Derivative of a trigonometric function
5 replies · 2K views
Ocata
[itex]\frac{d}{dx}7.5sin(\frac{pi}{10}x)[/itex]
[itex]7.5(\frac{pi}{10})cos(\frac{pi}{10}x)[/itex]
Maximum: f'(x) = 0
[itex]7.5(\frac{pi}{10})cos(\frac{pi}{10}x)[/itex] = 0
[itex]7.5(\frac{pi}{10})cos^{-1}(0)= \frac{pi}{10}x[/itex]
**[itex](\frac{pi}{10}\frac{10}{pi})7.5(90) = x[/itex]
[itex](1)(7.5)(90) = x = 675[/itex]
To me, this doesn't seem to be nearly the correct answer because it doesn't make sense given the graph of this function:
[itex]\frac{pi}{10}x= pi[/itex]
x = 10
So, the first arch is at x=0 and x = 10,
so the the maximum of the curve can not be x = 675.
What am I doing incorrectly in the derivative of the trigonometric function?
Thank you
Maximum: f'(x) = 0
x = 10
Thank you
Derivation part looks fine.
What, exactly, was the question? You only mention differentiating the function but then set that derivative to 0.
Yes, this is the correct derivative.
Maximum: f'(x) = 0
and so [itex]cos(\frac{\pi}{10}x)= 0[/itex]
No. To solve [itex]Af(x)= B[/itex], you take [itex]f^{-1}(B/A)[/itex], not [itex]Af^{-1}(B)[/itex].
**[itex](\frac{pi}{10}\frac{10}{pi})7.5(90) = x[/itex]/quote]
x = 10
Thank you
Hi lep11,
Thank you. I had a feeling I was running into the issue at solving for x.
(1) [itex]7.5\frac{π}{10}cos(\frac{π}{10}x)=0[/itex]
(2) [itex]7.5\frac{π}{10}cos^{-1}(0)= \frac{π}{10}x[/itex] Here is where I was getting stuck. The first thing I noticed, was that I let cos(0) = 90 instead of π/2.
(3) [itex]7.5\frac{π}{10}\frac{10}{π}cos(0) = x[/itex]
(4) [itex]7.5\frac{π}{2} = x = 11.78[/itex] Which is closer to within the interval of the first arch of the function, but not quite where the maximum should be.
Playing around with the algebra, I finally arrived at an answer that makes sense:
If I divide the [itex]7.5\frac{π}{10}[/itex] out of the equation first at step (1):
[itex]cos(\frac{π}{10}x) = 0[/itex]
[itex]cos(0) = \frac{π}{10}x[/itex]
[itex]\frac{10}{π}\frac{π}{2} = 5[/itex] That sounds more like it.However, what I don't understand, is how come I have to divide [itex]7.5\frac{π}{10}[/itex] first? In a regular equation, it doesn't matter when you decide to divide both sides by a number, why does it matter in this situation?
Thank you.
HallsofIvy said:
What, exactly, was the question? You only mention differentiating the function but then set that derivative to 0. No. To solve [itex]Af(x)= B[/itex], you take [itex]f^{-1}(B/A)[/itex], not [itex]Af^{-1}(B)[/itex].
Thank you HallsofIvy,
[itex]7.5\frac{π }{10}Cos(\frac{π}{10}x) = 0[/itex]
[itex]Cos(\frac{0}{(7.5\frac{π }{10})}) = \frac{π}{10}x[/itex]
[itex]Cos(0) = \frac{π}{10}x[/itex]
[itex]\frac{10}{π}Cos(0) = x[/itex]
[itex]\frac{10}{π}\frac{π}{2} = x = 5[/itex]!Thank you. Now that I know how to solve this and that there is a systematic way to approach, I will be looking into why the formula provided does in fact work. Thank you for your guidance :)
The product of ##\ 7.5\frac{π }{10} \ ## and ##\ \cos(\frac{π}{10}x) \ ## is zero.The only way for a product to be zero is for one of the factors to be zero. The only one which can be zero is ##\ \cos(\frac{π}{10}x) \ ## .
