Derivative of Inverse Function
To find g'(-1/2) for the inverse function g(x) of f(x) = x^3 / (x^2 + 1), it is essential to first determine g(-1/2) by solving the equation -1/2 = x^3 / (x^2 + 1). This leads to the cubic equation 0 = x^3 + (1/2)x^2 + 1/2, which has a solution at x = -1, thus g(-1/2) = -1. The derivative of the inverse function is given by g'(x) = 1/f'[g(x)], so g'(-1/2) = 1/f'(-1). Differentiating f(x) yields f'(x) = (3x^2(x^2 + 1) - 2x(x^3)) / (x^2 + 1)^2, and substituting x = -1 will provide the necessary value for g'(-1/2). Understanding these relationships is crucial for solving similar problems involving inverse functions.
sydneyfranke
Find g' (-1/2), where g(x) is the inverse of f(x) = x3 / (x2 + 1)
g'(x) = 1/f' [g(x)]
Everything else I tried got really messy, but I feel like I'm going out on a limb by:
1) y=x3 / (x2+1)
2) y=x3x-2 / 1
3) y=x
4) g '(0.5)= 1/ (0.53 /(0.52+1) = 10
I don't even know if I'm going about it the right way. Any help would be awesome. Thanks.
You say in 1) that
y = x^3 / (x^2 + 1)
and in 3) that
y = x.
If you put in x = 1 you see that in 1) you get 1/2 and in 3) you get 1. Something must hence be wrong.
Very true. I realize something is wrong. That was just my attempt.
But . . . I could still use some help with this problem, obviously.
sydneyfranke said:
1) y=x3 / (x2+1)
2) y=x3x-2 / 1
Line 2 is incorrect, it should be
y=x3x-2 / (1+x-2),
which actually just makes things more complicated. Just differentiate the expression on line 1 directly.
It would help to figure out what g(-1/2) was equal to
Then you could just plug stuff into this relationship: g'(x) = 1/f' [g(x)] -> g'(-1/2) = 1/f' [g(-1/2)]
Since we know that g is the inverse of f, we should try to solve when f(a) = -1/2. Then we would know a = g(-1/2).
So -1/2 = x^3 / (x^2 + 1) -> -1/2*(x^2 + 1) = x^3 -> 0 = x^3 + 1/2x^2 + ½ which clearly has a solution at -1. So we know g(-1/2) = -1 which means: g'(-1/2) = 1/f'(-1) and you can do the rest from there id bet.
So I differentiate to get
(x2+1(3x2))-(2x(x3))/((x2+1)2)
And then I dared to simplify it down to
(x4+3x2)/((x2+1)2)
But what I don't understand from all of this is that if I do that, am I plugging this in for the g(x) for the 1/ f '[g(x)]? That would be like plugging f '[f '(x)] right? I'm sorry I'm just trying to understand how to solve these types of problems.
As the guy above said, if f(c) = -1/2 then g(-1/2) = c. To find out what g(-1/2) is we need to find c, that is to solve the equation f(x) = -1/2.
When this is done you can just plug everything into the formula.
(x4+3x2)/((x2+1)2)
Surely if I have a function y=f(x), then the inverse is just x=g(y) and it's derivative is \frac{dx}{dy} which is a function of y. So that for:
f(x)=\frac{x^3}{x^2+1}
we have x=f^{-1}(y) and so the derivative of the inverse at y_0 can be written as:
\frac{df^{-1}}{dy}\biggr|_{y_0}=\frac{dx}{dy}\biggr|_{y_0}=\frac{1}{\frac{dy}{dx}}\biggr|_{x(y_0)}
So now let y_0=-1/2[/tex]. Then solve:<br /> <br /> y_0=-1/2=\frac{x^3}{x^2+1} <br /> <br /> which has three solutions. The inverse and it&#039;s derivative are multi-valued right since it&#039;s going to be a cube root correct? Therefore, just find the three roots (x_1,x_2,x_3) and for example, then one derivative of the inverse at y=-1/2 is:<br /> <br /> \frac{df^{-1}}{dy}\biggr|_{y=-1/2}=\frac{dx}{dy}\biggr|_{y=-1/2}=\frac{1}{\frac{dy}{dx}}\biggr|_{x(-1/2)=x_1}<br /> <br /> Try and follow the following Mathematica code which explicitly computes the inverse, then finds it&#039;s (multivalued) derivative at y=-1/2:<br /> <br /> <div class="bbCodeBlock bbCodeBlock--screenLimited bbCodeBlock--code"> <div class="bbCodeBlock-title"> <i class="fa--xf fal fa-code "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1765853780#code"></use></svg></i> Code: </div> <div class="bbCodeBlock-content" dir="ltr"> <pre class="bbCodeCode" dir="ltr" data-xf-init="code-block" data-lang=""><code>f[x_] := x^3/(x^2 + 1); mysols = x /. Solve[f[x] == y, x] N[D[mysols, y] /. y -&gt; -2^(-1)]</code></pre> </div> </div>
