Density of energy from the stress-energy tensor
The discussion centers on demonstrating that the expression ##t^\mu t^\nu T_{\mu\nu}## represents the density of energy of the electromagnetic (EM) field as measured by an observer with a temporal vector ##t^\mu##. The stress-energy tensor is defined as ##T^{\mu \nu}=\frac{1}{4\pi} \left ( F^{\mu \sigma } F^{\nu \rho} \eta _{\sigma \rho}-\frac{1}{4} \eta ^{\mu \nu } F^{\sigma \rho} F_{\sigma \rho} \right )##. The participants clarify the correct interpretation of indices and the calculation of terms, emphasizing that the density of energy is proportional to ##E^2 + B^2## and must be non-negative.
  • Understanding of the stress-energy tensor in electromagnetism
  • Familiarity with tensor operations and index notation
  • Knowledge of electromagnetic field tensors, specifically ##F_{\mu\nu}##
  • Basic concepts of relativity, including temporal vectors and 4-velocity
  • Study the derivation of the stress-energy tensor for electromagnetic fields
  • Learn about the properties and calculations involving the Levi-Civita symbol ##\epsilon_{\mu\nu\alpha\beta}##
  • Explore the implications of energy density in different reference frames
  • Investigate the relationship between electric and magnetic fields in the context of relativity
Students and researchers in theoretical physics, particularly those focusing on electromagnetism and general relativity, as well as anyone interested in the mathematical formulation of energy density in field theories.
fluidistic
Hi guys,
I would like to show that if ##t^\mu## is a temporal vector then ##t^\mu t^\nu T_{\mu\nu}## is the density of energy of the EM field measured by an observer with velocity ##t^\mu##. And that it is greater or equal to 0.
Density of energy is proportional to ##E^2+B^2## if my memory doesn't fail me.
Mostly tensor "operations"?
Def. of the S-E tensor: ##T^{\mu \nu }=\frac{1}{4\pi} \left ( F^{\mu \sigma } F^{\nu \rho} \eta _{\sigma \rho}-\frac{1}{4} \eta ^{\mu \nu } F^{\sigma \rho} F_{\sigma \rho} \right )##
I'm trying to grasp the basics of tensors through self study. I would like some feedback on this: ##T_{\mu \nu}=\frac{1}{4\pi} \left ( F_{\mu\sigma}F_{\nu\rho}\eta^{\sigma\rho}-\frac{1}{4} \eta_{\mu\nu}F_{\sigma\rho}F^{\sigma\rho} \right )##. Is this expression correct? I just used the definition given and lowered upper indices and rised lower indices.
My idea is to perform/analyse first ##t^\nu T_{\mu\nu}## and then contract it with the velocity vector ##t^\mu##.
So I wrote out the terms of ##t^\nu T_{\mu\nu}##, and since ##t^\nu## is temporal I chose it as (1,0,0,0) in my mind. So the only non zero "terms" are ##t^0T_{00}+t^0T_{10}+t^0T_{20}+t^0T_{30}=\sum _{\mu=0}^3 T_{\mu0}##.
I am not really sure what this sum is. It is a sum of what exactly? Of scalars? Can't be right... because then ##t^\mu## multiplied by a scalar is another vector and the density of energy is supposed to be a scalar...More thoughts: Then ##t^\mu t^\nu T_{\mu\nu}=t^\mu T_{\mu 0}=t^0 T_{00}+t^1 T_{10}+t^2 T_{20}+t^3 T_{30}=c\underbrace{t}_{\text {time}}T_{00}+t^1 T_{10}+t^2 T_{20}+t^3 T_{30}##.
Where I considered ##t^\mu=(ct,t^1,t^2,t^3)##, the 4-velocity.
Now I guess I must evaluate ##T_{\mu 0}## and replace back into the expression I got for ##t^\mu t^\nu T_{\mu\nu}##.
Is this correct so far?
O.k. knowing the nature of your professor's notes personally, you're going about it in a much more cumbersome way than needed given the tools in your notes. So let's start a bit differently i.e. in a frame independent manner (sometimes it is convenient to do calculations in a convenient choice of frame or coordinate system but in many other cases it is simply much more elegant and easier to do things in a frame/coordinate free way).
You know for starters that ##F_{\mu\nu} = 2E_{[\mu} t_{\nu]} + \epsilon_{\mu\nu\alpha\beta}t^{\alpha}B^{\beta}## right? Also, keep in mind the following identities (that are also probably in your notes) ##\epsilon_{\mu\nu\alpha\beta}\epsilon^{\mu\gamma\sigma\rho} = -3!\delta^{[\gamma}_{\nu}\delta^{\sigma}_{\alpha}\delta^{\rho]}_{\beta} ## and ##\epsilon_{\mu\nu\alpha\beta}\epsilon^{\mu\nu\sigma\rho} = -4\delta^{[\sigma}_{\alpha}\delta^{\rho]}_{\beta} ##. Now calculate ##F_{\sigma\rho}F^{\sigma \rho}## and ##F^{\mu\sigma}F_{\sigma \nu}t_{\mu}t^{\nu}## using the above expression for ##F_{\mu\nu}## and the given identities.
fluidistic, I don't want to steer you away from WannabeNewton, but I just wanted to comment on your attempt so you can see where you have a mistake.
Looks OK. Note that you didn't need to raise and lower the ##\sigma## and ##\rho## indices in the last term. You could have left it as
##T_{\mu \nu}=\frac{1}{4\pi} \left ( F_{\mu\sigma}F_{\nu\rho}\eta^{\sigma\rho}-\frac{1}{4} \eta_{\mu\nu}F^{\sigma\rho}F_{\sigma\rho} \right )##
But what you wrote is fine.
Yes, that's right. For the observer, ##t^\nu = (1,0,0,0)##
There's a mistake here. In the expression ##t^\nu T_{\mu\nu}## you are summing over ##\nu## and not summing over ##\mu##. So, ##\nu## takes the values 0, 1, 2, 3 while ##\mu## stays fixed.
Thanks guys.
WBN:I'll try "your" way and take for granted the formulae.
You're right, I misreported what I did on my draft which is somehow messy. But in the end I do reach that ##t^\mu t^\nu T_{\mu\nu}=t^\mu T_{\mu 0}=t^0 T_{00}+t^1 T_{10}+t^2 T_{20}+t^3 T_{30}=c\underbrace{t}_{\text {time}}T_{00}+t^1 T_{10}+t^2 T_{20}+t^3 T_{30}##. I don't know why the notation uses t for both time and velocity, it can get pretty confusing to me.
You don't have to take the formulae for granted. I know your professor's lecture notes have the formulas themselves if I recall correctly but if they don't have derivations of them then you can always look at the notes I showed you recently as they have the derivations.
I'm not familiar with the phrase "temporal vector" as used in relativity. I suspect it just means that the vector is "time-like". If the vector also has norm 1: ##t^\mu t_\mu = 1##, then the vector could represent the 4-velocity vector of some observer: ##t^\mu = (\frac{dt}{d\tau}, \frac{dx^1}{d\tau}, \frac{dx^2}{d\tau}, \frac{dx^3}{d\tau}).## (Assuming units where c = 1). So, the ##t## in ##t^\mu## does not stand for time, it's representing components of 4-velocity. In particular, ##t^0## does not represent time. It is the zeroth component of the 4-velocity of the observer.
Anyway, the problem statement says to interpret ##t^\mu## as the velocity of an observer. In the frame of the observer, this reduces to ##t^\mu = (1, 0, 0, 0)##, as you noted.
You found ##t^\mu t^\nu T_{\mu\nu}=t^\mu T_{\mu 0}=t^0 T_{00}+t^1 T_{10}+t^2 T_{20}+t^3 T_{30}##
What does this reduce to after substituting for ##t^0, t^1, t^2, t^3##?
I'm going back to you in a bit TSny, I appreciate the help.
WNB: I do not really understand why I should focus on calculating ##F_{\sigma\rho}F^{\sigma \rho}## and ##F^{\mu\sigma}F_{\sigma \nu}t_{\mu}t^{\nu}##.
I tried the first expression: ##F_{\mu\nu}F^{\mu\nu}=(2E_{[\mu} t _ {\nu ]} +\varepsilon_{\mu\nu\alpha\beta } t^\alpha B^\beta )(2E^{[\mu} t ^ {\nu ]} +\varepsilon^{\mu\nu\alpha\beta } t_\alpha B_\beta)##
=\underbrace{ 4 E_{[\mu} t _ {\nu ]} E^{[\mu} t ^ {\nu ]} }_I+\underbrace{ 2E_{[\mu} t _ {\nu ]} \varepsilon ^{\mu\nu\alpha\beta } t_\alpha B_\beta +2\varepsilon _{\mu\nu\alpha\beta } t^\alpha B^\beta E^{[\mu} t ^ {\nu ]} }_J+\underbrace{\varepsilon_{\mu\nu\alpha\beta } t^\alpha B^\beta \varepsilon ^{\mu\nu\alpha\beta } t_\alpha B_\beta }_K
I calculated ##I## to be worth 0, it's 2 lines in my draft, I will post the details if I'm wrong.
Is this okay so far?
In such case I get ##t^\mu t^\nu T_{\mu\nu}=t^0T_{00}=T_{00}##.
Which is worth ##\frac{1}{4\pi}(F^{0\sigma }F^{0\rho } \eta_{\sigma \rho }-\frac{1}{4}\eta ^{00}F^{\sigma \rho }F_{\sigma \rho})## where ##\eta^{00}=1## with the metric convention I'm using.
##I## shouldn't be zero. In fact ##4E_{[\mu}t_{\nu]}E^{[\mu}t^{\nu]} = (E_{\mu}t_{\nu} - E_{\nu}t_{\mu})(E^{\mu}t^{\nu} - E^{\nu}t^{\mu}) = -2E_{\mu}E^{\mu} = -2\left \| E \right \|^{2}## because ##E_{\mu}t^{\mu} = 0## and ##t_{\mu}t^{\mu} = -1##. Do you see that?
##J## however is zero. Can you see why? Also in your last expression, you have dummy indices appearing more than twice again, which you can't have. It should be ##\epsilon_{\mu\nu\alpha\beta}t^{\alpha}B^{\beta}\epsilon^{\mu\nu\sigma \rho}t_{\sigma}B_{\rho}##. Don't forget the identities for ##\epsilon_{\mu\nu\alpha\beta}##.
We are calculating ##F_{\sigma\rho}F^{\sigma \rho}## and ##F^{\mu\sigma}F_{\sigma \nu}t_{\mu}t^{\nu}## for use in the expression for ##T_{\mu\nu}t^{\mu} t^{\nu}##.
Yes, that looks good.
Hmm no I don't really see this. I understand that ##t_{\mu}t^{\mu}## is the norm of the time-like vector and in my case is worth 1-0-0-0=1 if I use the convention (+,-,-,-). Am I doing a sign error?
About ##E_{\mu}t^{\mu} = 0##, I don't see why this hold. Wouldn't that mean that ##E^\mu=(0,E^1,E^2,E^3)##? Why would the first component be zero?
Here is what I did: ##I=4 \cdot \frac{1}{2} (E_\mu t_\nu -E_\nu t_\mu) \cdot \frac{1}{2} (E^\mu t^\nu -E^\nu t^\mu)=(E_{\mu}t_{\nu} - E_{\nu}t_{\mu})(E^{\mu}t^{\nu} - E^{\nu}t^{\mu})=E_\mu t_\nu E^\mu t^\nu -E_\mu t_\nu E^\nu t^\mu -E_\nu t_\mu E^\mu t^\nu +E_\nu t_\mu E^\nu t^\mu## ##=2(E_\mu t_\nu E^\mu t^\nu - E_\mu t_\nu E^\nu t^\mu )=2E_\mu t_\nu (E^\mu t^\nu -E^\nu t^\mu )=0##. Hmm I guess I can't make the last parenthesis worth 0, can't change mu by nu and nu by mu in the second term because of the term I factorized outside the parenthesis... but I'm not sure.
No, really I don't see why.
I see.
Ok. I'm asked about ##t^\mu t^\nu T_{\mu\nu}##, not really different from ##T_{\mu \nu } t^{\mu } t^{\nu }## right?
Based on your expression for the energy-momentum tensor, you should be using the (-,+,+,+) convention. In this convention, ##t^{\mu}t_{\mu} = -1##.
Recall that ##E_{\mu} = F_{\mu\nu}t^{\nu}## so ##E_{\mu}t^{\mu} = F_{\mu\nu}t^{\mu}t^{\nu}##. Now ##F_{\mu\nu}## is antisymmetric and ##t^{\mu}t^{\nu}## is symmetric. What happens you contract a symmetric tensor with an antisymmetric tensor?
##\epsilon_{\mu\nu\alpha\beta}## is antisymmetric in all of its indices. In ##J## you are contracting it with products of the form ##t^{\mu}t^{\nu}## (with appropriate indices in the context of the expression) right? So apply the same reasoning as above.
Indeed no difference.
Ok I see.
I didn't know this, but it is worth 0. So now I can fully follow you on your post 9.
Let me see here if what I've done is correct as I think I get that J=0 for a different reason.
Skipping some latex, I found out that ##J=\underbrace{(F_{\mu\nu} t^\nu t_\nu -F_{\nu \mu } t^\mu t_\mu )}_{=0} \varepsilon ^{\mu\nu\alpha\beta } t_\alpha B_\beta+\varepsilon _{\mu\nu\alpha\beta } t^\alpha B^\beta \underbrace{(F^{\mu\nu} t_\nu t^\nu - F^{\nu \mu}t_\mu t^\mu)}_{=0}##. Except for the fact that I have mu and nu appearing 3 times in a single expression, is this "valid"?
Ok I see why now I think. A simple multiplication where the order doesn't matter I guess.
I can't really see how you got that expression for ##J##, mainly because the appearance of the dummy indices more than twice is really making it hard to parse the expression. Could you outline what you did there?
Sure. I probably did something worse than dividing by zero :approve:, but here it goes:
J=2 \left [ \frac{1}{2} (E_\mu t_\nu -E_\nu t_\mu ) \varepsilon ^{\mu\nu\alpha\beta } t_\alpha B_\beta + \varepsilon _{\mu\nu\alpha\beta } t^\alpha B^\beta \cdot \frac{1}{2} (E^\mu t^\nu - E^\nu t^\mu) \right ]
= (E_\mu t_\nu -E_\nu t_\mu ) \varepsilon ^{\mu\nu\alpha\beta } t_\alpha B_\beta + \varepsilon _{\mu\nu\alpha\beta } t^\alpha B^\beta (E^\mu t^\nu - E^\nu t^\mu)
Now I used the relation ##E_\mu=F_{\mu\nu}t^\nu##. And this is where I should have introduced 2 new Greeck letters instead of mu and nu.
This is how I got the line ##J=\underbrace{(F_{\mu\nu} t^\nu t_\nu -F_{\nu \mu } t^\mu t_\mu )}_{=0} \varepsilon ^{\mu\nu\alpha\beta } t_\alpha B_\beta+\varepsilon _{\mu\nu\alpha\beta } t^\alpha B^\beta \underbrace{(F^{\mu\nu} t_\nu t^\nu - F^{\nu \mu}t_\mu t^\mu)}_{=0}##.
That doesn't work. This is why you should stick to the index convention. What you have is ##E_{\mu}t_{\nu} - E_{\nu}t_{\mu} = F_{\mu\sigma}t^{\sigma}t_{\nu} - F_{\nu\sigma}t^{\sigma}t_{\mu}## which does not vanish in general. You should use what I told you about the antisymmetry of ##\epsilon^{\mu\nu\alpha\beta}## in all of its indices. For example, ##E_{\mu}t_{\nu}t_{\alpha}\epsilon^{\mu\nu\alpha\beta}B_{\beta} = 0## because ##t_{\nu}t_{\alpha}## is symmetric in ##\nu## and ##\alpha## whereas ##\epsilon^{\mu\nu\alpha\beta}## is antisymmetric in ##\nu## and ##\alpha##.
  • · Replies 30 ·
