How to Calculate the Density of Aluminum in a Face-Centered Cubic Unit Cell
To calculate the density of aluminum in a face-centered cubic unit cell, the atomic radius of 143 pm is used to determine the edge length, which is calculated as 404.46 pm. The mass of four aluminum atoms in the unit cell is found to be 1.79 x 10^-22 grams, while the volume of the unit cell is calculated as 6.61 x 10^-23 cm^3. Dividing the mass by the volume yields a density of 2.705 g/cm^3. The discussion also clarifies the relationship between molar mass and the mass of a single atom, emphasizing the importance of understanding the units of Avogadro's number.
Qube
(Skip to the bottom for my questions). I'm just sounding off my thoughts above.
Find the density of aluminum, which crystallizes in a face-centered cubic unit cell. The atomic radius is 143 pm.
edge length of FCC is (4/sqrt2)r.
Okay. I need to express density in grams per centimeter cubed so here goes.
1) There are 4 atoms per face-centered cubic unit cell. Therefore there are 4 aluminum atoms. What is the mass of these atoms?
The mass of one mole of Al is 26.98 grams. 26.98 grams divided by the number of atoms in a mole gives me the mass of each individual atom. 26.98 / (6.022 * 10^23) = 4.480 * 10^-23 grams per atom of Al.
Multiply by 4 and I have the mass of one unit cell of Al (1.79 * 10^-22 grams per unit cell).
2) I have mass. Now I need to find the volume.
10^12 pm = 1 m. Therefore 10^10 pm = 1 cm.
I can cube both sides and now I have 10^30 pm^3 = 1 cm^3. There we go. A measure of volume.
3) Volume of the unit cell.
Using the formula given above, the edge length of a unit cell is 404.46 pm, or 4.04 * 10^-8 cm.
Therefore the volume of a unit cell is simply the edge length (given above) cubed. Or 6.61 * 10^-23 cm^3.
4) We have grams and we have cm^3. We can divide them and get the (simplified) final result.
(1.79 * 10^-22 grams per unit cell) / (6.61 * 10^-23 cm^3) = 2.705 g/cm^3.
Questions:
1) I know my answer is correct. The second step was an intermediary step; I wasn't familiar with working with picometers. Is there, however, a simplified formula for the densities of the various unit cells?
2) How come dividing molar mass / moles = mass of one atom of the element?
g / moles = molar mass right?
(g/moles) / moles = g/moles^2 right?
Intuitively, however, dividing molar mass by moles seems to work. The mass of Avagadro's number of atoms divided by Avagadro's number is ... the mass of one atom.
Qube said:
Questions:
I suggest you not to look for it. The way you approached the problem is fine. It's always best to use the basic definition that density is mass/volume.
I don't get this. You agree that molar mass is mass of one mole? How many atoms are there in a mole? If there are N atoms, what is the mass of single atom?
Likes 1 person
Thanks! I think my problem was not realizing the correct units for Avogadro's number, which are atoms/mole.
I mistakenly thought the units for A's number was imply moles. If that were the case, then molar mass (units of which are grams/mole) divided by A's number would yield:
(g/mole) / mole = g/moles^2
But that's simply not the case.
The units of A's number are atoms / mole.
So grams / mole (molar mass) divided by atoms / mole is
grams / mole * (mole / atoms) = grams/atoms.
There we go :)!
17K
14K
