Derivative of function h(t) = sin(arccos(t)) - help
The discussion revolves around finding the derivative of the function h(t) = sin(arccos(t)). Participants express confusion regarding the application of the chain rule and the correct derivatives of the involved functions.
  • Mixed
  • Participants attempt to apply the chain rule and differentiate sin and arccos functions, while some question the correctness of their derivatives and the simplification of expressions.
There is an ongoing exploration of the derivative, with some participants providing guidance on the application of the chain rule. Multiple interpretations of the derivative's components are being discussed, but no consensus has been reached.
Participants note that their teacher does not want answers simplified, which influences their approach to the problem. There is also mention of potential typos and confusion regarding the relationship between trigonometric functions and their inverses.
BuBbLeS01
find the derivative of the function:
h(t) = sin (arccos t)
2. The attempt at a solution
derivative of sin = cos
derivative of arccos t:
(-1/sqrt 1-t^2) * 1
my book has a complete different answer so I need some help please.
(-1/sqrt 1-t^2) * 1
did u try chain rule?
Yes I got...
-1 * (1-t^2)^-1/2 + (2t)
(cos) * 1/2 * (1-t^2)^-3/2 + (2t)
BuBbLeS01 said:
Yes I got...
no that is incorrect... chain rule will be cos u *du where u in this case arcos(t)..
try again...
real10 said:
no that is incorrect... chain rule will be sin u *du where u in this case arcos(t)..
try again...
No, it won't. BuBbLeS01's first solution was much closer. Derivative of sin(f(t)) is cos(f(t))*f'(t). Let f be arccos.
hmm I am getting \frac{-x}{(1-x^2)^(1/2)} which I believe is right unless i read the question incorrectly!..
aaah a typo I have corrected the typo should be cos.thanks for pointing that out!
I'll let BuBbLeS01 check that.
Yes that's right...where did cos go?
Is this right?
cos (arccos t) * cos(-1/sqrt 1-t^2) * (2t)
My teacher does not want our answers simplified at all.
You are mixing up arccos and it's derivative. cos(arccos(t))=t. cos and arccos are inverse functions, right? The derivative of sin(f(t))=cos(f(t))*f'(t). That's the chain rule. Now carefully put f=arccos.
Okay, we have:
1. h(t)=\sin(arccos(t))
2. \frac{d}{dx}\sin(x)=\cos(x)
3. \frac{d}{dt}arccos(t)=\frac{-1}{\sqrt{1-t^{2}}}
4. \cos(arccos(t))=t
Agreed?
Thus, by the chainrule, setting x(t)=arccos(t), we have:
\frac{dh}{dt}=\cos(x(t))\frac{dx}{dt}=-\cos(arccos(t))\frac{1}{\sqrt{1-t^{2}}}=-\frac{t}{\sqrt{1-t^{2}}}
cos (arccos t) * (-1/sqrt 1-t^2)
Correct!
Now, what does cos(arcos(t)) simplify to?
Ok so cos(arccos(t)) simplifies to 1 because they are inverses of each other. I am sorry it has been a while since I have had precalc so I rusty
No, it simplifies to..t, not 1!
They are functional inverses, not multiplicative inverses.
ok so anytime I have like sin(arcsin(t)) it just cancels to t?
Sure, just like (sqrt(t))^2=t.
Okay I have another similar problem...
Find the derivative of...
tan(arcsint)
can I use the product rule?
It's not a product. Use the chain rule.
sec^2(arcsint) * (1/sqrt1 + t^2)
That's correct. If your teacher doesn't want you to simplify, I guess you can stop there.
Oh yay! thanks...lol
Okay I got another one :)...I am getting a different answer then calcchat because I did it differently...
Find the derivative...
y = xarcsinx + sqrt 1-x^2
y = xarcsinx + (1-x^2)^1/2
y' = x(1/sqrt1-x^2) + 1/2(1-x^2)^-1/2 * (2x)
