High School Why Can Derivatives Be Treated Like Fractions in Solving Equations?
NoahsArk
TL;DR
Not sure why derivatives are sometimes treated as fractions.
I don't understand the logic behind why derivatives can be treated like fractions in solving equations:
## \frac {du}{dx} = 2 ## simplified to
## du = 2dx ##
I keep seeing this done with the explanation that "even though ## \frac {du}{dx} ## is not a fraction, we can treat it like one". Why?
Thanks
Consider how dy/dx came about as the slope at any given point on a curve and that taught you start with ##\Delta y / \Delta x ## which a fraction of small differences.
Soon you will learn about differentials dy and dx and then it may make sense.
Likes NoahsArk
https://math.stackexchange.com/questions/1784671/when-can-we-not-treat-differentials-as-fractions-and-when-is-it-perfectly-ok#1784701 said:
So, yes, ##dy/dx## can be treated like a fraction in the sense (and to the extent) that the Chain Rule ##dy/dx=(dy/du)(du/dx)## is a thing that is true, but that's essentially as far as the fraction analogy goes. [...]
[...] here are examples of fraction-like manipulations which are not valid:
$$\left( \frac{dy}{dx} \right)^2 = \frac{(dy)^2}{(dx)^2} \ \ \text{ or } \ \ 2^{dy/dx} = \sqrt[dx]{2^{dy}}.$$
Because these manipulations are nonsensical, students are often warned not to treat derivatives like fractions.
Likes NoahsArk and DaveE
NoahsArk said:
Summary:: Not sure why derivatives are sometimes treated as fractions.
## du = 2dx ##
Thanks
Technically, in each case you have to prove (or at least justify) the manipulation. Although, the one you posted is usually taken as the definition of a differential.
Likes NoahsArk
Limits in Calculus often gave students headaches especially the epsilon definition.
in contrast, developing Calculus with hyperreals where the limit notion is buried inside the number system makes calculus easier and gives you a kind of differentials algebra where you can safely treat dy/dx as a fraction.
https://en.m.wikipedia.org/wiki/Hyperreal_number
one mathematician wrote a whole calculus book based on hyperreals. Limits were introduced later in the book for completeness.
https://people.math.wisc.edu/~keisler/calc.html
  • Skeptical
Likes sysprog, Dale, weirdoguy and 2 others
If a student is struggling with calculus, I'm not sure non-standard analysis is an easy escape route!
Likes jasonRF, Delta2, DaveE and 1 other person
Well if we are trying to integrate ## \frac {du}{dx} = 2 ## and we multiply both sides by dx:
du = 2dx
We end up with ## u\prime = 2 ## and then after integrating get u = 2x. So if the dx just disappears, what was the point of putting it on the right side? Why not just eliminate it from the equation? What does the dx even mean when it's being multiplied by 2?
du = 2dx
Actually, you get u = 2x + C, where C is an arbitrary constant.
As far as integration is concerned, the dx (or dt or d<whatever>) indicates what the variable of integration is. Another explanation is that it's a holdover from the Riemann sum in which you add up a bunch of thin rectangles that are 2 units tall and ##\Delta x## wide. That is,
$$\sum_{i = 0}^n 2 \Delta x_i$$
Here, some interval [a, b] is subdivided into n subintervals, with the width of the i-th subinterval being ##\Delta x_i##. If you take the limit of the above sum, as ##n \to \infty##, you get the area below the line y = 2.
Actually, in this case, you get the same result for any positive integer n, but that doesn't happen for other functions, in general.
Likes dextercioby, sysprog and NoahsArk
I'm really glad you weren't my High School Calculus teacher, but then I soon learned at University (Group Theory, actually) that I'm more suited to Engineering than Mathematics.
Maybe that's something Calculus teachers should take into account. How many of their students will become Mathematicians and such, versus how many will need Calculus for practical uses.
The way I learned it, is that I was being taught first the definition of the differential of a function f as $$df=f'(x)dx$$ and then the Leibniz symbolism for derivative as the ratio (fraction) of two differentials, the differential of the function to the differential of the identity function i(x)=x which is di=(x)'dx=dx. That is $$f'=\frac{df}{dx}=\frac{f'dx}{dx}=f'$$.
So , according to my opinion, it can be perfectly treated as a fraction. But beware if you have higher order derivatives for example $$f''=\frac{d^2f}{dx^2}$$ you can perfectly write this as $$d^2f=f''(x)(dx)^2$$ however you just can NOT integrate both sides of the last expression because the integral $$\int d^2f=\int f''(x)dx^2$$ is not well defined, we know that only integrals of the form $$\int g(x) dx$$ are well defined, that is we must have ##dx## there and not ##dx^2## or ##dx^n##.
Likes NoahsArk
du = 2dx
The simplest way to think about differentials is that they are like the smallest possible change in a quantity: ##dx## is like the smallest possible ##\Delta x##. From that point of view, you can multiply them by numbers.
To put the concept of a differential on a sound mathematical footing is not so easy, but that shouldn't be a concern for a first course in calculus.
Likes Klystron
DaveE said:
I'm really glad you weren't my High School Calculus teacher…
Why? The hyperreals are used merely to say it’s okay to treat them as fractions. Limits are then delayed until later chapters. Calculus then becomes more of applying the laws to functions to get derivatives and to solving realworld problems with it.
The point of the limit discussion early on is to allay feelings that the foundation of Calculus is somewhat sketchy. It’s why mathematicians worked so hard to come up with limit theory.
Look at the Keisler Calculus book and see if its alternative approach is good or not.
Likes Dale
du = 2dx
You started with ##\frac{du}{dx} = u' = 2##. What you're really doing is
\begin{align*}
\frac{du}{dx} &= 2 \\
\int \frac{du}{dx}\,dx &= \int 2\,dx \\
u &= 2x + C
\end{align*} The cancelling of ##dx## that you often see is just a useful mnemonic that happens to work notationally, but as others have pointed out, if you try to take the analogy too far, you run into trouble.
Just as ##du/dx## really means applying the operator ##d/dx## to ##u##, you can think of the integration operator as not just ##\int## but ##\int dx##. You never just throw in an integral sign without differentials also appearing.
Likes NoahsArk
Maybe part of my confusion is coming from definitions. What's the difference between ## \frac {\Delta y}{\Delta x} ## and ## \frac {dy}{dx} ## ? I thought all these were just different ways of saying ## y\prime ## where it's assume ## y\prime ## means the amount that y changes for a given value of x.
it is $$\frac{dy}{dx}=\lim_{\Delta x\to 0} \frac{\Delta y}{\Delta x}$$ which intuitively means that the difference between the two get as small as we want, as long as we choose small enough ##\Delta x##.
Likes bob012345, jack action, NoahsArk and 1 other person
## du = 2dx ##
They both say the same thing. It is a ratio between ##du## and ##dx##. Whatever the change in ##x## is, the change in ##u## is twice as large.
FactChecker said:
They both say the same thing. It is a ratio between du and dx. Whatever the change in x is, the change in u is twice as large.
I think that's an easier way to think about it. So, ## \frac {du}{dx} ## really is a fraction in a way.
du = 2dx becomes ## u \prime = 2dx ##. I am assuming the "d" on the left side and the "dx" on the right then disappear in the next step since these are both operators and we are doing the inverse operation to end up with u = 2x + c?
  • Skeptical
Likes PeroK
##du \ne u'##
Likes vela
@PeroK
I thought du, ## u \prime ##, and ## f \prime (x) ## all meant the same thing- i.e. the derivative of u with respect to x. What is the difference between du, ## u \prime ##? Thanks
NoahsArk said:
@PeroK
There are two common notations for a derivative, namely ##f'(x)## and ##\frac{df}{dx}##. Or, if we write ##y = f(x)##, then ##\frac{dy}{dx} = f'(x)##.
The differentials ##dy## and ##dx## are not derivatives. It's not clear why you should think that ##dy = \frac{dy}{dx}##.
But does ## u \prime = \frac {dy}{dx}? ##
I'm confused about what dy means standing by itself. ## \frac {dy}{dx} ## meant the derivative of y with respect to x. In the equation ## \frac {dy}{dx} = 2 ##, we simplified to dy = 2dx. Then in the next step (and please let me know if the next step I'm doing is wrong), we changed dy to ## u \prime ## and changed 2dx to just 2 then integrated. If the step was correct to change dy to ## u \prime ## and if ## u \prime ## is the same as ## \frac {dy}{dx} ## then we end up with the left side of the equation being the same with what we started with.
I am assuming the operator for the antiderivative is ## \int ##. Seems like it would be much easier to solve for ## \frac {dy}{dx} = 2 ## by saying ## \int \frac {dy}{dx} = \int 2 ## then we'd get y = 2x + c. This whole thing about putting the dx on the other side, then changing the dy to a ## y \prime ## which means the same thing as ## \frac {dy}{dx} ## which we started with, then erasing the dx from the right side which wasn't there to begin with, seems confusing.
It's not clear where you are getting this from. There is no need to introduce another variable ##u##, but if you do you have to define it.
##\int## means nothing on its own. It must always be ##\int dx## (or ##dy## or ##dt##), because you must always specific the variable with respect to which you are integrating. For example:
$$\frac{dy}{dx} = 2 \ \Rightarrow \ \int \frac{dy}{dx} dx = \int 2 dx = 2x + C$$Then we can use the fundamental theorem to see that $$\int \frac{dy}{dx} dx = y$$Note that we only need one arbitrary constant, so there's no point in adding another one here. In any case, this gives us $$y = 2x + C$$ More generally:
$$\frac{dy}{dx} = f(x) \ \Rightarrow \ \int \frac{dy}{dx} dx = \int f(x) dx \ \Rightarrow \ y = \int f(x) dx$$
Likes NoahsArk and vela
##dy## represents the change in y, not the ratio of change in y divided by change in x. In general use, ##dy## represents a minuscule change in y although it might be a larger change in some contexts.
Likes NoahsArk
Mathematicians timidly say they are not fraction. They are right, maybe. I observe many physics people including myself treat them as if they are fractions and have not encountered serious problems as far as I am concerned.
Likes NoahsArk
I have always liked the hyperreal approach and I wonder why calculus curriculums have been so slow to pick it up. It is not exactly a new thing any more. It seems far more intuitive and natural than the whole epsilon delta limits approach.
Likes jedishrfu
NoahsArk said:
@PeroK
No. du is the (possibly infinitesimal) change in u. Period.
##u\prime## is the ratio of change in u divided by the associated change in x.
It is like the difference between 55 and 55/3. They are not the same.
What would be your definition of the limit of a convergent sequence?
For teaching calculus I would skip the construction of hyperreals in terms of convergent sequences. That is not necessary for calculus students. I would focus on the properties of hyperreals and how to use them rather than how to construct them.
You're proposing not to teach sequences at all? Go straight to hyperreals?
You wouldn't teach anything to do with standard real analysis?
In a calculus class I would teach only as much real analysis or sequences as is absolutely necessary to teach calculus. I think that is pretty minimal, but "not at all" and "wouldn't teach anything" probably goes a bit too far. The goal is calculus, not these other topics.
  • · Replies 22 ·
11K
