Derivation steps for retarded potential Laplacian
2 replies · 3K views · last reply
yungman
This last part of the steps in proofing
[tex]V_{(\vec r, t)} = \frac 1 {4\pi \epsilon_0} \int_{v'} \frac {\rho _{(\vec r',t_r)} }{\eta} d\tau' \;\hbox { where } \;\eta=|\vec r -\vec r'|[/tex].
In the last step:
[tex]\nabla^2 V_{(\vec r , t) } = \frac 1 {4\pi \epsilon_0} \int_{v'} \left [ \frac 1 {c^2} \frac {\ddot{\rho} _{(\vec r',t_r)} }{\eta} - 4\pi \rho _{(\vec r',t_r)} \delta^3 (\vec {\eta}) \right ] d\tau' \;= \;\frac 1 {c^2} \frac {\partial^2 V_{(\vec r , t)}}{\partial t^2}\; - \;\frac {\rho_{(\vec r',t_r)} }{\epsilon_0}[/tex]
My questions are:
1) How do I go from [tex]\frac 1 {4\pi \epsilon_0} \int_{v'} \frac 1 {c^2} \frac {\ddot{\rho} _{(\vec r',t_r)} }{\eta} d\tau' \;= \;\frac 1 {c^2} \frac {\partial^2 V_{(\vec r , t)}}{\partial t^2}[/tex] ?
Only way I can come up with is:
[tex]V_{(\vec r, t)} = \frac 1 {4\pi \epsilon_0} \int_{v'} \frac {\rho _{(\vec r',t_r)} }{\eta} d\tau' \;\Rightarrow \; \frac {\partial^2 V_{(\vec r , t)}}{\partial t^2} = \frac 1 {4\pi \epsilon_0} \int_{v'} \frac {\ddot{\rho} _{(\vec r',t_r)} }{\eta} d\tau'[/tex]
Does anyone have a better way to derive this?
2) I cannot verify the second part:
[tex]\frac 1 {4\pi \epsilon_0} \int_{v'} 4\pi \rho _{(\vec r',t_r)} \delta^3 (\vec {\eta}) \right ] d\tau' = \frac {\rho _{(\vec r',t_r)} }{\epsilon_0}[/tex]
Notice [tex]\delta ^3(\eta)}[/tex]? But the final part [tex]\;\frac {\rho _{(\vec r',t_r)} }{\epsilon_0} \;[/tex] has no [tex]\eta[/tex] in it?
Can anyone help?
thanks
This all seems fairly trivial but I do not readily perceive what your integrating variables are. I assume that they are over space.
For part one, they took the second order partial derivative with respect to time of both sides and then divided both sides by c^2.
As for part two, it's just the volume integral of a function scaled by the dirac delta distribution which equals the value of the function evaluated where the dirac delta's arguments are zero. Since \eta is zero when r = r', then we simply evaluate \rho at r'.
That's what I came up as shown in my work, that I took the 2nd partial derivative respect to t. I was hoping that I can derive straight from the last step instead of take the answer and back up by taking the derivative on both side. But I would be happy if that is the only way.
Thanks for the reply
I am still a little unsure about the part, I have to think a little more. Also from the original equation [itex]\rho(\vec r, t_r)[/itex] means it is function of [itex]t_r[/itex]. But the answer is function of t only. Do I just look at this that [itex]t_r[/itex] differ from t by a constant so it is a function of t?
Thanks
Alan
