Determine Sign of Half-Angle Identities
  • Thread starter Thread starter rhoadsy74
    identities Sign
10 replies · 3K views
rhoadsy74
Use the figure to evaluate the function that f(x)=sin(x)
f(θ/2)
n/a
x2+y2=1
x= -2/7
(-2/7)2+y2=1
y=√(6)/7
sin(θ/2)= +/- √(1-cos(θ)/2) (the whole function is over 2 inside of the square root)
=+/- √(1-√(6)/7/2)
=+/- √(7-√(6)/14)
I keep coming out with the wrong sign. How do you determine the sign in a Half- Angle identity?
rhoadsy74 said:
x2+y2=1
x= -2/7
(-2/7)2+y2=1
y=√(6)/7
^ Not sure how you got that. Also, the y value has to be negative. Do you know why?
=+/- √(1-√(6)/7/2)
=+/- √(7-√(6)/14)
Is it supposed to be theta or alpha? Your diagram has the angle labeled alpha. Assuming theta, and assuming you know what quadrant it is in, you can guess what quadrant θ/2 is in. You also should know that certain trig functions are positive in certain quadrants.
I used the Pythagorean theorem to find the (square root) 6/7 but it should be negative because of the fact that it is the third quadrant. What I don't understand is how to determine whether the whole function is (+) or (-). Can you help me?
Why should it be negative? I understand that there are certain trig functions that are (+) and (-) in certain quadrants, but why is the the whole function negative?
I'm afraid you made a mistake somewhere. Even with the negative, I am not getting
[tex]y = -\frac{\sqrt{6}}{7}[/tex]
The answer to this question is 3/(square root) 14. That is what my homework is telling me. How do you come to that answer?
I believe I did make a mistake somewhere, just not sure where.
I was not answering the overall question. I was pointing out that you got the wrong y-coordinate of the point in the beginning of your work:
rhoadsy74 said:
x2+y2=1
x= -2/7
(-2/7)2+y2=1
y=√(6)/7
Another thing:
=+/- √(1-√(6)/7/2)
I forgot to mention that this is also wrong. On the unit circle, does cos θ equal the y-coordinate?
Cos of theta equals the x- coordinate. I realize that I got it wrong, but can you explain to me where i went wrong and how the homework came to that answer?
It would be better if you try it again yourself.
=+/- √(1-√(6)/7/2)
Instead of plugging in the y-coordinate (which you still haven't fixed), plug in the x-coordinate, (-2/7):
[itex]\sin \left ( \frac{\theta}{2} \right) = \pm \sqrt{\frac{1 - \cos \theta}{2}}[/itex]
[itex]\sin \left ( \frac{\theta}{2} \right) = \pm \sqrt{\frac{1 - (-2/7)}{2}}[/itex]
This will simplify to [itex]\frac{3}{\sqrt{14}}[/itex]. Try it.
