Deriving input-output relationship
  • Context: High School
  • Thread starter Thread starter jayki
    deriving Relationship
The discussion revolves around deriving a mathematical relationship between dependent (output) and independent (input) variables based on a limited number of sample points. Participants explore methods for generalizing this relationship and the challenges involved in doing so.
  • Exploratory, Technical explanation, Debate/contested
  • One participant asks how to derive a mathematical relation from known samples of dependent and independent variables.
  • Another participant suggests that knowledge of the functional form is necessary to extrapolate from a few points to a general relationship.
  • A participant reiterates the need for a general form to fit the data, mentioning that without a guess of the functional form, generalization is not feasible.
  • It is proposed that a polynomial of sufficiently high degree can fit the data, but this may not represent the desired relationship accurately.
  • A participant clarifies that they have specific vectors for x and y and seeks to generalize the relationship between them based on the given samples.
Participants express differing views on the feasibility of deriving a general relationship from limited samples, with some emphasizing the necessity of knowing the functional form and others discussing polynomial fitting as a potential approach. The discussion remains unresolved regarding the best method to generalize the relationship.
Limitations include the dependence on the assumed functional form and the challenges of fitting a polynomial to a finite number of samples, which may not yield the intended relationship.
jayki
hi frenz
i want to how to derive mathematical relation between dependent(output) and independent(input) variables when i know the relation between them at few samples.
cud someone help me out?
thanks in advance
do you know anything about the functional form? even roughly how it should look? if not then there is no way to extrapolate from a few points to every point.
as i told , i know the relation between them at few samples. but i want to generalise as a mathematical relation between them
As olgranpappy says, you can't in general... without at least having a guess to the general form. Given a finite number of samples, you can fit it to a polynomial of sufficiently high degree. However, that polynomial is probably not what you are looking for.
http://en.wikipedia.org/wiki/Curve_fitting
In addition, note the diagrams in
http://slack.net/~ant/bl-synth/3.nyquist.html
thanks for ur response dear frenz...but let me clear my question again. I have a vector(x) and a vector(y) with the value of x at few points and corresponding value of y. I want to generalize the relation between them with that given samples.
  • · Replies 33 ·
