Density Matrix (pure state) Property
The discussion focuses on proving the property of the density matrix for a pure state, specifically its positive semi-definiteness. The density matrix M is defined as a 2x2 matrix with elements m11 = |a|^2, m12 = ab*, m21 = a*b, and m22 = |b|^2, where a, b, c, and d are complex numbers. The proof involves demonstrating that the determinant of the density matrix is zero, leading to one eigenvalue being zero and the other being one, thus confirming that the matrix is semi-positive definite. The expression |ac* + bd*|^2 is derived, which is always non-negative, further supporting the conclusion.
  • Understanding of density matrices in quantum mechanics
  • Familiarity with complex numbers and their conjugates
  • Knowledge of eigenvalues and eigenvectors
  • Basic principles of linear algebra, particularly Hermitian matrices
  • Study the properties of Hermitian matrices in quantum mechanics
  • Learn about eigenvalue decomposition and its applications
  • Explore the implications of positive semi-definite matrices in quantum states
  • Investigate the role of trace and determinant in matrix theory
Quantum physicists, mathematicians, and students studying quantum mechanics who are interested in the mathematical foundations of density matrices and their properties.
Toten
Hello.
I need some help to prove the first property of the density matrix for a pure state.
According to this property, the density matrix is definite positive (or semi-definite positive). I've been trying to prove it mathematically, but I can't.
I need to prove that |a|^2 x |c|^2 + |b|^2 x |d|^2 + ab*c*d + a*bcd* >= 0,
where a, b, c, and d are complex numbers, and * means the complex conjugate.
My Density Matrix M (2x2) has the following elements:
m11 = |a|^2, m12 = ab*, m21 = a*b, m22 = |b|^2
And (c; d) is just a ket in the C2 space.
I hope you can help me. Thanks you!
Even if the density matrix is defined for a ensemble of spinors, the property holds true. How can you prove it?
Probably you have that |a|^2+|b|^2=1, because trace should be 1.
You matrix is Hermitian. Trace is the sum of eigenvalues, determinant is the product of eigenvalues. The determinant of your matrix is zero. Therefore one of the eigenvalues is zero, the other must be 1. Therefore your matrix is semi-positive definite.
Thank you! I hadn't realize that the determinant of the density matrix is zero. This gave me an idea on how to reorganize the terms in the following expression:
= aa*cc* + bb*dd* + ab*c*d + a*bcd*
= ac*a*c + bd*b*d + ac*b*d + bd*a*c
= ac*(a*c + b*d) + bd*(b*d + a*c)
= ac*(a*c + b*d) + bd*(a*c + b*d)
= (ac* + bd*)(a*c + b*d)
= (ac* + bd*)(ac* + bd*)*
= |ac* + bd*|^2, which is always greater than or equal to zero.
I don't know if this is the easiest way to prove it, but it is definitely one way.
Thanks for your help!
  • · Replies 21 ·
  • · Replies 17 ·
