Determine a suitable size beam (gantry girder)
  • Thread starter hershl
    Beam
5 replies · 4K views · last reply
hershl
In cross-section, the beam you are working on is a gantry girder.The maximum bending stress in the girder must not exceed 25MN/m2 and the modulus of elasticity can be assumed to be 210GN/m2.
Determine a suitable size for the beam, selected from the standard sections tables.
Also determine the maximum stress of the chosen beam and its radius of curvature.
E=σ=M
R y I
I have worked out the max bending moment as 36KN and drawn the SFD and BMD
Using the formula
σmax=M*ymax
I
This is where i get stuck as the notes i have are for universal beams and not gantry girders
I'm not after the answer but if anyone can shine some light on how to go about solving this i'd be much appreciative.
The course is HNC electronic and electrical eng. With a mechanical principles module
Can you post the cross-section? I'm afraid 'gantry girder' is a rather vague description.
Sorry
The table comes from a British standards book. showing universal, structural tees and gantry girders.
There is no cross section stated in the question(i think this is where I'm getting stuck as i have examples using the cross section).
Here is that table as well as my working of the SFD and BMD.
Thanks
  • Photo of a printed engineering table of section properties from a British standards handbook, with diagrams of universal beams, structural tees and gantry girders and columns of dimensions and properties.
  • Handwritten shear force diagram (SFD) and bending moment diagram (BMD) on squared graph paper, rotated sideways, for a simply supported beam with point loads and a uniformly distributed load.
I would work out the section modulus of the girder required to meet the max. allowable bending stress and then use the tables labeled 'gantry girder' to find a candidate beam.
Is that worked out using the same "max bending moment times 1/2 of depth of beam over 2nd moment of area"
As you would with the universal beam?
The gantry beam sections are not symmetric w.r.t. the neutral axis of the beam. This is clearly shown in the cross section sketches of the attached tables. The section modulus value Z from the beam tables should be the minimum value for a given beam size, and they can be checked by using the appropriate I and y values (Z = I / y). The bending stress is calculated as σ = M / Z, using appropriate units of course.
