- 3,378
Swamp Thing said:Assume that a device with a pointer is located close to ONE of the paths. After propagating further over a really long distance and time, the wave packet reaches a detection zone. Just before this happens, we can decide to switch the experiment between a setting where the pointer reveals the path information, to one where it can't. Depending on this decision, we se or don't see interference.
Now, does it matter how "macroscopic" the pointer device is? If it is just an atom or something, then it's plausible that it could give back the energy or whatever that it exchanged with the photon, and no one any the wiser. On the other hand, let's say the device is a photomultiplier tube, and the cascade of electrons should have reached the point of no return long before the wavepacket could reach the detection zone. What then? Can you put the toothpaste back in the tube even at this point? Or should we say that the cascade would be triggered nonlocally - or not triggered at all - depending on the scenario that exists in the detection zone at the last femtosecond? Would it make a difference whether or not the coherence length spans the PMT and the detection zone?
bhobba is right that for deriving the pointer states form decoherence, one usually needs a macroscopic number of degrees of freedom, However, if we are only talking about some aspects of the measurement, we can restrict our attention to just the system, or the system and a small part of the measurement apparautus often called an "ancilla", which can be a small quantum system. What matters is whether you can "reverse the interaction" between the ancilla and the system. If you can, then there is no collapse. If you cannot or do not want to control the ancilla enough to "reverse the interaction", then you can treat it as having collapsed the wave function. In this case, you typically do not observe the atom, so you can always delay the collapse. Collapse is only necessary when an observation is made, and a successive observation is made. An observation is when you get a definite outcome. Whether you have a definite outcome or not is subjective.
An example of an atom being used to cause collapse, provided we decide that we are not going to control the atom after it has interacted with the system is given in Fig. 1 of Zurek's http://arxiv.org/abs/quant-ph/0306072.
A related idea is the principle of deferred measurement.
http://en.wikipedia.org/wiki/Deferred_Measurement_Principle
http://www-bcf.usc.edu/~tbrun/Course/lecture07.pdf (p20)
