Derive ##\dfrac{\rho_1}{\rho_2}=\dfrac{T_2}{T_1}##
The discussion revolves around deriving the relationship between the densities and temperatures of two gases, specifically the equation ##\dfrac{\rho_1}{\rho_2}=\dfrac{T_2}{T_1}##. The context involves gas behavior in a hot-air balloon scenario, where the density of the gases is influenced by temperature and pressure conditions.
  • Participants explore the definitions of the variables involved, such as the densities of the gases and their relationship to temperature. Questions arise regarding the setup of the problem, including the conditions under which the gases coexist and how they interact. There is also discussion about the implications of fixed volume and how temperature changes affect pressure and density.
The discussion is ongoing, with participants seeking clarification on the definitions and relationships between the variables. Some have offered insights into the implications of temperature changes on pressure, while others express confusion about the physical setup of the problem and the behavior of the gases involved.
There are uncertainties regarding the definitions of the gases involved and their interactions, as well as the implications of the fixed volume of the balloon. Participants are also questioning the assumptions made about pressure and temperature relationships in the context of the problem.
Istiak
PV=nRT
I just found here(https://byjus.com/physics/relation-between-density-and-temperature/#:~:text=Density and Temperature Relationship 1 When density increases,,reduces. 4 When the temperature decrease, density increases.) that P=##rho##RT. So they just took ##\rho=\frac{n}{V}##.
##\dfrac{P_1}{P_2}=\dfrac{\rho_1 RT_1}{\rho_2 RT_2}##
##T_2=\frac{\rho_1T_1P_2}{\rho_2P_1}##
I got pressure while I want to ignore it. No, I don't want to choose ##P_n##=1
What are 1 and 2 defined in the problem ?
first object and 2nd object. e.g. ##\rho_1## density of first object.
Thanks. How do these objects are connected or coexist, the problem says ?
##\rho_1=n\rho_2##.
n? Number of particles? Which particles of objects1 or 2 or ... ?
No. ##n## is just an integer.
I am still puzzled. There are gas #1 and gas #2. Are they independent ? mixed in a same vessel ? pushing a piston from right and left ? or ... I do not get the situation.
The problem said that, "density of first object is ##n## times of second object". Hope it's clearer more now
Consider a hot-air balloon with fixed volume VB = 1.1 m3. The mass of the balloonenvelope, whose volume is to be neglected in comparison to VB, is mH = 0.187 kg. The balloon shall be started, where the external air temperature is ϑ1 = 20 oC and the normal external air pressure is po = 1.013 ⋅ 105 Pa. Under these conditions the density of air is ρ1 = 1.2 kg/m3.
What temperature ϑ2 must the warmed air inside the balloon have to make the balloon just float?
<br/>
sh*t I mixed up two questions. That's why you were getting confused, Sorry for that.
So gas #1 is the Air and gas #2 seems to be gas in the balloon, right ? You could find the relation between ##P_1## and ##P_2##.
Are you talking about ##(\dfrac{V_1}{V_2})^\gamma=\dfrac{P_2}{P_1}##?
When gas pressures inside and outside balloon are different, the balloon inflates or shrinks for the pressures to be ...
I think that depends. Like, if outside pressure is higher than it shrinks and inflates for less pressure outside
Right. So how do you estimate the pressures inside and outside in the end ?
don't know.
But I may try, at the end I will consider their temperature is same. So I will start with ##PV=nRT##
##\frac{P_1V_1}{P_2V_2}=1##? Considered for a single mole ##n=1##.
Yet the statement of the problem says that the volume is "fixed".
I understand that the balloon will not float unless its volume increases. I do not understand how to interpret "fixed". Maybe the 1.1 m3 is an upper limit?
Edit: The volume is constant. As the temperature of the air inside changes, air will leave or enter the balloon.
Thanks for reminding. So 1.1m^3 gas inside the balloon should be lighter than 1.1 m^3 air around with 0.187 kg for just float.
Istiakshovon said:
Homework Statement:: Derive ##\dfrac{\rho_1}{\rho_2}=\dfrac{T_2}{T_1}##
Relevant Equations:: PV=nRT
In order to get a hint how about thinking other way around, i.e.,
When ##\dfrac{\rho_1}{\rho_2}=\dfrac{T_2}{T_1}##, get the relation of ##P_1## and ##P_2## ?
##\rho=\frac{P}{RT}##
##\dfrac{\rho_1}{\rho_2}=\frac{T_2}{T_1}##
##\dfrac{P_1RT_2}{RT_1P_2}=\frac{T_2}{T_1}##
##\dfrac{P_1}{P_2}=1##
Why the question mark? That says that the pressure inside and outside the balloon is the same. Doesn't make sense? The volume enclosed by the balloon envelope is fixed but not the amount of air inside. Have you ever seen a hot-air balloon? The envelope has an opening at the bottom and a heater directly underneath the opening. How does that work?
The equation on #20 were saying pressures are same. But in #16 I got that pressure times volume are the same. If we consider pressure to be same then Volume should be same. That's what was confusing me that moment.
kuruman said:
How does that work?
The fire increases the pressure of the balloon if we consider volume to be constant. From ##PV=nRT##, pressure increases as the temperature increases.
Istiakshovon said:
The equation on #20 were saying pressures are same. But in #16 I got that pressure times volume are the same. If we consider pressure to be same then Volume should be same. That's what was confusing me that moment.The fire increases the pressure of the balloon if we consider volume to be constant. From ##PV=nRT##, pressure increases as the temperature increases.
You don't understand how a hot air balloon works and you didn't read post #21 carefully enough. Yes, ##pV=nRT##. The volume ##V## is fixed and the balloon is open at the bottom. Please answer the following questions in sequence:
1. How does the pressure inside the balloon differ from the pressure outside? Remember the balloon is open to the atmosphere.
2. What does ##pV=nRT## predict will happen when you raise the temperature inside from ##T_1## to ##T_2## keeping the volume constant?
3. Is your answer in question 2 consistent with your answer in question 1?
  • · Replies 18 ·
