gracy
- 2,486
- 83
according to De Brogli wavelength equation not every thing has a wavelength instead everything that moves has a wavelength right?
what is zero point energy?Shyan said:That's right but not applicable. Because nothing is not moving in QM. There is always a motion due to zero point energy coming from Heisenberg's uncertainty principle. So every particle has a De-Broglie wavelength!
Also you should be ready to farewell [itex]\vec p=m \vec v[/itex] when you start learning QM.
bhobba said:Well you actually hit on a huge problem with the De-Broglie hypothesis.
One can always jump to a frame where the particle is at rest and then issues arise such as infinite phase velocity.
Its really just a way station to the correct quantum theory and was consigned to the dustbin of history once that was developed.
That said its interesting to analyse it in light of the correct theory:
http://www.gauge-institute.org/wave-particle/deBroglieP.pdf
Thanks
Bill
Consider the uncertainty relation [itex]\Delta p \Delta x \geq \frac{\hbar}{2}[/itex] where [itex]\Delta p[/itex] and [itex]\Delta x[/itex] are uncertainties in particles momentum and position. We always have some vague knowledge of where the particle is. The least we can say is that its in the laboratory. So we're always confining the particle in a finite region of space. But that means [itex]\Delta x[/itex] is finite and so [itex]\Delta p[/itex] can't be zero too which means there is always some momentum associated to the particle.gracy said:what is zero point energy?
Shyan said:I don't think we're allowed to say that.
PhilDSP said:That, just like many other seemingly explicable things in QM, may not fit comfortably with our intuitive notions. Feynman had some relevant things to say in that regard.
bhobba said:This issue has been discussed a number of times on this forum eg:
https://www.physicsforums.com/threads/de-broglie-theory-and-relativity.757718/
No need to rehash it here.
Thanks
Bill
ok I am just curious. So because p=mv, and wavelength=h/p, for wavelength to be noticable, p must be small. So, to make momentum small, you can make mass a very small number so lamda is noticable. Ok, so ccould you make velocity extremely small to achieve the same effect? I mean, can u make a baseball go at like 10^-35 m/s so that in the end you generate 10nm as the wavelength?Shyan said:That's right but not applicable. Because nothing is not moving in QM. There is always a motion due to zero point energy coming from Heisenberg's uncertainty principle. So every particle has a De-Broglie wavelength!
Also you should be ready to farewell [x] \vec p=m \vec v [/itex] w
why p=mv not applicable in quantum mechanics and what is then alternative of momentum in quantum mechanics?Shyan said:That's right but not applicable. Because nothing is not moving in QM. There is always a motion due to zero point energy coming from Heisenberg's uncertainty principle. So every particle has a De-Broglie wavelength!
gracy said:ok I am just curious. So because p=mv, and wavelength=h/p, for wavelength to be noticable, p must be small. So, to make momentum small, you can make mass a very small number so lamda is noticable. Ok, so ccould you make velocity extremely small to achieve the same effect? I mean, can u make a baseball go at like 10^-35 m/s so that in the end you generate 10nm as the wavelength?
gracy said:why p=mv not applicable in quantum mechanics and what is then alternative of momentum in quantum mechanics?
