Can anyone Explain why a glass tips over when pushed from the top?
The discussion focuses on the mechanics of a glass tipping over when pushed from the top. It establishes that the height of the applied force affects the torque exerted on the glass, with higher forces resulting in greater torque. The key conclusion is that tipping occurs when the applied torque exceeds the gravitational torque acting on the glass. The coefficient of friction, which is 0.30 in this case, plays a crucial role in determining whether the glass will slip or tip under the applied force.
  • Understanding of torque and its calculation
  • Knowledge of static friction and its coefficient
  • Basic principles of physics related to force and motion
  • Familiarity with the concept of equilibrium in rigid bodies
  • Study the calculation of torque in rigid body mechanics
  • Learn about the effects of static friction on motion
  • Explore the principles of equilibrium and stability in physics
  • Investigate real-world applications of these principles in engineering
Students studying physics, particularly those interested in mechanics, as well as educators and anyone seeking to understand the principles of forces and motion in everyday objects.
linuxux
A glass has a height of 10 cm, and a diameter of 2 cm, it weight 300g and a coefficient of friction equal to .30 exists. Will it slip or tip?
Im almost certain there are no calculations informed since i have been hard pressed to find equations relating height and friction. But i did test this theory my self on a glass and it did tip. Is the reason it tips because the farther away you are from the base, the more perpendicular is the applied force in respect to the base, because is you push from the bottom of the glass all the force is against the friction. Is this right?
It's certainly true that the higher up the force is applied, the more torque it exerts. Whether it tips or not depends on whether the applied torque is greater than the torque due to gravity.
Assume for the moment that the glass doesn't slip. What applied force is required to overcome gravity? Would a force of that magnitude be enough to overcome static friction?
9K
15K
