Data analysis: 2D Surface fitting from raw data
2 replies · 6K views
lepatterso
Hey everybody
I've got a question for the programming savvy. I'm generating data which can generally be described by..
f(x,y) = Ʃn(an * xn)*Ʃn(bn * yn)
Basically what I'm looking at is a data set which shows a surface which looks like about 1/4th of a wonky bowl.
My trouble is that I need to calculate derivatives of f wRT x&y, and do some mathematical magic. To do that, I need to first generate f(x,y) from my raw data. So far, I've always used a canned package like Mathematica or MATLAB to generate that function, but this time I've got to build it from scratch. (Those licenses are expensive!)
Does anyone have any good examples of a fitting routine worked out for a 2d surface? I'm working in python, and am relatively new to no training wheels scientific computing.
Thanks!
If you have some confidence that your model f(x,y) is good then it isn't too difficult to fit a multivariate polynomial to your data without needing Mathematica.
Your goal is to minimize the square of the error between your observed and predicted z values.
To minimize a square you differentiate the square, set equal to zero and solve for the variables.
Suppose a simplified example where I am going to generate some data points {x,y,2x^2+3y+5} and then pretend I haven't seen that 2,3 or 5: {{3, -3, 14}, {-4, -3, 28}, {-3, -5, 8}, {2, 2, 19}, {-5, -5, 40}}
You want to minimize the sum of (zi - (a xi^2+b yi+c))^2.
Your xi,yi and zi are now constants, your variables are a,b,c.
To differentiate (zi - (a xi^2+b yi+c))^2 with respect to a gives 2(zi - (a xi^2+b yi+c))(-xi^2) and similarly for b and c.
Thus you want to solve
{0 == Sum(2 (zi - (a xi^2 + b yi + c)) (-xi^2)),
0 == Sum(2 (zi - (a xi^2 + b yi + c)) (-yi)),
0 == Sum(2 (zi - (a xi^2 + b yi + c)) (-1))}
where you sum over all your {xi,yi,zi}
That partially simplifies to
{0 == -8(19-4 a-2 b-c)-32(28-16 a+3 b-c)-18(14-9 a+3 b-c)-50(40-25 a+5 b-c)-18(8-9 a+5 b-c),
0 == -4(19-4 a-2 b-c)+6(28-16 a+3 b-c)+6 (14-9 a+3 b-c)+10(40-25 a+5 b-c)+10(8-9 a+5 b-c),
0 == -2(19-4 a-2 b-c)-2(28-16 a+3 b-c)-2 (14-9 a+3 b-c)-2(40-25 a+5 b-c)-2(8-9 a+5 b-c)}
which simplifies to
{0 == -3444 + 2118 a - 474 b + 126 c,
0 == 656 - 474 a + 144 b - 28 c,
0 == -218 + 126 a - 28 b + 10 c}
for the given data set.
Notice that these are n linear equations in n unknowns. That makes solving easy.
Solving that gives a==2, b==3, c==5 which were exactly the coefficients I used to generate the data set in the beginning and then waited to see if they would correctly reappear.
Check every detail of this carefully to make certain I have not made any errors.
If you study this for a while and remember some of your calculus and try this on a few examples where you know what the answer should be so you can flush out any errors or misunderstandings then you should be able to do multivariate polynomial regression on your data without needing Mathematica. In the process you may gain a deeper understanding of why regression works.
I urge you to not think that if a cubic polynomial sort of fit the data then a tenth degree polynomial must be better. But this has gone on long enough.
You could later consider trying Reduce, Maxima, Axiom, Sage or any of the other available "free" computer algebra systems. But you pay for those in trying to figure out where to get them, how to install them, how to use them, where to find people who can help answer questions, etc.
Bill's lesson looks good.
But, if you want to start taking advantage of popular algorithms in python, you may want to familiarize yourself with scipy and other packages.
