Destroying asteroids shown to be very difficult
  • Context: High School
  • Thread starter Thread starter jim mcnamara
    Asteroids
50 replies · 9K views
Charles El Mir et al, A new hybrid framework for simulating hypervelocity asteroid impacts and gravitational reaccumulation, Icarus (2018). DOI: 10.1016/j.icarus.2018.12.032
https://phys.org/news/2019-03-asteroids-stronger-harder-previously-thought.html
Modeling the destruction of asteroids in an effort to protect Earth from nasty collisions, has some new research. And a new model.
The takeaway is larger asteroids "reassemble themselves" from explosion fragments, under the asteroid's own gravity unless the explosion has far more energy than previous models indicated.
Assuming the model's results are meaningful -
In other words, we need a bigger bang. Which may mean that deflection of asteroids instead of breaking them into shards may be a more feasible approach. There is some discussion on this with Charles El Mir, the lead author, in the phys.org article.
Astronomy news on Phys.org
My impression is that deflection is the only feasible method ever being considered. Destroying a large asteroid would take an enormous amount of explosive, while a lot less energy would be needed to deflect..
I think it is safe to say that the object may indeed reassemble itself, but not entirely. A subsurface blast would eject a significant amount of material at speeds greater than escape velocity. So, unless the blast takes place at the exact center of gravity, the newly reassembled object will be on a different course. The ejected material would be on an even greater deviation from the original (collision) course.
Also discussed in this same Forum in the thread:
Ideas to protect the Earth from possible asteroid impacts
https://www.physicsforums.com/threa...-earth-from-possible-asteroid-impacts.959077/
Same article were already presented here
Let me link the relevant wiki article
Wiki is hard to be considered a reliable source - but even there the 'blow it to pieces' approach seems to be ... missing, and the whole 'nuke it' section is actually about nuclear propelled deflection.
Can't help wondering that why scientific articles would aim against - movies? o_O
Thanks for the link, @Rive , that article makes a lot of the same points mentioned in the PF link in my Post#4. Nice to see that other people are thinking the same way.
The article makes some pretty flawed assumptions. For example;
For example, if there's an asteroid coming at earth, are we better off breaking it into small pieces, or nudging it to go a different direction?
These are presented as mutually exclusive scenarios, which they are not. To me the obvious question would be, “Why should we care if the object is shattered into a thousand pieces, so long as none of those pieces are headed for Earth?”
The 'none' is the problem. As last resort blowing one to pieces might be better than nothing since the atmosphere has a decent shielding effect for smaller pieces so the expected damage will be most likely reduced, but it is impossible to guarantee the all the (dangerous) major pieces will miss Earth - and there is not much intervention possibility left once it become a rubble cloud without shape and handle.
But as long as it is in one piece it can be 'nudged' as a whole.
So with the 'nuke it' option the hard part is actually to give it the biggest nudge in the most effective direction without blowing it to pieces (small debris does not count).
The model mentioned in the article might be helpful in calculating the best yield/depth and other parameters.
Does a nuclear explosion actually transfer very much momentum? Why would detonating a nuclear bomb adjacent to an object in space do anything except heat that object up? Why would it push the object appreciably? In an atmosphere a nuclear explosion heats up air and the resulting shock wave moves a whole lot of stuff. In a vacuum one only has the particles that are released in the nuclear explosion to do any momentum transfer - I imagine not much pushing.
In order to move the asteroid, one must use part of the asteroid mass itself for momentum transfer I think - how can it be possible to push the asteroid via explosion without ejecting part of the asteroid mass to push the rest in the other direction? Maybe you don't disagree and this is what you mean by nudge also.
It would be nice to have the linked wiki article as bottom line for any discussion about 'nuke an asteroid'.
@Rive Yes, sorry, should have read that first.
It seems clear that Rive is contemplating a sub-surface detonation which does eject part of the asteroid mass to obtain effective thrust.
I'd be thinking in terms of a well-aimed armor piercing warhead with a delay fuse timed to achieve a burst at the desired depth. The guys who design missiles are pretty good at that stuff.
Actually, it seems to me not critical that any asteroid mass be ejected. Given an isotropic explosion at some point on the asteroid surface, nearly half the momentum ejected by the explosion goes to deflecting the asteroid. The tendency of the asteroid to coalesce if initially blown apart is only to the good for the purposes of deflection. With current technology, I don’t see any better deflection approach than a properly placed nuke.
Hmm... seems to me that the mass is in the plasma of the fireball, which would be the gross mass of the bomb and casing. Doesn't seem like that would be very effective in moving a megaton rock.
Here is a slightly informative link. https://www.labroots.com/trending/space/12897/here-s-what-d-happen-detonated-nuclear-bomb-space
Try a Google search for nuclear bomb explosion, or for nuclear bomb explosion in space
When available energy is to be converted to impulse, it is about the classic E= 1/2mv2 equation. With digging out the impulse it is p=2E/v, which is actually inversely proportional to the speed for any given energy.
There is energy loss and many other considerations, but at the end this is the basis of the deflection.
With abundant energy and low mass, you get a flashy explosion but just low impulse at the end: to get more impulse you need low speed and just the more mass the better.
Of course the speed still should be above the escape velocity of the asteroid in question to get effect.
So the key point of the 'nuke it' approach is to determine the optimal yield and depth of detonation for the material constitution of a specific asteroid to avoid breaking it up yet providing the most mass barely escaping it: this would provide the maximal thrust. (The direction of the thrust to get maximal effect is a different matter.)
That's why I dare to say that the linked model seems to be spot on, yet at the form it was presented it is just a capital misfire.
That's of course true, but impulse is still proportional to energy given that plasma velocity will not vary much as bomb yield increases. While it is not as efficient as optimal burial, a large enough energy produces a large impulse. It is also technologically easier.
It also appears to me that the researchers were pretty responsible in their wording, saying that their new model shows some “possible” differences from previous models, and the old conclusions are “called into question,” while the writers of the article make it sound like the old models have now been proved wrong. Always a good idea in these situations to remember that all we have now are two or more models that do not agree. We have no observations to support one over the other. The new model includes factors that the old model did not, and that is a good thing, but there is still a lot of room for factors that no one has even guessed at yet.
Let's take a really big bomb then. The Tsar Bomba, a yield of 50 MT with a mass of 27 tonnes. Too heavy to be launched on an Earth escape trajectory by any existing rocket. Let it explode on the surface, half of its mass hits the asteroid, half of it escapes using half of its energy. For simplification let's assume this half moves away with the same velocity for all the material, I'll do the same for the asteroid material so we ignore a similar prefactor in both cases. You shoot away 13.5 tonnes at a speed of sqrt(2E/m)=3900 km/s, a bit over 1% the speed of light. Total momentum transfer: sqrt(2Em) = 5.3*1010 kg m/s.
What happens if we can bury a 10 MT bomb ~10 meter below the surface and shoot away the material above it? Let's use 1000 tonnes here. Let's assume again that half the yield is used to shoot away this mass. We shoot the material out at a speed of 290 km/s and get a total momentum transfer of 29*1010 kg m/s. Despite using a much smaller weapon we got 5.5 times the effect.
What happens if we can shoot away 1 million tonnes with the 10 MT bomb (might need some sort of drilling to reach ~100 m depth)? You get a velocity of 9 km/s and a momentum transfer of 914*1010 kg m/s, we gain another factor 30 over the already improved result.
Why 'Nuke it'? (Apart from the obvious popular appeal.)
The thread has already established that we would need to land on and penetrate the asteroid in order to make best use of the 'nuke' then why not use a conventional rocket? Less energy available of course but energy is not momentum, as we have recognised and what's needed is a Match of source against load, to use an electrical analogy.
The Momentum change which is what we are actually after, could be directed in the optimum direction.
sophiecentaur said:
Why 'Nuke it'?
Apart from the obvious reason (nice big blast, at a convenient distance) it's about our actual limits regarding rocket technology. The available mass would be only a few hundred kg (based on the deep space vehicles produced so far) on the asteroid, and in that mass it's hard to pack anything else what would make any difference on a rock what's big enough to worth (or: better) deflected.
So with a nuke it would be already feasible with our current technology.
A 27 tonne rocket shooting "all" its mass away at 4.5 km/s (better use hydrolox) produces a momentum change by 1.2*108 kg m/s. That is a factor 400 worse than the Tsar Bomba surface explosion, a factor 2000 worse than the shallow explosion of the 10 MT bomb, and a factor 70,000 worse than the deep explosion.
Why nuke it? Because it is better if you need a significant push.
Hmm... this is an interesting topic. I think that the hypervelocity impact study is quite relevant to some of our ways of defending against an asteroid, but not necessarily to nukes.
In regards to nuke vs asteroid, I think that if we are to deploy an explosive device, we will likely emphasize on range. We want it to meet the asteroid as farm away from Earth as possible, so that it only has to make a small change in the asteroid's trajectory in order to make it completely miss Earth. This means that a heavier payload may not be better if we cannot get it to a detonation point as far as a lighter payload. That being said, the missile aimed at an asteroid will probably be nuclear not because it makes a bigger boom, but because the missile needs to be propelled by a nuclear source. Since even the largest impact we can make onto asteroids is pretty small, we will need to have a detonation point somewhere beyond at least Mars orbit. Preferably Saturn or Jupiter orbit. Mars orbit along takes 6 months to get to, and the only fuel source that lasts that long is really nuclear.
In this method, the hypervelocity impact study wouldn't really matter, because the explosion will not be big enough to create a system where the asteroid and the impactor are shattered to a degree in which the particles' gravity end up very uniform in strength and are also spherical. (implying that the pieces are uniform in mass, shape, and therefore composition)
The way we might defend ourselves from asteroids which does involve these hypervelocity impacts, and a personal favorite of mine, is to nudge objects from the asteroid belt into their paths. This method is actually pretty half-baked as if we are getting hit by an asteroid, it probably comes from the asteroid belt and this method solves none of that. But, for the sake of having a hypervelocity impact, this is one of the more plausible ones.
@rizheng1: Most near Earth asteroids fly around in the inner Solar System, their distance to Earth changes all the time and their orbit intersects Earth's orbit. You don't need to go far away to get there.
It is challenging already to reach an object with a rocket. With an asteroid, that is mainly dead mass? Much more difficult.
rizheng1 said:
...to nudge objects from the asteroid belt into their paths.
We are not even able to tell for sure if an asteroid will hit Earth or not: we can give a probability only, and for this we have a relatively big target. But then we nudge a small asteroid to hit another small asteroid with 100% chance and give it a known change in trajectory? :woot:
I know the numbers could be important but how important would it be if you could choose a very early intervention? Your figures imply a no-brainer solution to a last minute deflection problem.
As rizheng says:
rizheng1 said:
We want it to meet the asteroid as far away from Earth as possible, so that it only has to make a small change in the asteroid's trajectory in order to make it completely miss Earth.
A one minute of arc deflection a year beforehand would give massive amplification of course direction. But I appreciate that the orbit prediction error goes up, the further in advance you take action so that could mean many more interventions with more asteroids would be necessary - just to be on the safe side. There are actually a lot of relevant factors when deciding on a suitable solution for the collision problem and different generations could find different optimum solutions as technology progresses.
I think the most relevant factors are the time of noticing the danger: the size of the asteroid and our capability to deliver mass to the asteroid.
For the size of the asteroid, we have a bottom line: below that any intervention is just does not worth it. And that size is actually pretty big already.
About our capability to send a device, a few hundred kg delivered in limited time is already a big deal.
Please correct me if I'm wrong, but right now on scientific/engineering basis nothing else seems feasible but a nuke with a surface (!) explosion, and even for that we are a bit short, and the progress does not seem promising at all.
On top of that there are prediction errors that multiply with time. Looking too far ahead would produce an embarrassing number of possible candidates. I could imagine a number of craft, placed in suitable orbits, that could rendezvous with threatening objects when they've been identified. That could save a lot of time and even save on overall cost.
What we actually need is a 'serious' collision that would bring the problem to the public's attention and that would justify vast amounts of global spending. But the 'event' would need to be pretty big; more visible than the present evidence of climate change, which is not yet serious enough to make people sit up and take notice of that (probably) more relevant problem. Most humans don't think the same way that most PF members think, unfortunately.
[Edit: a large new crater on the Moon (our side) would be an ideal advert for a very expensive defence system for Earth. I guess the downside could be that, for a very visible crater formation, a significant amount of debris could reach Earth and do some low level damage here.]
It doesn't matter. If the asteroid is so small and you have so much time that a tiny impactor is sufficient to deflect it: Sure, do that. That's not the point. The question is how to deal with larger asteroids efficiently.
Unless the asteroid will make close fly-bys afterwards you only get an amplification in the direction of the orbit - the orbit stays a closed ellipse, changing its shape but not the orbital period doesn't lead to a deviation that accumulates over time.
sin(1 arcminute)*1 AU = 43,000 km. Enough if you know the orbit very precisely already.
To put the asteroid into an entirely different orbit, wouldn't that (a least sometimes) involve more than one burn?
I realize that a deflection will not cause a helical path (you didn't mean that?) but what can you do to ensure that it will always be out of harm's way? You are perhaps implying that there is a minimum energy requirement to get a permanent miss trajectory? That makes sense.
Every burn will change its orbit. With a single short burn the new orbit will intersect the old orbit at the point of the burn.
To get the object away from Earth permanently you need a much larger trajectory change (~1000 times larger) than a simple impact avoidance maneuver needs. Moving it by a few thousand kilometers vs. moving it by a few million kilometers.
