Derivation of Lorentz transformation (time)
7 replies · 2K views
rem45
Hi all,
I'm trying to derive that t=δ(t'+vx'/c^2)
Using x'=δ(x-vt) then substituting for x=δ(x'+vt') I should be able to isolate t and solve the problem but I am getting to the following point after simplification and can't figure out where to go next...?
x'= δ[δ(x'+vt')-vt] (isolate "vt")
vt = -x'/δ + δ(x'+vt') (divide by "v")
t = -x'/δv + (δ/v)(x'+vt')
If you're trying to solve the system of equations
\begin{align}
&t'=\gamma(-vx/c^2+t)\\
&x'=\gamma(x-vt)
\end{align} for t, it's really weird to use the result for x in terms of t' and x', because that's no easier to find than the result for t.
I recommend that you start by finding a linear combination of x' and t' that doesn't involve x. (I would also use units such that c=1, to avoid having to keep track of factors of c in every step, but that's optional).
I agree but the assumption is that I do not know the equation for t or t', only x and x'. I see this approach on numerous websites including the wikipedia derivation but everyone seems to get to where I am the just write that this becomes the familiar t=(gamma)(t'+vx'/c^2)
OK, in that case, the trick is to rewrite ##\gamma^2-1## in a clever way. Can you see it? Use the definition of ##\gamma##.
$$t=-\frac{x'}{\gamma v}+\frac{\gamma}{v}(x'+vt') =\frac{x'}{\gamma v}(\gamma^2-1)+\gamma t'.$$
Yes, it took me min but now I see it! Very sneaky. I don't see how this becomes t=δ(t'+vx'/c^2)...
Apparently δ(vx'/c^2) = [x'/δ(v)](δ^2-1) but there must be some other trick to reduce to the standard formula
Not sure why there's an x' in your result for ##\gamma^2-1##, but you can cancel it from that equation. Then solve for ##\gamma^2-1##, and insert the result into the right-hand side of the calculation in post #4.
Why are you using the symbol δ instead of γ. Is it just because the latter looks too much like a y?
Edit: OK, now I see what you're doing. The reason you didn't solve for ##\gamma^2-1## is that you wanted to rewrite the first term on the right-hand side in post #4. You found that it's equal to ##\gamma v x'/c^2##. This turns the result in post #4 into
$$t=\frac{\gamma v x'}{c^2}+\gamma t' =\gamma\left(t'+\frac{vx'}{c^2}\right).$$
Got it! Sorry i didn't have my reading glasses with me but now i can see now that I've been using delta instead of gamma.
Thanks for your help!
OK, cool. I think the easiest way to do this calculation is like this (in units such that c=1):
\begin{align}
&x'=\gamma(x-vt) =\gamma\big(\gamma(x'+vt')-vt\big) =\gamma^2(x'+vt')-\gamma vt\\
&\gamma vt =\gamma^2(x'+vt')-x' =(\gamma^2-1)x'+\gamma^2vt'\\
&\hspace{20mm}\bigg[\gamma^2-1=\frac{1}{1-v^2}-1 =\frac{1-(1-v^2)}{1-v^2}=\gamma^2v^2\bigg]\\
&\gamma vt =\gamma^2v^2x'+\gamma^2vt'\\
&t=\gamma v x'+\gamma t' =\gamma(vx'+t')
\end{align}
