Definite Integral limit problems
12 replies · 3K views
SALAAH_BEDDIAF
[tex]\int_0^{2\pi} \frac{1}{25cos^2(t) + 9sin^2(t)}dt[/tex]
Substituted the variables twice and got the upper and lower boundaries to both be 0 (think i might have gone wrong there) [tex]\frac{1}{15} tan^{-1} \frac{3tan(t)}{5}[/tex] with upper and lower boundaries both being 0. I know the answer is [itex]2\pi/15[/itex] but I am not getting that answer, would it be my limits that are incorrect here?
We have no way of knowing if your boundaries were correct or not if you don't tell us what substitution you did. Write out all the steps you took and it will be a lot easier to spot where you went wrong.
Your work is confusing; you should try to write it better for your own sake.
It looks like you calculated the indefinite integral right, but why are you changing the limits of integration then back subbing at the end?
The whole purpose of changing limits of integration is so that you don't have to make back substitutes at the end.
Evaluate this at [tex]0, 2\pi[/tex]
You still get 0, but what should you do? What is 0 to 2pi?
But from the substitution, wouldn't the limit of [itex]2\pi[/itex] become 0? Both points give us a value of 0 as [itex]tan(0) = tan(2\pi)[/itex]
First calculate the indefinite integral. Note that
[tex]\frac{1}{25 \cos^2 x+9 \sin^2 x}=\frac{1}{9 + 16 \cos^2 x}=\frac{1}{9} \cdot \frac{1}{1+\left(\frac{4}{3} \cos x \right)^2}.[/tex]
A much better way, IMO, is to factor out the cos^2(x) i.e
$$\frac{\sec^2x}{25+9\tan^2x}dx$$
A very obvious substitution can be used now.
They already have the indefinite integral, if you look at their work they have what you wrote. What they need to understand is what a net signed area is, and why the integral from 0 to 2pi is obviously zero.
If they want the total area, then they need to find that.
OP, while subbing if you change the limits of integration, then you don't need to make a back sub at the end. Does that make sense?
The integrand is positive over the entire interval of integration. There's no cancellation occurring leading to a vanishing result. This paradox has nothing to do with net signed area.
[tex]\frac{1}{15} tan^{-1} \frac{3tan(t)}{5}[/tex] is positive from 0 to 2pi??
Is that the integrand?
Haha, you're a clever one. I got so caught up in it. :/
The function is positive so the integral must be increasing and continuous. There is a problem with the indefinite integral, it only holds for -pi/2<=t<=pi/2.
To fix it we can either break the integral up or make sure the integral is increasing and continuous.
Break it up
$$\int_0^{2\pi}\frac{\mathrm{d}t}{25\cos^2(t)+9\sin^2(t)}=4\int_0^{\pi/2}\frac{\mathrm{d}t}{25\cos^2(t)+9\sin^2(t)}=4\left[\frac{1}{15}\tan^{-1}\left(\frac{3}{5}\tan(t)\right)\right]_{t=0}^{t=(\pi/2)^-}$$
It turns out that
$$\int_0^{x}\frac{\mathrm{d}t}{25\cos^2(t)+9\sin^2(t)}=\frac{1}{15}\tan^{-1}\left(\frac{3}{5}\tan(x)\right)\\\text{is valid when}\\-\frac{\pi}{2}<x<\frac{\pi}{2}$$
