Undergrad Derivation of the partition function
The discussion focuses on deriving the partition function using constrained variations of Shannon entropy, starting from energy levels and occupations. The participant aims to find the distribution that maximizes entropy under fixed constraints of total particle number and energy. They utilize Lagrange multipliers to solve the variation, ultimately arriving at the conclusion that the occupation numbers follow the form a_n = Ne^{-\mu e_n}. Corrections are made regarding the definitions of frequencies and constraints, leading to the realization that the parameters relate to the Boltzmann factor and chemical potential. The final interpretation is that the derived state represents the maximum entropy configuration consistent with the given constraints.
Mentz114
Starting from the definition of energy levels ##e_n## and occupations ##a_n## and
the conditions ##\sum_n a_n = N## (2.2) and ##\sum_n a_n e_n = E## (2.3) where ##N## and ##E## are fixed I'm trying to find the distribution which extremizes the Shannon entropy.
Using the frequency ##f_n=a_n/N## and ##S=\sum f_n\log(f_n)## I need to solve the variation ( ##\lambda## and ##\mu## are Lagrange multipliers) ##\delta\left(S+\lambda(\sum_n f_n-1) + \mu(\sum_n e_n f_n -E/N\right)=0##.
<br /> \begin{align*}<br /> \delta(S) &amp;= \sum \delta f_n\log(f_n) + \sum f_n \delta(\log(f_n) )\\<br /> &amp;\sum f_n \delta(\log(f_n) ) = \sum f_n (\delta f_n)/f_n=\sum \delta f_n<br /> \end{align*}<br />
and the total variation is
<br /> \begin{align*}<br /> \delta &amp;= (1+\lambda)\sum \delta f_n + \sum \delta f_n\log(f_n) + \mu\sum e_n\delta f_n<br /> \end{align*}<br />
Setting ##\lambda=-1## we are left with ##\sum \delta f_n\log(f_n)=- \mu\sum e_n\delta f_n ## from which follows ##a_n=Ne^{-\mu e_n}##.
This is the first time I've attempted a constrained variation so I'm not entirely confident that this is right. I hope it is because it is more satisfactory than methods** that use Stirlings formula. Also ##\lambda## can be trivially eliminated.
The interpetation can now be made that the state derived has the greatest entropy/disorder of all possible states that satisfy the constraints. There is a physical connection which is absent if a probability is extremised, because probability has no physical analog, unlike entropy.
** This method extremises the log of ##P=N!/\Pi a_n! ##
Using the frequency ##f_n=a_n/N## and ##S=\sum f_n\log(f_n)## I need to solve the variation ( ##\lambda## and ##\mu## are Lagrange multipliers) ##\delta\left(S+\lambda(\sum_n f_n-N) + \mu(\sum_n e_n f_n -E\right)=0##.
Looks good to me, except for a couple of points. Since you define ##f_n## as ##a_n/N##, then
  • ##\sum_n f_n = 1## (not ##N##)
  • ##\sum_n e_n f_n = E/N##
Also, why can you set ##\lambda = 1##? What you actually need is ##\sum_n e^{-\lambda - \mu e_n} = 1##. So ##e^\lambda = \sum_n e^{-\mu e_n}##
Likes Mentz114
Thanks for pointing that out. I have corrected the constraints. I switched from ##a_n/N## to ##f_n## for brevity and failed to update those expressions.
I'm thinking about this. I thought I could solve for ##\lambda## and ##\mu## separately.
OK, the total variation ##\ (1+\lambda)\sum \delta f_n + \sum \delta f_n\log(f_n) + \mu\sum e_n\delta f_n=0## gives
##f_n = Ne^{-1-\lambda-\mu e_n}##. Which is not what I concluded. Does this mean that the state which extremises the Shannon entropy is not that given by the partition function. Clearly I need help or to read some more. Any suggestions ?
I think it's correct. Your parameter ##\mu## should be equal to the Boltzmann factor ##\frac{1}{kT}##. Your parameter ##(-1-\lambda)## will be equal to ##\frac{\mu_{cp}}{kT}## where ##\mu_{cp}## is the chemical potential. So your ##f## would then be ##e^{-\frac{e_n - \mu}{kT}}##
Yes, that can be deduced from mixing and additivity once the variation is solved.
The variation I wrote seems to be correct because (the original) ##\sum e^{-\lambda - \mu e_n}=N## and (for the frequencies) ##\sum e^{-1 -\lambda - \mu e_n}=1## are the same in that we can solve for ##e^{-\lambda}## or ##e^{-1-\lambda}## and on substituting into the second constraint the equation is satisfied.
Now understand how ##\lambda## was eliminated in the derivation I'm reading ** this is straightforward.
Thanks for pointing me in right direction.
[edit]
From ##f_n = e^{-1-\lambda-\mu e_n}## using the first constraint ##\sum_n f_n=\sum_n e^{-1-\lambda-\mu e_n}=1## we find the value of ##e^{-1-\lambda}## to be ##1/\sum e^{-\mu e_n}##. Substituting into the second constraint gives ##\sum e_n e^{-\mu e_n}/\sum e^{-\mu e_n}## which is the expected value of the energy ##E/N##. Both constraints are thus satisfied.**
Erwin Schrodinger, Statistical Thermodynamics, Dover (1952)
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 0 ·
