Deriving the thermal expansion formula for pipes
2 replies · 4K views · last reply
dirk_mec1
I do not understand how this formula is derived:
Diagram titled Expansion Loop Formula: L = square root of (3 ED (ΔL) / 2S), with labels for loop length (in.), modulus of elasticity at maximum temperature (psi), outside diameter of pipe (in.), working stress at maximum temperature (psi), and change in length due to change in temperature (in.).
Can somebody help me?
Source:
https://www.corzan.com/en-us/piping-systems/specification/thermal-expansion
Note: Important information needed is missing from the above thread post.
It is necessary to go to the reference source and view its "loop" diagram consisting of two vertical legs' with a length ratio = 2L/5 of the calculated L requirement with two standard 90° pipe ells at the top connecting a horizontal pipe section with a leg to leg spacing ratio = L/5 requirement to understand what apparently results in the above formula.
As a result the above appears to be a formula based upon all of the above loop configuration requirements.
