Determine if two lines are parallel, intersecting, or skewed.
  • Thread starter Thread starter getty102
    Lines Parallel
To determine the relationship between the lines r1=<1+2s,3+2s,2-2s> and r2=<2+t,6-t,-2+t>, the equations were set equal to each other for x, y, and z components. The values s=1 and t=2 were found, but substituting these back into the equations showed that they do not satisfy all three equations, indicating that the lines do not intersect. The direction vectors of the lines were analyzed, revealing they are not multiples of each other, thus confirming the lines are skewed. The discussion also touched on the possibility of coincident lines, but concluded that no solution exists for intersection. The lines are ultimately classified as skewed based on the analysis.
getty102
Determine if the lines r1=<1+2s,3+2s,2-2s> and r2=<2+t,6-t,-2+t> are parallel, intersecting, or skew. If they intersect, find the point of intersection.
x: 1+2s=2+t
y: 3+2s=6-t
z: 2-2s=-2+t
I set the components of r1=r2 then solved for s and t using substitution.
s=1
t=2
I then used 1+2(1)=2+(2) to get 3≠4
therefore it is skewed? or intersecting?
I'm not sure how to find the point of intersection if it does intersect.
The initial process for finding intersection is good (although you didn't tell us which equations you initially used to get candidates for s & t, so checking was impossible). But in essence we need the same two values to satisfy all three equations.
If there is no solution as here, you then need to get direction vectors for the two lines, which consists of the multipliers of the variable parameter here. Then if those vectors are a simple multiple of one another, the lines are parallel, otherwise skewed.
There's also the possibility that the lines are coincident, which will come out of your check for intersection as a relationship between the two parameters (choose any s and you can find a suitable t to satisfy the equations).
I determined that the two planes stated above are not parallel because the planes are not multiples of each other, therefore they are skewed and intersecting. I'm not what the next step is to find the intersecting line.
The lines you specify are not intersecting, because you couldn't find values for t and s that made all three equations true. (Or, more accurately, you showed that no such s & t values exist). Finding a unique s & t would have also given you the intersection point.
I don't know about any planes.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
