What Value of x Maximizes the Function y=axln(b/x)?
  • Thread starter Thread starter Karol
    Derivative Ln
The function \( y = a \cdot x \cdot \ln\left(\frac{b}{x}\right) \) is maximized when \( x = \frac{b}{e} \). The derivative of the function is set to zero to find the critical points, leading to the equation \( \ln\left(\frac{b}{x}\right) - 1 = 0 \). The correct application of the chain rule and logarithmic properties is essential for deriving the maximum value accurately. The discussion emphasizes the importance of rewriting logarithmic expressions before differentiation.
  • Understanding of calculus, specifically differentiation techniques.
  • Familiarity with logarithmic properties and rules.
  • Knowledge of the chain rule in calculus.
  • Ability to manipulate algebraic expressions involving logarithms.
  • Study the application of the chain rule in calculus.
  • Learn about logarithmic differentiation techniques.
  • Explore optimization problems involving derivatives.
  • Review properties of logarithms and their applications in calculus.
Students studying calculus, particularly those focusing on optimization problems, as well as educators teaching differentiation and logarithmic functions.
Karol
$$y=a\cdot x\cdot ln\left(\frac{b}{x}\right)$$
The derivative should be 0 (to maximize), what's x?
$$(ln\:x)'=\frac{1}{x}$$
$$(x^a)'=ax^{(a-1)}$$
$$(uv)'=u'v+v'u$$
$$\dot y=a \left[ ln \left( \frac{b}{x} \right)-x\frac{x}{b}x^{-2} \right]=a \left[ ln \left( \frac{b}{x} \right)-\frac{1}{b} \right]$$
$$\dot y=0 \rightarrow ln \left( \frac{b}{x} \right)-\frac{1}{b}=0 \rightarrow x=e^{\left( \frac{1}{b} \right)}$$
But the answer should be ##x=\frac{b}{e}##
Have you tried rewriting ln (b / x) using the rules of logarithms before taking the derivative of the whole expression?
$$(uv)'=u'v+v'u$$
You missed the Chain rule.
Also it may be make things easier to first expand the logarithm.
##\displaystyle \ \ln\left(\frac{b}{x}\right)=\ln(b)-\ln(x) \ ##
This question is from my post in physics, i re-wrote the constants in order not to confuse.
Yes, i used there the logarithm's rules:
$$y=a\cdot x\cdot ln\left(\frac{b}{x}\right)=a\cdot x\cdot (ln\:b-ln\:x)$$
$$\dot y=a\left[( ln\:b-ln\:x )-x\frac{1}{x} \right]=a(ln\:b-ln\:-1)=a\left[ ln\left( \frac{b}{x}\right)-1 \right]$$
$$\left[x\cdot ln\left( \frac{b}{x} \right)\right]'=ln \left( \frac{b}{x} \right)+x\frac{x}{b}(-b)\frac{1}{x^2}=x\left[ ln\left( \frac{b}{x} \right)-1\right]$$
I think it's solved, i forgot the constant b, thanks
Karol said:
$$\left[x\cdot ln\left( \frac{b}{x} \right)\right]'=ln \left( \frac{b}{x} \right)+x\frac{x}{b}(-1)\frac{1}{x^2}$$
What's the derivative of ##\displaystyle \ \frac{b}{x} \ ?\ ##
See my answer in #5, i solved, thanks
That's incorrect.
10K
