Determine initial velocity of a vertical throw
A ball thrown vertically returns to its starting position after 4 seconds, with gravity at 10 m/s². The discussion revolves around using kinematic equations to determine the initial velocity, with suggestions to apply the equation s = v₀t + ½at². Participants clarify that the time taken to ascend equals the time taken to descend, leading to a total flight time of 4 seconds. The initial velocity is calculated to be 20 m/s, but confusion arises regarding the velocity at the moment of landing. Understanding the motion and applying the correct equations are emphasized as crucial for solving the problem effectively.
duchuy
t = 4s , g = 10 m/s^2
I don't really know which equation to use...
Hi,
I was given this problem saying that a ball is thrown vertically up in the air and returns to its initial position after 4 seconds. The acceleration due to gravity is given to be equal to 10m/s^2.
I tried to attempt this problem by using the equation :
v^2 - v0^2 = 2ah by considering terminal velocity = 0. Despite this, i still can't determine the total distance travelled.
Sorry in advance if I have misused any vocabulary sincei translated this from french.
Thank you!
Do you have any ideas?
Well, I'm also trying with v = v0 + at but I didnt really work out..
This is why I chose medecine physics is so so hard..
What about $$s = v_0t + \frac 1 2 at^2$$
But in this case wouldn't I have to values of gravitational acceleration?
When the object is going up, acceleration is negative and when it goes down, it's positive.
Therefore I couldn't use the 4 seconds value because ( i think ), the time the object takes to go up is different from the time it takes to go down right?
That equation is a good start. You know that the ball is in the air for 4 s, and you know the acceleration. If the velocity is +v0 when the ball is thrown up, what would it be at the moment it comes back down after 4 s?
I think the thing that what's stopping me is that I don't know whether the time an object takes to go up is different from the time it takes to go down..
Because I've been considering that it's different, so i didnt really manage to write the equation..
At 4s, wouldn't the velocity be 0?
If I consider that the time is equal, I'm getting v0 = 20 m/s ...
If you're not sure, you could split the motion into two parts (up and down). You can then show using the kinematic equations whether the time to go up is the same as the time to come down.
If you throw a ball up at ##20 m/s##:
1) What is the displacement after ##4s##?
2) What is the velocity after ##4s##?
At 4 s the ball returns to the height from which it was launched. Just before it is stopped, it is still moving, That's the velocity I was asking about. Anyway, I don't want to detract from the course that @PeroK has set so I will cease and desist.
Likes duchuy and PeroK
Oh ok ok I got that thank you two so much!
For the displacement after 40swouldn't it be 40m?
For the velocity I'm not quite sure.. I really thought that it would be 0 since it's the moment the ball landed..
  • Sad
Likes PeroK
Sorry, that's not right at all.
1) That's not what the equations tell you.
2) A ball is moving downwards when it hits the ground after being thrown up.
There are lots of videos on line about throwing an object up. I think you need to develop some sort of physical understanding of what is happening.
But, also, you have to develop the ability to use equations.
