What is the Definition of a Candela?
  • Context: High School
  • Thread starter Thread starter SamRoss
    Definition
The definition of a candela is the luminous intensity of a source emitting monochromatic radiation at a frequency of 540×1012 hertz, with a radiant intensity of 1/683 watt per steradian. Luminous intensity is measured in candelas (cd), while radiant intensity is measured in watts per steradian (W/sr), highlighting their non-commensurate nature. The distinction lies in human perception; luminous intensity accounts for how brightness is perceived by the human eye, whereas radiant intensity measures power density. The luminosity function, which varies with frequency, is essential for converting radiant intensity to luminous intensity.
  • Understanding of luminous intensity and radiant intensity
  • Familiarity with the concept of the luminosity function
  • Basic knowledge of photometry and radiometry
  • Awareness of the SI unit system and its dimensions
  • Research the differences between photometric and radiometric measurements
  • Study the implications of the luminosity function on light perception
  • Explore the historical evolution of the definition of the candela
  • Learn about the calibration of photometric detectors
Students of physics, optical engineers, lighting designers, and anyone interested in the principles of light measurement and human visual perception.
SamRoss
TL;DR
Trying to wrap my head around the definition of a candela.
I'm trying to wrap my head around the definition of a candela:
"The candela is the luminous intensity, in a given direction, of a source that emits monochromatic radiation of frequency 540×10^12 hertz and that has a radiant intensity in that direction of 1/683 watt per steradian."
I'm aware that this definition is from 1979 and there is a new definition which went into effect in 2019 but I would still prefer to work with the 1979 definition. Here's what I think I get so far...
- Watts are joules (a measure of energy) per second.
- Radiant intensity is watts per steradian - so joules per second per steradian.
- Luminous intensity is also measured in watts per steradian, but it does not take into account all energy (per second per steradian), only energy from light of frequencies which are visibile to the human eye and it is weighted based on how well the human eye responds to those frequencies. For this reason, the luminous intensity is found by taking the radiant intesity of a certain frequency and multiplying it by some weight (which could be zero if the frequency is out of the visible range). For light of more than one frequency, the weight would be replaced by a luminosity function which is integrated over all frequencies.
Procedure: So to define a candela, we start with a green light (specifically, light with a frequency of 540×10^12 hertz), then measure how much energy is coming out of that light per second per steradian.
Now, I know I must be wrong about something because with my "understanding" as I've outlined it above, the definition of a candela seems redundant. If radiant intensity and luminous intensity are both measured in watts per steradian, then why can't the definition just be "The candela is the radiant intensity of a source that emits monochromatic radiation of frequency 540×10^12 hertz" which happens to be 1/683 watt per steradian. I am also implicitly assuming here that since the frequency of light used in the definition is a frequency that is perceived very well by the human eye, the radiant intensity and luminous intensity should be the same (which is why I used "radiant intensity" in my definition and did not mention multiplying this by the luminosity function in my procedure). Is that also incorrect?
Science news on Phys.org
SamRoss said:
Summary:: Trying to wrap my head around the definition of a candela.
No. Radiant intensity is measured in W/sr. Luminous intensity is measured in cd. They are non commensurate units.
The difference between the two is human perception. Two sources have equal luminous intensity if they visually appear the same brightness (all other things equal). Two sources have equal radiant intensity if they provide the same power density (all other things being equal).
Is it correct to say luminous intensity = radiant intensity x luminosity function?
Yes, but note that the luminosity function is not dimensionless in the SI unit system.
Alright, so that's one piece of the puzzle. I was assuming the luminosity function was dimensionless. So I suppose its dimensions are cd sr W^-1 ?
Yes, exactly.
Dale said:
Yes, exactly.
Okay, so I get that the units are not the same. There's still something that's bothering me, though. If the light is of only one frequency and the radiant intensity is within the limits of what the eye can handle, wouldn't the "weight" that we multiply the radiant intensity by to get the luminous intensity just be 1? In other words, isn't all of that light getting through to the observer?
No, the weight is ##683\text{ cd sr/W}## at ## 540\text{ THz}##, and it varies from there.
The radiant intensity is the power detected by a perfectly color unbiased calibrated detector. The photometric and radiometric detector will agree (in Watts/whatever) if presented with only the magic green light (is it 556nm? I don't care} . Otherwise the eyeball is considered attenuated by insufficient sensitivity.
Right. Okay, I think I'm seeing where my thinking went off the rails. If we have light of many different frequencies then the luminosity function is sort of a filter which picks out the frequencies we can see and attaches different weights to them. I was confused about the need for the definition of candela to use the words "luminous intensity" at the beginning, thus implying the luminosity function, if the use of the function is so trivial for light of one color (I mistakenly said the weight would be 1 but a weight of 683 is just as trivial; the point is that the whole apparatus of a filter seems to be overkill when there's only one color to begin with). I suppose the wording is necessary simply because we want the measurement to be in units of candelas. Now I see that your earlier statement about the incommensurability of the units for luminous and radiant intensities is a key point. Once again, Dale, I owe you a debt of gratitude. Thank you.
You are more than welcome! It is always enjoyable to see someone pick up a concept quickly like this
  • · Replies 25 ·
  • · Replies 17 ·
15K
  • · Replies 0 ·
