kgm2s-2
- 5
We all know that the definition for work is
W = ∫F.ds
Why can't it be
W = ∫s.dF?
W = ∫F.ds
Why can't it be
W = ∫s.dF?
The definition of mechanical work is established as W = ∫F.ds, where W represents work, F is the force vector, and ds is the displacement vector. The discussion highlights that using W = ∫s.dF lacks physical meaning, as it implies displacements cause forces, contrary to the established principle that forces cause displacements. Additionally, it is noted that in one-dimensional contexts, integration by parts can yield W = Fx - ∫x dF, which avoids the issues presented by the alternative definition. The concept of work is crucial in understanding energy transfer, particularly in conservative forces like gravity.
PREREQUISITESPhysics students, mechanical engineers, and anyone interested in the principles of work and energy transfer in mechanical systems.
kgm2s-2 said:We all know that the definition for work is
W = ∫F.ds
Why can't it be
W = ∫s.dF?
Yes, actually that's what it would mean if you did the integration by parts thing.chrisbaird said:Do you see the problem? What is s(F1) supposed to mean physically? The displacement applied at the certain force strength F1?
I don't see how the cause-and-effect relationship is relevant. And in any case, it is often possible to view displacements as causing forces. For example, if I have a mass on a spring and I displace it, that causes a different force to exist.chrisbaird said:This doesn't mean anything. Forces causes displacements to do work. Displacements don't cause the forces.
kgm2s-2 said:Why can't it be
W = ∫s.dF?
But W=Fx-\int x dF (derived using integration by parts, evaluated at the beginning and end of the displacement) doesn't have this problem.AlephZero said:That definition would mean that if F was constant, dF would be 0 and W would be 0 for any value of s.
That doesn't answer the OP's question. The OP wants to know *why* work is defined a certain way.AlephZero said:That isn't how "mechanical work" is defined.
kgm2s-2 said:It seems like it is because ∫s.dF doesn't have a physical meaning so we can't use it to find work done?
So for a force vs displacement graph, ∫F.ds is talking about the area under the curve and the x-axis while ∫s.dF is talking about the area bounded by the curve and the y-axis. Hence ∫s.dF does not have a physical meaning?
