Determine if set is a vector space
2 replies · 6K views
Laura1321412
Q) Determine if the set is a vector space under the given operations
The set of all pairs of real numbers of the form (1,x) with the operations (1,y)+(1,y')=(1,y+y') and k(1,y)=(1,ky)
2. Homework Equations / Solution Attempt
I know the axioms needed in this case, and I believe most all of them hold. The ones I am having trouble with in particular are
> There is an object 0 in V called the zero vector such that 0+u= u.
- But there isn't a zero vector if V is defined by (1,x) right?
> For each u in V there is an object -u in V, such that -u + u =0
- But -u would equal (1,-x) + (1,x) = (2,0) -- not 0
However, in the answer section of my book it says that this is a vector space under the given operations. I can't understand how the two above axioms hold... Any help is greatly appreciated!
First: There must be a zero vector, but the only property the zero vector needs to have is that [tex]0 + u = u + 0 = u[/tex] for every [tex]u \in V[/tex] -- using the definition of [tex]+[/tex] you are given. In other words, you shouldn't necessarily expect the zero vector to be [tex](0, 0)[/tex]. In fact, as you point out, [tex](0, 0) \notin V[/tex].
Second: Be careful -- when you compute [tex]-u + u[/tex], what definition of [tex]+[/tex] should you be using?
You can (and should) use the report button to request that your other thread be deleted. (I also agree with what ystael said).
