Determinats,dependence, span, basis.
  • Context: Undergrad
  • Thread starter Thread starter am_knightmare
    Basis Span
The discussion clarifies the relationships between determinants, linear dependence, span, and basis in the context of a 3x3 matrix in R3 vector space. A determinant of zero indicates linear dependence, meaning the matrix does not span R3 and is not a basis for R3. Conversely, a non-zero determinant signifies linear independence, allowing the matrix to span R3 and serve as a basis. The conversation emphasizes that the determinant itself does not determine these properties; rather, it is the set of column vectors of the matrix that holds these characteristics.
  • Understanding of linear algebra concepts such as determinants and vector spaces.
  • Familiarity with the properties of matrices, specifically 3x3 matrices in R3.
  • Knowledge of linear independence and dependence.
  • Concept of basis and span in vector spaces.
  • Study the properties of determinants in linear algebra.
  • Learn about linear independence and dependence in vector spaces.
  • Explore the concept of basis and span in Rn.
  • Investigate the rank of a matrix and its implications in linear algebra.
Students and professionals in mathematics, particularly those studying linear algebra, as well as educators seeking to clarify the relationships between determinants, linear dependence, span, and basis in vector spaces.
am_knightmare
Im having trouble under stand the relationships between determinats, span, basis.
Given a 3x3 matrix on R3 vector space.
* If determinat is 0, it is linearly dependent, will NOT span R3, is NOT a basis of R3.
, If determinant is non-zero, its linearly independent, will span R3, is a basis of R3
I was not able to confirm this statement one of my friends said, and i checked wiki as well, but didn't find a answer. Question is, is this right? can anyone confirm this? Thanks in advance.
It is not meaningful to say that a determinant is linealy independent, spans Rn, or is a basis for Rn. Only sets of sets of vectors can do these things. And the set of vectors of interest here is the set of column vectors of the determinant (more precicely, of the underlying matrix).
For a (quadratic) nxn-matrix A, the following four statements are equivalent, either all four of them are true or all four are false:
1. The determinant of A is nonzero.
2. The column vectors of A is a linearly independent set.
4. The column vectors of A span Rn.
5. The column vectors of A is a basis for Rn.
The corresponding is true for the row vectors.
I think this link might be useful to you, here I answer some of your questions...
"www.physicsforums.com/showthread.php?t=590440"
For now I will say you're mixing up concepts. A determinant itself has nothing to do with linear dependence or with basis... a determinant is simply a number which is assigned to every quadratic matrix. If you understand what a determinant is, then you will be able to understand what the "rank of a matrix" is, which is a number assigned to every matrix (quadratic or not).
I hope I don't get banned or anything for helping you, by the way...
Thanks for the replies, just what I needed Erland.
