Determine if integral is convergent or divergent?
The discussion centers on the application of the limit comparison test for determining the convergence or divergence of improper integrals. The user proposes using the limit comparison test with the sequences an = 1/(2e^x - x) and bn = 1/2e^x, concluding that since bn converges, so does an. However, the conversation reveals skepticism about directly applying the limit comparison test from series to integrals, suggesting the need for a known convergent integral for comparison. The Integral Limit Comparison Test is highlighted as a more suitable method for this purpose.
  • Understanding of improper integrals
  • Familiarity with the limit comparison test for series
  • Knowledge of convergence criteria for integrals
  • Basic calculus concepts, including integration techniques
  • Study the Integral Limit Comparison Test in detail
  • Explore examples of convergent and divergent integrals
  • Learn about other convergence tests for improper integrals
  • Practice applying the limit comparison test to various functions
Students studying calculus, particularly those focusing on improper integrals and convergence tests, as well as educators seeking to clarify the application of the limit comparison test in different contexts.
theBEAST
I attached the problem to this post.
I was wondering if I could use the limit comparison test for this integral. My professor taught us this test that can be used for series but could it work for improper integrals as well?
So what I would do is an = 1/(2ex-x) and bn = 1/2ex.
Then take the limit approaching infinity of an/bn which yields 1. Since bn converges so does an. Does that make sense?
I don't quite understand how you're applying the limit comparison test from series to integrals. However, my instinct is that you are making a jump that can't be made. You might check this yourself by seeing if you can find a counterexample to your method.
However, there does exist a technique that is similar to the limit comparison test. The idea is to find an integral that you know converges/diverges on the interval and use that. So if we had 1/x^2 + 1, we know that on [0,infinity) this integral is < the integral of 1/x^2 on [0,infinity) and therefore converges since the integral of 1/x^2 converges (why? this one is easily computed manually). Can you find such a function here?
This is the equivalent comparison test for integrals.
If \displaystyle |g(x)|\ge|f(x)|\text{ for all }x \ge a\,, and if \displaystyle \int_a^\infty\ |g(x)|\ dx converges, then so does \displaystyle \int_a^\infty\ |f(x)|\ dx converge.
Yup I can use 1/e^x but why wouldn't the limit comparison test work for integrals as well?
I initially interpreted your post as using the a_n, a_n+1 limit test. What you've actually described is very close to what SammyS has posted, which is what the Integral Limit Comparison Test usually describes. I'm reasonably sure that your method works, but the method SammyS has posted is, I think, usually easier.
