Determine source frequency and impedance
4 replies · 6K views
TheRedDevil18
The current in a series circuit of R=5 ohms and L=30 mH lags the applied voltage by 80 degrees. Determine the source frequency and impedance.
(Ans: Z=5+j28.4 , f=150.4 Hz)
Current in the inductor,
IL = Vm/wL*sin(wt-80)
Current in the resistor,
Ir = Vm/R * sin(wt-80)
Current in the resistor equals current in conductor
Equating them you get,
1/wL = 1/R
1/w(30*10-3) = 1/5
w = 166.67 rad/s
w = 2*pi*f
f = w/2*pi
= 166.67/2*pi
= 26.53Hz
But they get a frequency of 150.4Hz
have you learned phasors yet? if you have there is an easy way to do this problem.
That being said, your problem is voltage Vm is equel to the voltage drop across the inductor AND the resistor. They are is series. Therefore the voltage drop across the inductor is not vm. You also wrote your time domain equation wrong.
Yes, I have done phasors
I think I found a way using phasors
if z = x∠80
Then, x*cos(80) = 5 (The real part, which is the value of the resistor)
Therefore x = 28.79
So, z = 28.79∠80
Therefore the impedance of the inductor is equal to 28.79sin(80) = j28.4
Angular frequency for inductor
z = jWL
W = 28.4/30*10-3
= 946.67 rad/s
Therefore the frequency is
w/2*pi
= 946.67/2*pi
= 150.67Hz
I think that's correct, yes ?
Thanks
yes! here is how i did it
i=v/z
z=R+LS
we know I=mag(I)∠-80
so z=mag(z)∠80=sqrt(R2+(Lw)2)∠tan-1(Lw/R)
80=tan-1(Lw/R)
solve for w
in other words, the same thing, but used algebra until the end. I recommend you do that, with more complicated problems avoiding calculations until the end can prevent mistakes.
i=v/z
z=R+LS
80=tan-1(Lw/R)
solve for w
Yeah, I see my final answer was a bit off there
Thanks for you help :smile:
