Defination of E D and P fields
  • Context: Graduate
  • Thread starter Thread starter omri3012
    Fields
The discussion centers on the relationship between the electric field (E), electric displacement field (D), and polarization density (P) in electrostatics. E represents the electric field in free space, while D accounts for the electric field within matter, defined by the constitutive relation D = εE. P is identified as the dipole moment per unit volume, contributing to D in response to E. The conversation highlights the complexities of these definitions, particularly in non-linear or anisotropic materials, and references key texts for further understanding.
  • Understanding of electrostatics and Maxwell's equations
  • Familiarity with the concepts of electric field (E), electric displacement field (D), and polarization density (P)
  • Knowledge of linear and non-linear dielectric materials
  • Basic principles of charge conservation in electrostatics
  • Study the constitutive relations in dielectric materials, specifically D = εE
  • Explore the implications of polarization in non-linear and anisotropic media
  • Review the definitions and applications of the polarization magnetization tensor
  • Investigate advanced texts such as "Molecular Quantum Electrodynamics" by D. P. Craig and T. Thirunamachandran
Physicists, electrical engineers, and students studying electrostatics, particularly those interested in the behavior of electric fields in various materials and the mathematical formulations of polarization.
omri3012
Hallo everyone,
in electrostatic we have a linear realation between E D and P, i do understand that P
is related to the polaryzation density but what about E and D? which of those represent the
overall field?
'E' is the electric field in free space, 'D' is the electric field within ponderable matter. Relating 'E' and 'D' requires a constitutive relation (for example, D = eE), and 'P' is taken to be the contribution to 'D' from the matter responding to 'E'.
It can be a little confusing...
thanks for your reply.
from your answer i don't understand what the diffrence between D and P?
P is the dipole moment per unit volume.
E is the electric field. Its field lines start and end on all charges, including the charges in the dipoles that make up P.
D is like E, except that the lines of D only start and end on free charges, and not on the charges that make up P.
'D' is the *total* electric field within a material, 'P' is that portion that comes from the material in response to the 'E' field.
For simple linear materials:
D = eE
P = D - e_0E
That is at best an approximation for substances which can be thought to consist of independent molecules or atoms.
The polarization derives fundamentally from the conservation of charge of the substance. Hence it is possible to introduce the polarization magnetization tensor whose divergence yields the charge current vector. This tensor is not uniquely defined. E.g. in optics one sets M=0 and P=int j dt.
The relation is somewhat analogous to the relation of the magnetic vector potential to the electromagnetic field tensor.
What are examples of substances where this approximation does not hold true?
I meant that the electrons are strictly confined to these atoms and molecules. There are many examples of substances where the electrons are delocalized, e.g. semicoductors, metals.
Hi,
does anybody know any textbook or article that treats this question of polarization in detail?
1) What is the correct definition of polarization?
Standard textbooks say that P is the density of dipole moment. But referred to what? Dipole moment of a charged body depends on the reference point.
2) And then, how to prove the relation div P = -rho?
Textbooks say that the polarized body with density P creates the same potential as a body with no polarization at all but with the charge density of -div P. So what we have is in fact equality between two integrals. But we know very well that from this we can not always infer the equality of integrands, right? As a contra-example, the dipole moment of the body with respect to the origin of coordinates is
<br /> \boldsymbol p = \int \boldsymbol r \rho dV = \int \boldsymbol P dV<br />
Clearly the integrands are not the same.
And furthermore, this argument with potential works only in static situation; but we use the Maxwell's equations with polarization for optic and radiative phenomena...
A definition of the polarization and magnetization which goes beyond the dipole approximation and which is especially suitable for the discussion of molecular systems can be found e.g. in these lecture notes of Claude Cohen Tannoudji (in French):
http://www.phys.ens.fr/cours/college-de-france/1986-87/cours9/cours.pdf
Or in Molecular Quantum Electrodynamics of D. P. Craig,T. Thirunamachandran; Dover Publications.
These definitions can be taken over to solid systems only if the solid can be thought to be consisting of appreciably non-overlapping entities to which the above decomposition can be applied.
When this is not the case, one usually sets M=0 and P=\int_{-\infty}^t j dt, see, e.g., Electrodynamics of continuous media, Lev Davídovich Landau,Evgenij M. Lifšic.
Thank you DrDu, I will read it carefully. But on the first glance, the method of Tannoudji is quite suspicious - why do we need to use artificial line of dipoles and Fourier's transformation? That is not very convincing. Simple relations should reflect simple physical picture. Besides, when we introduce the dipole line instead of the charge at the end of {\boldsymbol r}_{\alpha}, we manufacture a new charge -q_\alpha} at the beginning of {\boldsymbol r}_{\alpha}, but it was not there before...
Hmmm, all the textbooks I've read call D an artificial mathematical quantity. E is the real physical macroscopic electric field in the medium. I.e. the real electric field will be rapidly fluctuating on the atomic scale, but if you average out the short distance fluctuations, you get the so-called coarse grained macroscopic electric field, which is the E field.
The E field contains contributions from induced dipole moments. When doing computations, you don't a priori know what the dipole moment density P is. It is possible to subtract this contribution from E and then you obtain the D field. The usual arguments then lead to equations like D = epsilon E, and
Div D = rho_free
which together with boundary conditions allow you to compute the electric field in dielectric media.
The introduction of D and P is independent from any coarse graining or macroscopic averaging.
This obviously does not mean that it is not usefull to consider coarse grained P and D, but that these can be calculated from the microscopic quantities, see e.g. S. Adler, Phys Rev (1962) vol 126, pp. 413.
In fact, P it is only a reformulation of charge conservation, see e.g.:
http://arxiv.org/abs/physics/9907046
or R.G. Woolley, Int J Quantum Chem, (1999), Vol 74., pp. 531, who also discusses the multipolar hamiltonian which is quite a standard at least in molecular physics.
Especially, polarization does not equal the dipole moment density in general and Jano L. realized quite correctly that the latter approximation is ambiguous as it depends on the choice of the reference points.
Ok omri, are there still open questions then?
The E field is still the true E field (eventually one considers only some average values of it), while the polarization is an alternative way to describe the electric charges and currents of the medium.
Count Iblis,
that most textbooks say D and H are secondary is true, however it is not very clear why. In the matter, there is no way to measure the fields E and B, so all of these four quantities get the same reality. Furthermore, EDBH still survives everywhere, equations look nice and also Maxwell used them. If I remember correctly, he had an idea that even the free charges are just the result of nonuniform polarization of vacuum, described by D: \rho_{free} = div D.
When I read the last part of your message, I recalled an amusing result: did you know that in a linear dielectric D = \epsilon E implies \rho = \epsilon_r \rho, so that \rho = 0 always? The whole argument have a meaning just for nonlinear or anisotropic media...
  • · Replies 16 ·
