Decrease in Laser Power: Why Is It Happening?
  • Context: High School
  • Thread starter Thread starter nordmoon
    decreasing Laser Power
The discussion centers on the decrease in laser power observed in laser diodes, specifically noting a 10% reduction over a day. It highlights the importance of using a proper driver with a temperature controller to maintain stable diode performance, as laser diodes are sensitive to temperature fluctuations. The conversation also references commercial temperature controllers available from Thorlabs, which are suitable for specific diode mounts. The lack of a proper driver in the user's setup is identified as a potential cause for the observed power decrease.
  • Understanding of laser diode technology
  • Knowledge of temperature control systems for electronics
  • Familiarity with laser power measurement techniques
  • Experience with electronic driver circuits
  • Research "laser diode temperature control systems"
  • Learn about "Thorlabs temperature controllers" and their specifications
  • Investigate "proper laser diode driver circuits"
  • Explore "laser power stability techniques" in diode applications
Engineers, researchers, and hobbyists working with laser diodes, particularly those interested in optimizing laser performance and stability through proper electronic control methods.
nordmoon
Hi, So I am working with measurements using a laser. What I have noticed is that the power of the laser decreases from the time we start the laser until maybe an hour later.
Today I noticed it has decreased 10%, from yesterday, which I think sounds like a lot.
Does the laser have to warm up and become stable Before operation? The laser is a laser diode.
Science news on Phys.org
How is the temperature of the diode controlled? I.e,. are you using a "proper" driver or are you just driving it with a normal current source?
Laser diodes are sensitive to temperature which is why "proper" drive electronics includes a temperature controller.
Ok I see, that makes sense. I forgot about the temperature sensitivity. As far as I can see it only have a power source and pulse generator. No, there is no 'proper' driver. How would a temperature controller look like? What would it consist of?
Commerical versions look like this
https://www.thorlabs.com/navigation.cfm?guide_id=2107
However, these will only work if your diode is an a mount which can be used with a temperature controller.
(btw, I am not an expert in this area; but I do use laser diodes from time to time)
