end of the cables are attached to 2 separate rocket ships so the spool is in the middle and the rocket ships are both moving away from the spool, at an equal rate wrt to the spool and in opposite directions. As the rocket ships move away it would be like pulling the chords from head phones out at both sides, as in the link above. This would turn the spool as the cables unwind. If the cables were marked every meter, then as the cables unwind I can measure how fast the meters pass me and this would give me the relative velocity of the space ships. (Ignoring any initial stretching of the cable etc.)
So that's simple enough I hope and no issues there.
So replace the rockets with distant galaxies that are moving away from the spool in opposite directions (ignoring what is causing them to move apart for the moment) and I imagine the effect on the spool would be exactly the same. As the galaxies move away, the spool turns as the cables unwind.
So assume those are comoving galaxies, there distance relative to the spool in the middle will increase due to expansion (assuming they are not gravitational bound.) As I understand it, as their distance increases the effect will be the same, the spool will turn as the cables unwind from it. And I can measure how fast the meter intervals pass me and this will give me rate of separation of the galaxies relative to the spool.
So is there any difference between two rocket ships pulling the cable from the spool and two distant galaxies pulling the cable from the spool?
It's the physics that tells you that the tension in the rope increases without bound as the distance between its ends approaches the cosmological horizon distance. The precise math is the expansion scalar of the congruence of worldlines that describes the rope.
Are you assuming flat spacetime? That is, no gravity? No expansion of the universe? If so, the rocket ships will need to fire their engines in order to pull the ends of the cable in opposite directions.
Not if you're also replacing flat spacetime with an expanding universe containing dark energy. In an expanding universe containing dark energy, the galaxies are in free fall; no rocket engines are attached to them pushing them apart. What makes them move apart is the geometry of spacetime. That is why you can't just assume that the results will be the same.
The whole point is to have this driven by the accelerated expansion. Whether or not this effect is large enough depends on its ratio compared to the mutual gravitational attraction of the masses. But that goes down with the square of the separation, whilst the dark energy acceleration increases linearly with separation, so the dark energy will win at large separations.
The former effect also goes up with the product of the masses, whereas the latter is independent of them. So it "could work" (in some very theoretical sense) even over small distances, as long as the participating masses are small, and the rope's mass is even smaller. Right?
I guess so, the only problem is that it gets swamped by other effects on small scales, like thermal motion. But maybe if you do it in some super-cold environment like a bose Einstein condensate then something could be measurable. I suspect that current condensates are still many orders of magnitude too hot though.
Well, I think this thread is well past the point of worrying about a mere few orders of magnitude. ;-)
Anyway, I envisioned some larger "local" region than an Earth-based lab.
Note: I have corrected a typo in the equation that I gave. It should have been the 2nd derivative of D, not the square of the first derivative.
To follow on with some simple math:
When talking about both masses comoving (with the Hubble flow) at large scales, there is no gravity (potential gradient) involved. At the present time, with the cosmological constant, there will be a local coordinate acceleration between each mass and the local nano chain of**
$$d^2D/dt^2 = D H_0^2(\Omega_\Lambda-\Omega_m/2)/2$$
in opposite directions. ##D## is the comoving distance between the two masses, ##\Omega_\Lambda## the cosmo-constant and ##\Omega_m## the present matter density parameter. Some form of energy extraction at each mass will enter as another negative term inside the brackets. As long as the factor inside the brackets remains positive, there could in principle be continuous energy extraction, not so? If so, it can even increase as ##\Omega_m## decreases over long periods. Or is it all wishful thinking?
** I have previously used the paper: "On the influence of the global cosmological expansion on the local dynamics in the Solar System" by Matteo Carrera and Domenico Giulini (2006), to calculate cosmic acceleration for a different scenario.
Lol fair enough. I'm not quite sure what sort of experiment could be done though, even of the extreme sort. The effect would be so tiny compared to all sorts of other environmental "noise" that it is hard to image what could be done. But ok, let's actually calculate the acceleration and see what we are dealing with.
$$dD^2/dt^2 = D H_0^2(\Omega_\Lambda-\Omega_m/2)/2$$
Sounds ok, but this form is not so great to use I think since we have to fiddle with H_0 and critical densities and such. I think we can just use the second Friedman equation more directly:
$$\frac{\ddot{a}}{a} = - \frac{4\pi G}{3}\left(\rho + \frac{3p}{c^2}\right) + \frac{\Lambda c^2}{3} $$
Let's then just ignore all matter and focus on the dark-energy dominated case. This is maximum acceleration we are ever going to get with a constant ##\Lambda##. So then we can ignore the density and pressure terms, and we are left with just
$$\frac{\ddot{a}}{a} = \frac{\Lambda c^2}{3} $$
##a(t)## is the scale factor which defines the ratio between proper distance between two comoving objects now ##r(t)##, relative to separation at some reference time in the past ##r_0## so
$$r(t) = a(t) r_0$$
Now, I forget the exact meaning of "t" in these coordinates, so I am not totally confident that the acceleration I am about to calculate is the correct one. If anyone sees that it needs fixing then please feel free :). I guess it is the proper time of comoving observers, though our masses are no longer comoving (although the centre of the bound system is comoving, so maybe if we measure the proper acceleration relative to the comoving point of our system then this is correct)
Anyway, suppose that we have a strong cable that just holds the two masses at fixed proper distance. I think the acceleration of the scale factor should then just give us the acceleration we want (up to my possible misuse of the time coordinate), which is the acceleration of the comoving coordinates relative to our proper separation. So, then, taking two deriviatives with respect to ##t## we have
$$\ddot{r}(t) = \ddot{a}(t) r_0$$
We can then substitute these expressions for ##a## and ##\ddot{a}## back into the second Friendman equation:
$$\frac{\ddot{r}(t) / r_0}{r(t) / r_0} = \frac{\Lambda c^2}{3} $$
$$ \ddot{r}(t) = r_0 \frac{\Lambda c^2}{3} $$
Now, ##\Lambda \sim 10^{-52} \mathrm{m}^{-2}## according to Planck data. ##c^2/3## is about ##3 \times 10^{16} \mathrm{m}^2 \mathrm{s}^{-2}##. So for 1m separation we are looking at ##\ddot{r} \sim 10^{-36} \mathrm{m s}^{-2}##, or ##10^{-37} g##. Thus to get to ##1\mathrm{g}## of acceleration we need ##r_0 = 10^{37} \mathrm{m}##. The universe is only about ##10^{26} \mathrm{m}## in diameter so this is pretty big. This is why I suggested going to large masses instead; the Earth is about ##10^{24}## kg, so for ##1##m separation the Earth would pull on the rope with about ##10^{24} \times 10^{-36} = 10^{-12}## N. 1 Lightyear is ##10^{15} \mathrm{m}##, so setting our separation at 1 lightyear gets us about ##10^{15} \times 10^{-12} = 10^3## N of tension, or 1 kN, which is certainly measureable. However, the mutual gravitational attraction of the two Earths is bigger than that I think, even at 1 lightyear separation (##G M^2 / r^2 = 10^{-11} \times (10^{24})^2 / (10^{15})^2 = 10^7 \mathrm{N}##). But the ##1/r^2## kills this pretty quickly so we only need to go a few more tens or hundreds of lightyears apart. Oh and actually I guess we only need one heavy mass, not two. So let's suppose we have the Earth and a 1kg mass. Then the gravitational attraction is just ##G M m / r^2 = 10^{-11} \times 10^{24} / (10^{15})^2 = 10^{-17} \mathrm{N}##. So ok we are fine at 1 Ly separation as long as one of the masses is small. Although hmm, that's probably no good, we need both masses to be heavy I think. If one mass is small then the Earth will just follow its comoving path and easily drag the small mass along for the ride. So we only really get tension from accelerating the smaller mass, and lose our factor of ##10^{24}##. So ok, back to two large masses, with a few hundred lightyear separation.
On the other hand, if we want to do some smaller experiment with small masses, then we lose this enormous factor of ##10^{24}## which helped us out a lot. The accelerations are super miniscule so I am not sure there is any hope of ever measuring them on small masses.
Note, I have corrected a crucial typo in the equation.
In which case I will argue that the equation which I started with is far simpler to use. For a flat de-Sitter spacetime, ##\Omega_\Lambda = 1##, I think, so all you need is the Hubble constant and the proper separation (D) between the two ends of the cable at any time:
##d^2D/dt^2 = D H_0^2/2##.
##dD^2/dt^2 = D H_0^2/2##.
Hmm I don't think that's true, but probably it is defined like ##\Omega_\Lambda H_0^2 = \Lambda c^2 / 3 ##, in which case there is similar complexity. Just depends on whether you rather deal with ##\{ \Omega_\Lambda, H_0\}##, or ##\{\Lambda, c\}##. I think I prefer the latter :). Actually maybe you are right and it works out that ##\Omega_\Lambda## is 1... well anyway they are pretty equivalent. It seems more physically intuitive to use ##\Lambda## to me, since you would just have to use that to calculate ##H_0## anyway. We also don't have to worry about how ##\Omega_\Lambda## or ##H_0## are defined this way.
