Derivative of momentum with respect to time
The discussion focuses on the relationship between the derivative of the unit momentum vector (dPhat/dt) and the tangential velocity (v) divided by the radius (R) of a circular path, expressed as dPhat/dt = v/R. Participants clarify that v represents the tangential velocity of an object in circular motion, while R is the radius of that circular path. The derivation involves understanding the change in direction of momentum and applying the product rule to momentum vector calculations. The conclusion emphasizes that as the radius decreases, the rate of change of direction increases, supporting the equation dPhat/dt = v/R.
  • Understanding of basic physics concepts, particularly momentum and circular motion.
  • Familiarity with calculus, specifically derivatives and the product rule.
  • Knowledge of vector mathematics, including unit vectors and their properties.
  • Concept of centripetal force and its relation to circular motion.
  • Study the derivation of centripetal acceleration and its relation to velocity and radius.
  • Learn about the product rule in calculus and its applications in physics.
  • Explore the concept of angular velocity and its relationship to tangential velocity.
  • Investigate the implications of changing radius on the motion of objects in circular paths.
Students of physics, particularly those studying mechanics, as well as educators and anyone interested in the mathematical foundations of motion in circular paths.
MAC5494
Hi, I don't really have a particular problem that needs to be solved, I'm just interested in why dPhat/dt = v/R. It's explained very poorly in my physics book, or I'm just not smart enough to understand it the way they explained it.
dp/dt = F, where F is force.
So there's no way it could equal v/R if v is speed and R is a distance, the units don't work out. What are v and R?
Sorry, I explained that poorly. I don't mean the derivative dPhat/dt = v/R, i want to know why dPhat/dt is equal to v/R
pvector = pmag*phat
so by using the product rule you get:
dpvector/dt = (dpmag/dt)*phat + pmag * (dphat/dt)(dpmag/dt)*phat is the rate of change of the magnitude of momentum, or the force parallel.
pmag * (dphat/dt) is the rate of change of the direction of the momentum, or the force perpendicular.It says in my book that, lim Δt approaches 0, magnitude(Δphat/Δt) = magnitude(dphat/dt) = vmag/R
So I want to know why that is?
Ah, yes, dphat is dimensionless, I see. I think you can imagine v is tangential velocity of an object rotating around some circle with radius R with your coordinate system at the center of the circle. So if you have a huge circle, R is going to be very big and your tangential force will be smaller since the object turns at a slower rate with a bigger circle (given a constant tangential velocity, v).
Okay, I get some of that, but I'm still having a hard time conceptualizing how those 2 quantities are equal. I get that the velocity will be pointing in the direction of the Phat, but I don't understand how one derives velocity/radius from dPhat/dt.
I'm basically trying to understand it, because it makes more sense to truly understand rather than memorize that dPhat/dt = v/R
Well, you can derive it from p=mv using the definition of the unit vector.
you would also have to consider that:
\vec{p} = m\vec{v}
and that
\vec{v} = x\hat{x} + y\hat{y}
How do you derive it? I've been messing around with it for a little while and I can't seem to figure it out.
Phat = p/pmag = m*vvector/m*vmag = vvector/vmag
dt = dp/Fnet (vvector/vmag)*Fnet/dp
Am I doing this right? I'm kind of lost at that point.
I'm not sure I've seen that bottom equation before.
hrm. I'm not getting there with my approach either. I'll have to rethink it. can you define v and R for me and tell me the general physical set up?
Well v is just velocity, and R is the radius of a kissing circle.
For instance, if an asteroid had a circular orbit around a planet, then the speed would be constant. Only the direction would be changing, so you'd want to find the rate of change of the direction of momentum, which is |p|*(dpvector/dt) which = |p|*(|v|/R) = (m*|v^2|)/R
So the derivation is lots of algebra so I didn't carry it through.
However, if you have a vector and you break it into magnitude and direction, then \frac{d \hat{p}}{dt} is just "change in direction of vector per time".
So if you imagine a particle orbiting around in a circle, it's going to turn faster as it's tangential velocity is higher (it's going faster around the circle so it's turning faster) and, given a fixed v, it's going to turn faster on a smaller circle. So v/r seems to fit qualitatively, no?
