Describe each plane, 8x-5y=-40z
  • Thread starter Thread starter paralian
    Plane
The discussion revolves around the mathematical representation of the plane defined by the equation 8x - 5y = -40z. Participants confirm that the plane intersects all three axes at the origin (0, 0, 0) and emphasize that to fully describe the plane, additional points are necessary. The conversation highlights the importance of understanding that three points determine a plane and that a single point combined with a normal vector can also define it. The participants suggest finding more points on the plane by selecting values for two variables and solving for the third.
  • Understanding of linear equations in three dimensions
  • Knowledge of intercepts in coordinate geometry
  • Familiarity with the concept of normal vectors
  • Ability to perform algebraic manipulations to solve for variables
  • Learn how to derive the normal vector from a plane equation
  • Study the geometric interpretation of planes in three-dimensional space
  • Explore methods for finding additional points on a plane given one point
  • Investigate the relationship between planes and their intersections with other geometric shapes
Students studying geometry, mathematics educators, and anyone interested in understanding the properties and representations of planes in three-dimensional space.
paralian
Apologies for this being a kind of stupid question...
Describe each plane
(a) 8x-5y=-40z
Probably have to find the x, y, and z intercepts.
I would assume that in order to find the x intercept you set y and z equal to zero. And the same idea for the other two.
THe answer that I got was (0, 0, 0). Am I doing this wrong?
paralian said:
8x-5y=-40zI would assume that in order to find the x intercept you set y and z equal to zero. And the same idea for the other two.
Hi paralian! :smile:
No, you're completely correct …
the plane intersects all three axes at the origin, (0, 0, 0). :smile:
erm … wasn't that obvious? :rolleyes:
Since there are an infinite number of planes that contain (0,0,0), you might want to give some other points also to "describe" the plane. Three points determine a plane.
What is required to answer such a question?
Hi Defennder! :smile:
Hint: Forget about axes … what defines a particular plane through a given point? :smile:
The dot product of the normal vector to the plane and a vector lying on the plane through that point?
Well, that will always be zero …
but what defines the plane? :smile:
(what makes one plane different from another plane?)
More specifically, what do you or your teacher mean by "describe the plane". You said you were looking for the three axis-intercepts but found that the plane passes through (0,0,0). My point before, based on what you said you were doing, was that three points "determine" a plane. Did you intend to "describe" the plane by giving the 3 intercepts? If so that is the same as giving three points. But they don't have to be the intercepts. You know one point, (0,0,0). You can find two more points in the plane by picking any two of x, y, or z to be some simple numbers (simplicity is, after all, is the whole point of the intercepts) and then solve for the third component.
It is also true that a single point (which you already have) and a normal vector "determine" a plane. Would you accept that as a "description" of the plane?
  • · Replies 17 ·
20K
