SupersonicMan
- 3
What is the evidence in favor of dark matter? How does does this take into account baryonic and non-baryonic matter?
mathman said:The significant question arises from the evidence that most dark matter is non-baryonic, which means we don't know what it's made of.
Interestingly, the baryon entropy ratio required for the right amount of helium corresponds to
\Omega_b \approx 0.2. Here \Omega_b is the ratio of the baryon density to a “density parameter” determined by the Hubble constant: \Omega_b = \rho_b/\rho_c = 8\pi G \rho_b/3H_o^2
\Omega_b \approx 0.2 closes dynamic mass estimates of large galaxies and clusters [see eg [20, 21]]. In standard cosmology this closure is sought to be achieved by taking recourse to non-baryonic cold dark matter. Thus in a linearly scaling cosmology, there would be no need of non-baryonic cold dark matter to account for large scale galactic flows.
Garth said:The conclusion that most of the DM is non-baryonic is theory dependent, i.e. it is dependent on a Friedmann model of the expansion of the universe in the first three minutes. In the radiation dominated era R(t) \propto t^{1/2}.
However the strictly linearly expanding model R(t) \propto t appears to produce just about the right amount of baryonic matter to account for nearly all of DM. A Concordant “Freely Coasting” Cosmology
Garth
That could well be right, it depends on what form the baryonic DM is in today.Parlyne said:I was under the impression that, regardless of cosmological models, baryonic dark matter would lead to the wrong kind of structure for galactic and cluster halos, due to EM interactions.
Garth said:That could well be right, it depends on what form the baryonic DM is in today.
IMBH's, for example, would interact gravitationally and not through EM interactions.
If the DM is baryonic I would expect it to consist of about 50% IMBHs, the remnants of an era of PopIII stars, and ~ 50% WHIM and cold gas.
At high z there would be a longer cosmological age than in the standard model during which the large structure might form.
Garth
And therefore we can invent non-baryonic DM with just the right properties? I'll believe it when the DM particle is discovered in the laboratory and found to have just those properties!Parlyne said:My worry was less about large scale structure and more about fitting the results from galactic rotation curves and gravitational lensing. EM interactions provide a way for matter to radiate energy and angular momentum, which should lead to smaller halos.
Perhaps they have been: http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6TVD-3XXDVDB-69&_coverDate=11%2F30%2F1996&_alid=502540181&_rdoc=1&_fmt=&_orig=search&_qd=1&_cdi=5532&_sort=d&view=c&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=d6b67ef1b62c0c014565db84cbac3a05.Also, if IMBHs were so prevalent as to account for 50% of dark matter, shouldn't we be able to see lensing due to some of them?
Garth said:And therefore we can invent non-baryonic DM with just the right properties? I'll believe it when the DM particle is discovered in the laboratory and found to have just those properties!
The conclusion that most of the DM is non-baryonic is theory dependent, i.e. it is dependent on a Friedmann model of the expansion of the universe in the first three minutes. In the radiation dominated era .
mathman said:An additional observation in favor of the current estimation of baryonic matter (about 4%) is the ratio of H1 to H2 in the universe, as well as other ratios of nuclides formed right after the big bang.
