Delta/epsilon two variable limit
  • Thread starter Thread starter iRaid
    Limit Variable
The limit evaluation of the function $$\lim_{(x,y)\rightarrow (0,0)} \frac{5x^2y}{x^2+y^2}$$ concludes that the limit is 0. The discussion emphasizes the use of polar coordinates, where the transformation to $$r \to 0$$ simplifies the analysis. Participants agree that choosing $$\delta = \varepsilon / 5$$ effectively demonstrates that the limit approaches 0, as the conditions of the epsilon-delta definition of limits are satisfied. Alternative methods, such as direct substitution and bounding techniques, are also discussed but polar coordinates are highlighted as the most straightforward approach.
  • Understanding of multivariable calculus concepts, particularly limits.
  • Familiarity with the epsilon-delta definition of limits.
  • Knowledge of polar coordinates and their application in calculus.
  • Basic algebraic manipulation skills to handle rational functions.
  • Learn how to convert Cartesian coordinates to polar coordinates in calculus.
  • Study the epsilon-delta definition of limits in detail to solidify understanding.
  • Explore alternative methods for evaluating limits, such as bounding techniques.
  • Practice additional limit problems involving multivariable functions to enhance problem-solving skills.
Students in multivariable calculus, educators teaching calculus concepts, and anyone seeking to deepen their understanding of limit evaluations in multiple dimensions.
iRaid
In calculus 1, honestly, I never understood this as it just doesn't make sense. Now in multivariable calculus, it still doesn't make sense. After all these engineering, math, and science classes, I still cannot figure these problems out, and it pisses me off! I would appreciate it if someone could explain this example to me...
Evaluate
This is an example problem, the book does not explain this well at all. The answer they get is: You can choose ##\delta = \varepsilon /5## and conclude that the limit = 0.
I don't even see how they just (seemingly) magically conclude that.
Any help is appreciated.
Evaluate
Try expressing the variables in polar coordinates. ##(x,y)\to (0,0)## is the same as ##r\to 0##.
iRaid said:
In calculus 1, honestly, I never understood this as it just doesn't make sense. Now in multivariable calculus, it still doesn't make sense. ...
Evaluate
The definition of a limit would imply that the limit will be 0 if, for every small positive ε, there exists some δ such that |5xy2/(x2 + y2)| < ε whenever the distance from (x,y) to (0,0) is less than δ. We're can always ignore LARGE values of ε, so just assume ε < 1 (you'll see why).
If x2+y2 < δ2, you know that x2 <= (x2+y2) < δ2 < δ; the last inequality depends on δ < ε < 1. So if δ = ε/5, then 5x2 < 5δ = ε. And you know that y/(x2+y2) is sin(θ), whose absolute value is <= 1. That proves the absolute value of the entire fraction is smaller than ε.
No, ##\frac y {\sqrt{x^2+y^2}}=\sin\theta##.
So I can just change these functions into polar coordinates and solve that way?
Is this the best way to approach these problems?
There is no best way. What you do depends on the nature of the problem. In this problem the degree of the numerator is 3 and the denominator is 2, plus the ##x^2+y^2## in the denominator suggest trying polar coordinates. Try it.
This is also possible without polar co-ordinates. Start with the definition:
$$∀ε>0,∃δ>0 \space | \space 0<||(x,y)-(0,0)||<δ⇒|\frac{5x^2 y}{x^2+y^2}-0|<ε$$
Note that ##||(x,y)-(0,0)||<δ⇒|x|<δ∧ |y|<δ##.
By the triangle inequality:
##|\frac{5x^2 y}{x^2+y^2}-0|= \frac{5|x|^2 |y|}{|x^2+y^2|} ≤ \frac{5|x|^2 |y|}{|x|^2+|y|^2 } < \frac{5δ^3}{2δ^2} < \frac{5δ^3}{δ^2} = 5δ##
So we have:
##5δ ≤ ε ⇒ δ ≤ \frac{ε}{5}##
Therefore, by choosing ##δ ≤ \frac{ε}{5}, |\frac{5|x|^2 |y|}{|x^2+y^2|}-0|<ε##. Although you should try the polar co-ordinates as well as it is often a useful trick. Try proving the chosen ##\delta## does indeed satisfy the definition.
Perhaps simpler:
If ##x = 0## and ##y \neq 0##, then we have
$$\frac{5x^2y}{x^2+y^2} = 0$$
If ##x \neq 0## we may write
$$\frac{5x^2y}{x^2+y^2} = \frac{5y}{1 + y^2/x^2}$$
As ##y \rightarrow 0##, the numerator goes to zero. The denominator is at least ##1## for all ##x,y##. What can you conclude?
If we are going to explore alternatives, you can also use ##|xy|\le \frac{x^2+y^2} 2## which comes from ##(|x|-|y|)^2\ge 0##. Then$$
\left|\frac{5x^2y}{x^2+y^2}\right|\le 5 |x|\left|\frac{xy}{x^2+y^2}\right|\le\frac 5 2 |x|$$which leads to a solution too. So @iraid, I guess you have seen more than one way to skin this particular cat. Still, I think polar coordinates is the simplest.
