Deriving the Divide and Average Method from Newton-Raphson Formula
  • Thread starter Thread starter thedc
The discussion revolves around deriving the Divide and Average Method for calculating the square root of 2 from the Newton-Raphson formula. Participants explore the mathematical foundations and relationships between the two methods, focusing on the necessary equations and derivatives involved.
  • Homework-related, Mathematical reasoning, Technical explanation
  • Some participants express confusion about how to derive the Divide and Average Method from the Newton-Raphson formula, questioning the steps involved.
  • One participant suggests that the function can be expressed as F(x) = x^2 - A, where A is the number whose square root is sought, specifically A=2 in this case.
  • Another participant proposes that the derivative of the function f(x) = 2/x is f'(x) = -2(1/x^2), indicating a potential misunderstanding of the derivation process.
  • Several participants reiterate the Newton-Raphson method's purpose, which is to find roots by iteration, but do not clarify how it directly relates to the Divide and Average Method.
  • A later reply emphasizes the need to express the function such that F(x) = 0 and suggests performing algebra on the resulting iterate expression after taking the derivative.
Participants generally express confusion and uncertainty about the derivation process, with no consensus on the correct approach or understanding of the relationship between the methods.
Participants have not reached a clear understanding of the necessary steps to derive the Divide and Average Method from the Newton-Raphson formula, and there are unresolved questions regarding the appropriate function and its derivative.
thedc
[Divide and average Method] Square root of 2 was computed using the formula
Xi+1 = 1/2 ( Xi + 2/Xi).------------ (1)
Derive this method from the Newton-Raphson Formula
Im boggled at how to derive this solution.
The equation for Newton Raphson is
F'(Xi) = (F(Xi) - 0) / Xi -(Xi+1) ------------- (2)
which can be rearranged to
Xi+1 = Xi - F(Xi) / F'(Xi)--------- (3)
does this mean that i take the derivative of the equation (1)?
(Xi+1)' =1/2(Xi+2/Xi)
You have
[tex]x^2 = 2[/tex]
or
[tex]x = \frac{2}{x}[/tex]
So,
[tex]f(x) = \frac{2}{x}[/tex]
Derive your equations from there.
I still don't get it, do i take the derivative of 2/x?
that would be f(x)'=-2(1/x^2)
What is the Newton-Raphson method?
Good job guy.
/s
I am having the same problem.
Newton Raphson method: Xof(i+1) = xi - f(x)/f(x)'
it is used to find roots by iteration
Write your equation in the form y = f(x).
Calculate f'(x).
Choose a starting value for x0.
If y - f(x0) < tolerance then end
else
Calculate x1 using Newton-Raphson formula.
Iterate
I think there is sufficient confusion amoung these posts to warrent another (hopefully non-confusing) post
thedc: For Newton-Raphson, you are looking for the zero of a function (F), hence, you need to express the function (F) such that F(x) = 0.
In your original post, you desire to find the answer to [itex]x[/itex] for [itex]x = \sqrt{2}[/itex]. Consider the more general solution for [itex]x[/itex] with [itex]x = \sqrt{A}[/itex] for some positive [itex]A[/itex].
Question: How can we express a function, [itex]F(x)[/itex], such that it results in [itex]F(x)=0[/itex] for this problem?
Answer: Look at the [itex]x = \sqrt{A}[/itex]. This is really the same as finding [itex]x^2[/itex] such that [itex]x^2 = A[/itex]. Hence, one selection of [itex]F(x)[/itex] might be [itex]F(x) = x^2 - A=0[/itex].
This is the "F" that is needed in the N-R method. The iterates for the solution of x are as follows:
[tex] x_{\nu+1} = x_{\nu}-\frac{F(x_{\nu})}{F'(x_{\nu})}[/tex]
Here, [itex]F'(x)[/itex] is shorthand to mean [itex]\frac{d\,}{dx}F(x)[/itex]. Also, in your case, the vale of A is A=2. You will need an initial estimate [itex]x_{0}[/itex] to start this procedure.
The key to achieve the end goal of your exercise is to do some algebra on the resulting iterate expresion once you take the derivative of F and substitute it into the expression.
Hope this helps.
9K
