- 42,954
- 10,553
It just means sketch a graph of ω against φ.Davidllerenav said:Ok, So it would be ##\frac{\omega^2}{2} = \beta_0 \sin\varphi+0##, right? I understand, thanks! How do I draw the graph of the dependence?
But how to I graph that?haruspex said:It just means sketch a graph of ω against φ.
How do you sketch any graph?Davidllerenav said:But how to I graph that?
But there isn't any x or y. It is polar coordinates, right?haruspex said:How do you sketch any graph?
Pick a few convenient values of x and see what y is.
Same for gradients at the same points.
Consider local extrema and asymptotic behaviour.
You are just sketching a graph of one variable against another. The physical meanings are irrelevant.Davidllerenav said:But there isn't any x or y. It is polar coordinates, right?
So I have to set ##\omega## as y and ##\varphi## as x, right? Then I you said I just need to plug in values. The values that would be easy to cumpute would be ##\varphi=0##, ##\varphi=1##, ##\varphi=\pi##, ##\varphi=\pi/2##, right?haruspex said:You are just sketching a graph of one variable against another. The physical meanings are irrelevant.
You could sketch it in polar if you wish, but I doubt that is what is expected.
To plot angular velocity, ##\omega ,## as a function of ##\varphi##, the usual convention is to plot ##\varphi## on the x-axis and angular velocity, ##\omega ,## on the y-axis.Davidllerenav said:But there isn't any x or y. It is polar coordinates, right?
Like I said on post #36?SammyS said:To plot angular velocity, ##\omega ,## as a function of ##\varphi##, the usual convention is to plot ##\varphi## on the x-axis and angular velocity, ##\omega ,## on the y-axis.
Well, yes for:Davidllerenav said:Like I said on post #36?
Davidllerenav said:So I have to set ##\omega## as y and ##\varphi## as x, right?
At least, ## \varphi=1## is not an easy value, is it?The values that would be easy to cumpute would be ##\varphi=0##, ##\varphi=1##, ##\varphi=\pi##, ##\varphi=\pi/2##, right?
Oh, yes it isn't, sorry.SammyS said:At least, ## \varphi=1## is not an easy value, is it?
Yes, you're right.SammyS said:Other values "easy" for φφ\varphi are π6π6\dfrac{\pi}{6} and 5π65π6\dfrac{5\pi}{6} .
