Derivative of integral of function with respect to the function
The discussion revolves around the differentiation of an integral with respect to another integral, specifically in the context of functions related to probability distributions. Participants explore the implications of changing one function while maintaining certain properties and the relationships between two integrals defined in terms of these functions.
  • One participant presents an integral expression for f and claims that increasing another integral g leads to an increase in f, questioning the validity of differentiating f with respect to g.
  • Another participant challenges the differentiation approach, stating that f and g are not functions of x, suggesting a misunderstanding of the relationships involved.
  • Subsequent posts clarify the definitions of the functions involved, with one participant renaming variables to avoid confusion and specifying the properties of the functions a(x), F(x), and f(x).
  • There is a discussion about functional derivatives, with one participant attempting to derive expressions for the derivatives of q and g with respect to a(x), leading to a proposed relationship between these derivatives.
  • Another participant introduces the concept of treating g as a variable and explores the implications of differentiating with respect to g, suggesting a more complex relationship between the functions involved.
  • Some participants discuss the monotonic properties of the cumulative distribution function (CDF) and probability density function (PDF), and how these properties influence the inequalities between the integrals q and g.
  • Concerns are raised about the uniqueness of solutions when solving integral equations related to the functions a(x) and g.
Participants express differing views on the validity of differentiating the integrals and the implications of changing the function a(x). There is no consensus on the correct approach or the validity of the proposed relationships, indicating ongoing debate and exploration of the topic.
Participants note that the functions involved are dependent on specific properties and assumptions, such as the positivity and monotonicity of a(x). There are unresolved questions regarding the uniqueness of solutions and the implications of the relationships between the integrals.
DCG
Hi all,
I have the following quantity:
[itex]f = \int_{\mu}^{\infty} (1-F(x))a(x)dx[/itex]
I want to claim that by increasing the following quantity:
[itex]g = \int_{\mu}^{\infty} a(x)f(x)dx[/itex]
then [itex]f[/itex] can only increase. Can I differentiate [itex]f[/itex] with respect
to [itex]g[/itex]? Is the following correct?
[itex]\frac{\partial (\int_{\mu}^{\infty} (1-F(x))a(x)dx)}{\partial (\int_{\mu}^{\infty} a(x)f(x)dx)}[/itex]
[itex]= \frac{\frac{\partial (\int_{\mu}^{\infty} (1-F(x))a(x)dx)}{\partial x}}{\frac{\partial (\int_{\mu}^{\infty} a(x)f(x)dx)}{\partial x}}[/itex]
[itex]= \frac{(1-F(x))a(x)}{f(x)a(x)}[/itex]
[itex]= \frac{1-F(x)}{f(x)}[/itex]
I already know that [itex]a(x) > 0[/itex] for [itex]x>\mu[/itex] and that [itex]\frac{1-F(x)}{f(x)}[/itex] is positive. Therefore [itex]f[/itex] increases when [itex]g[/itex] is increased. Does this resolve the problem?
Thank you for taking the time to read and answer!
No, because you cannot differentiate f and g with respect to x- they are not functions of x.
Oh I see. Any pointers on how I could approach this though? Is there a name for this kind of problem? Anything I could read that could help me?
Thanks a lot!
It's not clear what you're trying to do. You have an expression for f that doesn't depend on g at all. Why are you talking about increasing g? Is F(x) given, or is the problem to determine F(x) in terms of g?
DCG said:
Hi all,
In the second line, you have f as a function of one variable, x. But the first line doesn't make it a function of x. Rather, it appears to be a function of μ, and/or a functional of F(), a().
I am sorry, my choice of variable names is terrible. Let:
[itex]q = \int_{\mu}^{\infty} (1-F(x))a(x)dx[/itex]
In my first post I named it [itex]f[/itex] and it has nothing to do with [itex]f(x)[/itex].
Here [itex]F(x),f(x)[/itex] are fixed. They are the cdf and pdf of a regular distribution, [itex]\mu[/itex] is also fixed. It is the mean of that distribution. The only thing not fixed here is [itex]a(x)[/itex]. This function is positive for [itex]x>\mu[/itex] and is also monotone non-decreasing. My problem is the following:
Suppose I have some specific [itex]a(x)[/itex] and I want to replace it by another function ([itex]a_2[/itex]) with the same properties. Let:
[itex]q_2 = \int_{\mu}^{\infty} (1-F(x))a_2(x)dx[/itex]
and
[itex]g_2 = \int_{\mu}^{\infty} a_2(x)f(x)dx[/itex]
I want to prove that if [itex]g_2 \geq g[/itex] then [itex]q_2 \geq q[/itex]. Thanks your time.
So I read a bit about functional derivatives. It seems like [itex]q=q(a)[/itex] is a functional. It maps functions to numbers. So I can try and find its derivative with respect to [itex]a[/itex]. According to what I read:
[itex]\int \frac{\partial q(a)}{\partial a(x)}h(x)dx = {lim}_{\epsilon \rightarrow 0} \frac{q(a + \epsilon h) - q(a)}{\epsilon}[/itex]
[itex]= {lim}_{\epsilon \rightarrow 0} \frac{q(a) + \epsilon q(h) - q(a)}{\epsilon}[/itex] [itex]= q(h) = \int_{\mu}^{\infty}(1-F(x))h(x)[/itex]
Now if I assume that [itex]h(x)[/itex] is defined only on [itex][\mu ,\infty ][/itex] I have that:
[itex]\int_{\mu}^{\infty} \frac{\partial q(a)}{\partial a(x)}h(x)dx = \int_{\mu}^{\infty}(1-F(x))h(x)[/itex]
which means that (I am not sure about this):
[itex]\frac{\partial q(a)}{\partial a(x)} = (1-F(x))[/itex]
In the same way it turns out that [itex]\frac{\partial g(a)}{\partial a(x)} = f(x)[/itex]
Using the chain rule I get:
[itex]\frac{\partial q(a)}{\partial g(a)} = \frac{\frac{\partial q(a)}{\partial a(x)}}{\frac{\partial g(a)}{\partial a(x)}} = \frac{1-F(x)}{f(x)} \geq 0[/itex]
Does this even resemble anything valid?
That's more or less right, but you might run into problems trying to do it that way when your functionals aren't linear in your function a(x). When doing variational derivatives it's helpful to use the identity
$$\frac{\delta a(x)}{\delta a(y)} = \delta(x-y),$$
where ##\delta(x-y)## is the Dirac delta function (I will assume you know what this is, but ask if you don't). If we take the variational derivative of, say, g = g[a], we get
$$\frac{\delta g[a]}{\delta a(y)} = \int_{\mu}^\infty dx~f(x) \frac{\delta a(x)}{\delta a(y)} = \int_{\mu}^\infty dx~f(x) \delta(x-y) = f(y)\Theta(y-\mu),$$
where ##\Theta(x)## is the Heaviside step function, which appears because the delta function doesn't contribute anything to the integral unless y is in the integration range.
I'll let you try the variational derivative of q[a] for yourself.
What the derivative tells you is that if you have some fixed ##a(x)## and you perturb it to ##a(x) + \epsilon \delta a(x),## where ##\epsilon## is some small number and ##\delta a(x)## is O(1), then
$$g[a + \epsilon \delta a] \approx g[a] + \epsilon \int_{\mu}^\infty dy f(y) \delta a(y);$$
(well, it's exactly equal to that in this case because g was linearly dependent on a, but this is basically the functional equivalent of the tangent approximation to a function).
That said, I'll have to think for a second if the chain rule would work like that for variational derivatives.
Hey DCG and welcome to the forums.
You have a PDF so it means that the CDF is monotonic increasing. This implies 1 - F(x) is monotonic decreasing.
If g2 > g then this means integral of (a2(x) - a(x))f(x)dx over the appropriate interval is > 0. If q2 > q then this means integral (a2(x) - a(x))(1 - F(x))dx over the appropriate interval is also > 0.
But (a2(x) - a(x))(1 - F(x)) = (a2(x) - a(x)) - F(x)(a_2(x) - a(x)) which implies integral (a_2(x) - a(x))dx > F(x)(a_2(x) - a(x))dx over the right region (which makes sense).
Now we know (a_2(x) - a(x))dx > 0 and we know that F(x) <= 1 for any x by the properties of the CDF so the above inequality holds.
To push the functional way of doing it a little bit further (although DCG might be happy with chiro's solution, which is less technically demanding than what I'm about to do), I think the way you would need to think about things is like this: suppose g is just a variable, not a functional. Then we could interpret a(x) as a function of both x and g, which is determined by solving the integral equation
$$g = \int_{\mu}^\infty dx~f(x)a(x|g).$$
Differentiating implicitly with respect to g gives
$$1 = \int_{\mu}^\infty dx~f(x)\frac{\partial a(x|g)}{\partial g}.$$
Notice that if we set g = 1 in the first equation we would have a similar equation to this second one, suggesting that we can state
$$a(x|1) = \frac{\partial a(x|g)}{\partial g},$$
where a(x|1) is the solution to the original integral equation with g = 1.
Now, we can also consider q to be a function of g. (q is no longer considered to be a functional of a because a is determined by solving the integral equation). So,
$$q(g) = \int_{\mu}^\infty dx~(1-F(x))a(x|g),$$
and
$$\frac{\partial q(g)}{\partial g} = \int_{\mu}^\infty dx~(1-F(x))a(x|1).$$
One could then presumably solve the integral equation for a(x|1), and could then insert the solution into the equation for q'(g). Of course, the problem is that I don't think you get a unique solution. Suppose I set ##a(x|1) = h(x)/f(x)##, assuming f(x) is never zero on ##(\mu,\infty)##. Then all I need to do is pick any function h(x) that's normalizable on ##(\mu,\infty)##.
Thank you for your answer but I do not understand what happened to f(x) in the integral of
(a2(x)-a1(x))f(x)dx >0
this does not imply that integral(a2(x)-a1(x))dx > 0
since f(x) could allocate more probability mass to intervals where a2(x)>a1(x) and less to opposite ones.
and
I like this approach. Since the only thing that I want to prove is that if g increases then
q can only increase or stay the same, it suffices to prove that:
[itex]\frac{\partial q(g)}{\partial g} \geq 0[/itex]
Thank you all for the answers.This was really helpful. I think that I am in the right direction now, so I will try to work it out.
What does g2 - g >= 0 imply in terms of the integral?
