Derivative of p-fold convolution
1 reply · 4K views · last reply
divB
Hi,
What is the derivative of a p-fold convolution?
[tex] \frac{\partial}{\partial Y(\omega) } \underbrace{Y(\omega) * \dots * Y(\omega)}_{p-\text{times}}[/tex]
EDIT: I have two contradicting approaches - I guess both are wrong ;-)
As a simple case, take the 2-fold convolution. FIRST approach:
[tex] \frac{\partial}{\partial Y(\omega)} Y(\omega)*Y(\omega) = \frac{\partial}{\partial Y(\omega)} \int_{-\infty}^{\infty} Y(\tau) Y(\omega-\tau) d\tau = \int_{-\infty}^{\infty} Y(\tau) \underbrace{\frac{\partial Y(\omega-\tau)}{\partial Y(\omega)}}_{\delta(\tau)} d\tau = \int_{-\infty}^{\infty} Y(\tau)\delta(\tau) d\tau = 1[/tex]
Here I think the derivative is wrong but intuitively it makes sense at least: Differentiation is the opposite of smoothing, smoothing is convolution, so taking away the convolution is taking away smoothing.
SECOND approach:
[tex] \frac{\partial}{\partial Y(\omega)} Y(\omega)*Y(\omega) = \mathcal{F}\left\{ \mathcal{F}^{-1}\left\{ \frac{\partial}{\partial Y(\omega)} Y(\omega)*Y(\omega) \right\} \right\} = \mathcal{F}\left\{ -j y(t) y^2(t) \right\}= \mathcal{F}\left\{ -j y^3(t) \right\} = -jY(\omega)*Y(\omega)*Y(\omega)[/tex]
Here is the point where I am stuck - I am sure I can't apply the derivative theorem here because it's not a derivative by [tex]\omega[/tex]. But how to do this? Anyways, this result does the opposite from above and is also against my inuition, so I think it's wrong ...
Ok I think I got it. Is this correct? (I was not able to do simple differentiation)
[tex] \frac{\partial}{\partial Y(\omega)} Y(\omega)*Y(\omega) =<br /> \frac{\partial}{\partial Y(\omega)} \int_{-\infty}^{\infty} Y(\tau) Y(\omega-\tau) d\tau = \\<br /> \int_{-\infty}^{\infty} Y(\tau) \frac{\partial Y(\omega-\tau)}{\partial Y(\omega)} d\tau =<br /> \int_{-\infty}^{\infty} Y(\tau) \frac{\partial \omega}{\partial \omega} \frac{\partial Y(\omega-\tau)}{\partial Y(\omega)} d\tau =<br /> \int_{-\infty}^{\infty} Y(\tau) \frac{\partial \omega}{\partial Y(\omega)} \frac{\partial Y(\omega-\tau)}{\partial \omega} d\tau = \\<br /> \int_{-\infty}^{\infty} Y(\tau) \left(\frac{\partial Y(\omega)}{\partial \omega}\right)^{-1} \frac{\partial Y(\omega-\tau)}{\partial (\omega-\tau)} \frac{\partial (\omega-\tau)}{\partial \omega} d\tau =\\<br /> \int_{-\infty}^{\infty} Y(\tau) \frac{1}{Y'(\omega)} Y'(\omega-\tau) d\tau =<br /> \frac{Y'(\omega) * Y(\omega)}{Y'(\omega)}[/tex]
In any case, now I am struggling with something different where I do not know if there is even a solution to it!
Suppose the same setup as above. However, instead of having just a convolution, I have a function which operates on [itex]Y(\omega)[/itex]:
[tex] \frac{\partial}{\partial Y(\omega)} F(Y(\omega))[/tex]
However, I do not have the analytical form of F. However, I know the analytical form of its Fourier transform f.
Can I write the equation above in terms of the Fourier transform [itex]y(t)[/itex] and [itex]f[/itex] ?
I can do it but I still have the factor of [itex]1/Y'(\omega)[/itex]. For the example above:
[tex] \frac{1}{Y'(\omega)} j \mathcal{F}\left( t \cdot y^2(t) \right)[/tex]
Oh, wait, I didn't realize that I can also trivially expand [itex]1/Y'(\omega)[/itex]:
[tex] -\frac{\mathcal{F}\left\{ t \cdot y^2(t) \right\}}{\omega \mathcal{F}\left\{(t) \right\}}[/tex]
Is this correct?
