Deflection of a Perfect Strut Under Point Forces
  • Thread starter Thread starter dichotomy
    Deflection
The discussion revolves around the behavior of a perfect strut under the influence of two imaginary point forces acting at its centroid. Participants explore whether such a strut would bend laterally, considering ideal conditions that ignore practical limitations and material failure.
  • One participant questions whether the strut would bend laterally under two point forces at the centroid, arguing that these forces produce no moment or horizontal component to cause bending.
  • Another participant asserts that if any component of the load is perpendicular to the centroidal axis, bending would occur.
  • A different viewpoint suggests that in a perfect scenario with no applied moment or eccentricity, the strut should remain in perfect compression without buckling.
  • One participant emphasizes the importance of several factors, including end restraints, moment of inertia, unbraced length, and applied load, in determining the likelihood of lateral deflection and buckling.
  • It is noted that as the strut length increases, the section decreases, or the applied load increases, the strut becomes more likely to buckle and deflect laterally.
Participants express differing views on whether the strut would bend laterally under the specified conditions. There is no consensus, as some argue for the possibility of bending while others maintain that it would not occur under ideal conditions.
Participants highlight the need to consider various assumptions, such as end restraints and material properties, which may affect the outcome of the discussion. The lack of consensus on these assumptions contributes to the unresolved nature of the debate.
dichotomy
hello all, first post here so don't bite.
if a perfect strut was compressed by an 2 imaginary point forces acting exactly on its centroid, and ignoring outside effects, would it bend laterally, and why so? when I say perfect, i mean ignore all consequences of practicality, ie. the alignment is precise to the eg. atom, and the bar is of impeccable geometry along its length.
i was having a debate about this for at least 20 minutes with someone, and I saw no good reason why it should (ignoring material failure for the moment), since the point forces acting on the centroid produce no moment/horizontal component to cause the strut to bend in such a dramatic manner.
What? Be more clear. If one of the components of a load is perpendicular to the centroidal axis (beam, bar, slab, etc...), then there would be bending!.
In your perfect example, I guess there is no real reason for the column to buckle. You would then have to deal with compressive failure. If there is no moment at the ends or eccentricity to the load and the material is perfectly homogeneous, it should be in perfect compression. I had to take a quick look back in one of my books to make sure the Euler equation for buckling is derived assuming that there is an applied moment at the end of the column.
You have to know several different things before you can answer that question.
1) end restraints (it is common to assume that both ends are pinned or free to rotate)
2) moment of inertia of the section (about both axes)
3) unbraced length of the strut in compression
4) the amount of load applied
As the strut length gets longer, the section gets smaller, or the applied load gets larger, the strut will be more likely to buckle and deflect laterally. Assuming the section is sized appropriately, it will not buckle and will not deflect lateraly. :biggrin:
  • · Replies 30 ·
  • · Replies 69 ·
17K
  • · Replies 32 ·
  • · Replies 264 ·
33K
