Derjaguin Formula for Contact Angle Prediction | Explained and Illustrated
  • Context: Graduate
  • Thread starter Thread starter LouisD
    Formula
The discussion revolves around the Derjaguin formula for predicting the contact angle of a droplet on a solid substrate, particularly in the context of a thin liquid interlayer. Participants explore the implications of Lifshitz energy calculations in this scenario, questioning the necessity of an intervening medium between the phases involved.
  • One participant presents the Derjaguin formula and questions how to calculate Lifshitz energy when only air, water, and a solid substrate are present.
  • Another participant shares their experience using the Derjaguin formula in their master's thesis, introducing a different expression for the contact angle involving disjoining pressure and precursor film thickness.
  • A third participant attempts to clarify the first question by suggesting that the thin film acts as the medium for the Lifshitz energy calculation, implying that air does not significantly affect the interaction in this context.
  • There is uncertainty regarding the definition and role of Lifshitz energy, as one participant expresses confusion about its necessity in the absence of a liquid or gas between the two phases.
Participants express differing views on the role of the air and the necessity of an intervening medium for Lifshitz energy calculations, indicating that the discussion remains unresolved.
There are limitations regarding the assumptions made about the roles of air and the thin liquid film in the context of Lifshitz energy, as well as the definitions of terms like disjoining pressure and Lifshitz energy itself.
LouisD
Hi everyone,
Decades ago, Derjaguin calculated formula which was able to predict the contact angle of a droplet on a solid substrate. The droplet and the solid substrate are separated by a thin liquid interlayer.
This formula was
cos(θ) = 1 + G(h0)/γ
where θ is the contact angle of the droplet on the solid substrate, h0 is the equilibrium distance between the droplet and the droplet (i.e the width of the thin liquid interlayer) and γ the surface tension of the liquid (water here).
The calculation of G(h0) leads to the following expression :
G(h0) = - A/(12.[itex]\pi[/itex].h0²)
with A the Hamaker constant of the system. This energy corresponds to the Lifshitz energy.
Here is my question : When you're calculating the Lifshitz energy between two materials (solid or liquid) you need to have between them a liquid or a gas. In this case, you just have air-water-solid substrate. I don't understand how it is possible to calculate the energy then, can somebody help me with that ? As I'm not a very good english speaker, I hope my question is clear otherwise don't hesitate to ask me to clarify any details.
For more detail one this, http://arxiv.org/pdf/1212.6583.pdf
Thanks you
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
I needed the Derjaguin formula several times when I was writing my master's thesis on the behavior of thin liquid films on solid substrates. The formula we used was ##\cos \theta = 1 + \frac{1}{\gamma}\int_{h*}^{\infty}\Pi (h)dh##, where ##\theta## is the contact angle, ##\gamma## is the surface tension, ##h^*## is precursor film thickness and ##\Pi (h)## is the disjoining pressure as a function of film thickness.
I'm not sure I really understand LouisD's question... What is Lifshitz energy? What do you mean by needing to have something between the two phases for which the energy is calculated?
I think I understand your question. The disjoining pressure in your case is made of van der Waals energy (specifically - London-Lifshitz dispersion forces). You said yourself that there is a thin film between the substrate and the liquid. In that case that is the medium which is used in the formula. The air plays no role here since it is far above the surface and you can probably assume infinite thickness for the liquid.
  • · Replies 0 ·
  • · Replies 50 ·
12K
  • · Replies 25 ·
