Definitions and properties of limits (handwriting attached)
The discussion revolves around the definitions and properties of limits in the context of calculus, specifically focusing on the relationship between differentials (dy and dx) and integrals. Participants explore the implications of these definitions for finding antiderivatives and the Fundamental Theorem of Calculus (FTC).
  • One participant seeks feedback on their proof that ∫ y' dx = ∫ dy, indicating a desire to understand the definitions involved.
  • Another participant asserts that if dy and dx are properly defined, the equality is clear for differentiable functions, but questions the utility of this proof for finding antiderivatives without bounds.
  • A later reply emphasizes that the proof does not establish anything substantive, as it merely involves changing notations and highlights the dependency of dy on dx.
  • One participant expresses confusion regarding the proper definitions of dy and dx, seeking clarification on their apparent relationship in integrals.
  • Another participant mentions the common practice in physics texts of treating dx/dy as a quotient, indicating a concern about understanding these concepts without oversimplification.
  • One participant explains that integrating dy alone is problematic without knowledge of the position, emphasizing the relationship between dy, dx, and the slope of the tangent line.
  • Another participant discusses the need to understand the change in area under a curve when deriving the FTC, suggesting that dy can be used in conjunction with dx under certain conditions.
Participants express differing views on the validity and usefulness of the proof presented, with some agreeing on the dependency of dy on dx while others question the clarity and implications of the definitions involved. The discussion remains unresolved regarding the proper interpretation and application of these concepts.
There are limitations in the definitions of dy and dx as they relate to the proof, and the discussion highlights the potential confusion arising from their treatment in different contexts. The relationship between these differentials and integrals is not fully settled, and assumptions about their definitions are not universally agreed upon.
tolove
Could someone look over this and see if I have any mistakes? I'm trying to show that
∫ y' dx = ∫ dy through definitions.
http://imgur.com/6zCHYo5
Thanks!
If dy and dx have been properly defined (which for some reason is a rare occurrence), then this equality is immediately apparent for differentiable functions. However, this is useless as a means to finding an antiderivative (which is what you're doing, since you have no bounds on your integral.)
Your proof is not much more than switching notations out. Even if it were a definite integral, dy is dependent on dx, so trying to evaluate the integral that way would be futile.
What you're saying is that "What you wrote has no problems, however it's a pointless exercise and proves nothing since all you're doing is changing notations around."
If that is so, then thank you! That's more or less what I was going for. These notations have been confusing me, but I think I've made sense of them.
Well... I'd say that it "makes sense" only if it were a definite integral.
And I wasn't complaining about the uselessness of the proof, so much as the impossibility of computing the integral on the RHS.
I hope you're not using this to "prove" FTC. If you are, you should consider the change of the area under the curve with upper bound x induced by moving delta x, then find the corresponding dA.
I think I'm only following you in pieces (I have a pretty awful understanding of the subject!)
"If dy and dx have been properly defined (which for some reason is a rare occurrence), then this equality is immediately apparent for differentiable functions."
What do you mean by properly defining dx and dy? And by apparent, do you simply mean that this is clear to see ∫ dy/dx dx = ∫ dy? I find it very unclear to simply to see that. Mathematically, just cancel out the dx, but physical equations can become hard to visualize for me sometimes, ∫ v' dt = ∫ dv.
"the change of the area under the curve with upper bound x induced by moving delta x, then find the corresponding dA."
I don't follow this either ;_;
The physics book I'm using breaks up dx/dy in equations regularly, and I'm try to not get into the habit of just viewing dy/dx as a quotient.
Suppose we have the graph of a function. Let us approximate its shape with vectors whose horizontal component is dx and vertical component is dy. Then, the derivative of the function gives us the number we need so that [tex]dx \cdot \frac{dy}{dx}=dy.[/tex] (Typically, y is dependent on x, so we can assume that dx is the same at every point.) Thus, dy is dependent on dx AND the slope of the tangent line at the point. Thus, integrating dy by itself doesn't make sense unless you know something about the position.
If you keep in mind this relationship, you can detach dy and dx freely for differentiable functions.
To derive FTC (for functions that are almost everywhere continuous), you need to see what happens to the change in area (dA) of the function [tex]A(x)= \int_a ^x f(t)dt[/tex] when we move a small amount dx. Here, you will see that you can use dy by itself, keeping in mind the associated dx.
  • · Replies 16 ·
