Definite integral of complex gaussial-like function
The discussion revolves around the evaluation of a complex definite integral involving a Gaussian-like function. Participants explore various methods for solving the integral, which includes multiple variables and real constants, and express concerns about the practicality of analytical solutions versus numerical methods.
  • One participant presents the integral and seeks pointers for a solution, noting that while it is solvable on paper, practical realization is challenging.
  • Another participant suggests that if the integral can be solved in the general case, it should also be solvable in a simpler case where several constants are set to zero.
  • Some participants propose that the best approach, given finite integration limits, may involve the error function.
  • There is a suggestion that the integral can be approached as an iterated integral with a specific form, but the squared exponent complicates matters.
  • A participant restates the problem in terms of a different expression and requests hints for a solution, emphasizing the need for numerical computation.
  • One participant expresses skepticism about the feasibility of evaluating the integral numerically, while another provides a Mathematica example to demonstrate numerical integration.
  • Concerns are raised about the practicality of analytical solutions, with some participants arguing that they may be messy and computationally costly.
  • There is a discussion about the possibility of using the multinomial theorem to expand the exponential function, but participants note that this approach may also be complex.
  • Some participants advocate for direct numerical integration as a more efficient method, especially if the integral needs to be computed many times.
  • One participant mentions the potential for using Mathematica's interpolation or fitting functions to create an analytic approximation for practical use.
  • There is a dialogue about the context in which the integral needs to be computed, with questions about whether it involves multiple actuaries or a single program performing numerous calculations.
Participants express differing opinions on the feasibility and efficiency of analytical versus numerical methods for solving the integral. While some advocate for direct numerical integration, others explore the potential for analytical solutions, leading to an unresolved discussion on the best approach.
Participants note that the integral's complexity may lead to cumbersome analytical solutions involving special functions or infinite series, which could be more time-consuming than direct numerical integration.
spyke2050
so the question is how to solve the next:
∫...∫exp(-(a+b*x1+c*x1*x4+d*x3*x4+f*x2*x3*x4)^2)dx1dx2dx3dx4
a,b,c,d,f - real constants;
x1,x2,x3,x4 - real variables;
borders of integration are finite, let say for x1 it is [x1a,x1b] and so on for the rest of them;
i'v tried to solve it in terms of tensor vector multiplication. it solvable on paper but it's practical realization is rather impossible.
so i would be appreciate for any pointers or directions for solution.
thanks in advance
thanks in advance
If you could solve this integral in the general case, a fortiori, you could solve it in the much simpler case a=0, b=1, c=0, d=0, f=0.
By the way, could you solve it in the case a=0, b=1, c=0, d=0, f=0 ?
Try it and see where is the hitch !
As long as the integration limits are finite the best you can hope for is something involving the error function.
I agree with jjacquelin. Your notation indicates you are trying to perform an iterated integral. With respect to each variable x, the integral has the form [itex]\int e^{p + qx} dx[/itex] where [itex]p[/itex] and [itex]q[/itex] are constants. Can you not do that integration?
The expression in the exponent is squared, so it looks more like a Gaussian, not an exponential.
ok, let me restate a problem a bit:
[itex]\int[/itex]...[itex]\int[/itex]exp([itex]\sum_{i,j,k}[/itex]A[itex]_{i,j,k}[/itex]x[itex]_{i}[/itex]x[itex]_{j}[/itex]x[itex]_{k}[/itex])dx[itex]_{i}[/itex]dx[itex]_{j}[/itex]dx[itex]_{k}[/itex]
what whould be the solution to above definite integral?
solution is not required to be exact.
i would be appreciated for any hints for solution.
i went through a few already but thay are not satisfactory in terms of numerical computation.
thanks again
I fail to see why you would have any problems evaluating the integral numerically to any reasonable level of accuracy. Here's an example in Mathematica:
Code:
a = 2;
b = -3;
c = -4;
d = 2.5;
e = 7.6;
f = -3.2;
x1a = 2;
x1b = 7;
x2a = 3;
x2b = 17;
x3a = -4;
x3b = 12;
x4a = -22;
x4b = 22;
NIntegrate[
 Exp[-(a + b x1 + c x1 x4 + d x3 x4 + f x2 x3 x4)^2], {x1, x1a,
  x1b}, {x2, x2a, x2b}, {x3, x3a, x3b}, {x4, x4a, x4b},
 PrecisionGoal -> 6, AccuracyGoal -> 6]
Code:
a = 2;
b = -3;
c = -4;
d = 2.5;
e = 7.6;
f = -3.2;
x1a = 2;
x1b = 7;
x2a = 3;
x2b = 17;
x3a = -4;
x3b = 12;
x4a = -22;
x4b = 22;
NIntegrate[
I need analitical solution for that integral. Not just numerical evaluation of that integral. I got some solutions. But the thing is that those solutions are absolutely impractical for numerical computation.
Then in an act of utter desperation I would investigate the possibility of expanding the exponential function using the multinomial theorem:
[tex]\overset{\text{n-folded}}{\int\cdots\int}\exp(P(x_n)^2)d^nx=\sum_{k=0}^{\infty}\overset{\text{n-folded}}{\int\cdots\int}\frac{P(x_n)^{2k}}{k!}d^nx[/tex]
Actually I initiallly tried this when you first posted the thread but got dizzy with the indicies. Maybe though you could do better.
that solution was my first choice. but it's too messy and computationally costly.
but thakns anyway
You sure about that? Won't reduce down huh? I mean comet coming and all, just gotta' have it to save the world even if it's messy. Just no way right? Even on one of those fast parallel-processing computers?
I fully agree with jackmell opinion.
What can we expect from analytical resolution for a so awful integral ? Recourse to arduous special functions ? Huge formula, even in terms of infinite series ?
Even if it was possible, this would be "messy and computationally costly" as spyke2050 complains.
The direct numerical integration, as proposed by jackmell, is far to be the less messy and the less costly way.
If I may add to that, we can also compute a very good "analytic" approximation to the numeric solution for example using Mathematica's "Interpolation" or "Fit" or other functions. This will produce a function f as a function of one or more variables you wish to select, which can then be differentiated, integrated, and used for all practical purposes, as a very good subsittiute for the actual analytic solution.
well the thing is that it should be computed from thousands to millions times. so matematica isn't the solution i hoped for.
ok guys thank you for help
best regards
If it should be computed millions times, clearly the most economic method is the direct numerical integration, because it avoids a lot of intermediate steps and/or series and/or special functions, which respective numerical computation are often more time consuming that the direct numerical integration of the initial function.
really? it's kind of surprising. but ok, i'll try to do so then.
thanks
That isn a clear description of the scenario. Are you talking about a thousand actuaries doing this calculation on their PC 10 times a day? Or are you talking about one computer program doing this calculation thosands of times and hopefully completing its task in 5 minutes? Assuming someone will pay for a thousand Mathematic licenses, Mathematicia is a sufficient tool for the former problem.
it's one computer program should all those computations.
